Old 04-01-2020, 03:54 AM #1
mymalade mymalade is offline
mymalade is on a distinguished road
Headlight stopped working after removing assembly
This is one has me stumped, I have removed probably 20 different headlight assemblies over the years but have never run into this issue. I pulled out the headlight on my buddy's 06 to change out the fender, and when I put the assembly back in, only the low beam won't work. It is very straightforward, 3 plugs which I pulled off and put back in, so what could cause it to stop working? I checked fuses which are all fine, and tried a new bulb which also did not work.
mymalade is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 06:23 AM #2
Burt Burt is offline
Burt is on a distinguished road
Use a meter and check for voltage at head lamp connector. If absent, maybe the wire harness got damaged when swapping out the fender.
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2019 F250 SuperDuty
Burt is offline   Reply With QuoteReply With Quote
Old 04-02-2020, 11:30 PM #3
hetzler_l33's Avatar
hetzler_l33 hetzler_l33 is offline
hetzler_l33 is on a distinguished road
I’d trace the harness and make sure no wires got pinched when the new fender got installed. Also check the plug end for damage to the pins.
As previously mentioned, a voltmeter will help you in determining the cause
hetzler_l33 is offline   Reply With QuoteReply With Quote
assembly , back , headlight , put , working
4wd stopped working benedict1337 3rd gen T4Rs 0 06-02-2012 04:39 PM
Anybody found a way to remove passenger side headlight assembly without removing the Bonin 5th gen T4Rs 1 03-29-2012 01:21 PM
Removing Headlight Assembly gflurry 4th Gen T4Rs 1 10-08-2011 01:00 PM
Headlight Projector Mod vs. Buying OEM 2006+ Headlight Assembly triguy74 4th Gen T4Rs 26 08-07-2009 09:13 PM
Removing Headlight Assembly?? josh220 4th Gen T4Rs 0 02-10-2008 11:42 PM
