04-01-2020, 05:18 PM
Coastal Offroad Bumpers
I really like the price and the looks of Coast OffRoad bumpers. HOWEVER, I have 0 experience with welding and/or powder coating. What are my options? Thanks!
2004 Limited AWD V8, Icon Stage 2 w/DJ UCA, Nitto Terra Grappler 285/70/17, SCS SR8, Apex Front Recovery Points, Prinsu Roof Rack
04-01-2020, 05:54 PM
You could always order one and pay a local welder to weld it. They would probably appreciate the business during this time too. A buddy of mine got one and we got the whole think tacked in an afternoon. Super fun project. I'll be getting one of these soon hopefully. As for powder coating thats a personal preference. I know mine is gonne get scratched up from wheeling so I'm just going to bed liner mine. Then I can just rattle can it whenever it gets scratched up. Its a lot harder to fix powder coat.
06 Galactic Limited on 33's, Rear locker, Bilstein 5100s, Toytec 2" Superflex Springs, Whitson Metalworks Rack, Squadron Sport Ditch Lights, Dual Viair 450cc Air compressors with 2.5 gal tank, Cobra 75WXST CB Radio
Build Thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
04-01-2020, 06:58 PM
Sexiest bumper on the market pho sho
PS got a friend who welded it for me
04-02-2020, 10:01 AM
yeah definitely need to find welder friends lol
04-02-2020, 10:15 AM
It was a very fun project for my 2nd gen. I would recommend it as well just based on final product. Options are
1) get a welder yourself by borrowing or renting if that's possible, practice a bit and weld it yourself
2) have a pro do it for probably $3-500
That's it. The thing about it is that you're likely going to grind down all the outside welds anyway to make it look more smooth so weld appearance isn't that important, other than having it be strong.
I also recommend AGAINST powder coating if you plan on using the vehicle for actual off-roading. Reason being, if you scratch it ever, you will cry. And it can't really be fixed to look perfect again I don't think. I rattle canned mine in my gargage and it looks amazing. Plus when it gets dings or scratches, I literally hold a piece of cardboard to block off overspray and touch it back up in less than one minute.
End result makes it all worth it
04-02-2020, 02:04 PM
Agree with the Coastal off road bumper being awesome looking. I'm in the same boat when it comes to either needing to learn to weld, or pay someone to do it. Neither option is attractive.
A similar design you can get for not *too* much extra is sos offroad concepts bumper. They've got a 20% off coupon right now, as well as 160$ sipping, which keeps the whole thing under 900 shipped to the nearest UPS facility.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
04-02-2020, 02:38 PM
Welded my own as my first welding project. It sounds harder than it is, seriously. I literally just watched a bunch of YouTube videos, bought a second hand welder off Craigslist and started practicing.
Sent from my SM-G986U using Tapatalk
04-02-2020, 02:58 PM
What kind of welder did you guys use for this? Did you need a plug with higher voltage in your garage?
04-02-2020, 03:16 PM
I got a Lincoln weldpak style welder that runs off a standard wall plug. In hindsight the only thing I would recommend is getting gas to run mig. I did it flux core with no gas and its a lot more clean up. But Flux core does work and you do get strong welds.
04-02-2020, 03:40 PM
I’ve been eyeing their kits, as well. I’ve been wanting an “excuse” to buy a welder and this is perfect one.
04-02-2020, 04:33 PM
The fit up is pretty good, some minimal grinding required for everything to fit great. I had some issues but for first time welder with zero experience and no classes or anything, I think mine turned out well. Having issues uploading photos for some reason or I would add one.
04-02-2020, 04:38 PM
Here we go, hope it shows up ok.
03-13-2021, 03:00 PM
Is this the 06' runner? I noticed the grills are different on some of the 4th gen runners and am wondering if I'll run into issues following the fender lines from where the grill drops down (Drops about 1" below the left and right fender lines) or does the kit compensate and cut around the grill..?
I am expecting the kit to arrive next week sometime.
03-13-2021, 04:23 PM
Real Name: Howard J. Turkstra
Montijo505’s signature line says ’08. I’m not positive, but I think 06-09 are the same, as are 03-05. I don’t have an answer to your fender line question. I have an ’04.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
03-13-2021, 07:45 PM
Real Name: Todd
Real Name: Todd
Pretty sure the fender lines are still the same from 03-09. Only the grill, headlight and the trim piece below the headlights are different.
4th gen 4runners have a sort of smile to them when you are building the bumpers. They are all the same for the 4th gen years. You compensate for the smile when you are building the bumper.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
