Old 10-17-2012, 01:23 PM #1
Smhx4 Smhx4 is offline
Smhx4 is on a distinguished road
Transmission flush or drain?
2003 SR5 V6 4x2 118k miles. Service has never been performed.
The dealer recommended a flush. Firestone said at this point do a drain and refill only. Is too risky to flush the system, could cause problems.
Dealer also recommended power steering flush, Firestone said they never need flushing.
Also I've always used synthetic oil but the previous owner didn't. Can I switch, should I bother?
I appreciate any advice. Thanks, Sandra
Smhx4 is offline   Reply With QuoteReply With Quote
Old 10-17-2012, 01:34 PM #2
20034RunnerV84x2's Avatar
20034RunnerV84x2 20034RunnerV84x2 is offline
Real Name: Allen
20034RunnerV84x2 is an unknown quantity at this point
Real Name: Allen
Drain & fill. Transmissions are very picky on having them flushed. Power steering is your choice and synthetic is too. I use synthetic myself personally.
2003 Toyota 4Runner SR5 iForce 4.7L V8 2WD Natural White With Plastic Bumper Cladding, Everything Completely Stock.
Owned since 10/3/11
90,000 Miles and counting!
20034RunnerV84x2 is offline   Reply With QuoteReply With Quote
Old 10-17-2012, 02:11 PM #3
4runnin83 4runnin83 is offline
4runnin83 is on a distinguished road
I agree, with the amount of miles on your tranny, doing a complete flush could shock the system, just drain and fill. Now if you get the pink milkshake, you'll have to flush, but at that point, thats the least of your worries.
4runnin83 is offline   Reply With QuoteReply With Quote
Old 10-17-2012, 02:50 PM #4
BOSMECH's Avatar
BOSMECH BOSMECH is offline
Location: Stockbridge GA. ( formerly Kent WA. ) & ( formerly Grafton MA. )
BOSMECH is on a distinguished road
BOSMECH's Avatar
Flush it for sure, it is the correct and right thing to do, thats a no brainer.
BOSMECH is offline   Reply With QuoteReply With Quote
Old 10-17-2012, 03:35 PM #5
MikeInNH MikeInNH is offline
MikeInNH is on a distinguished road
Flushing on many transmissions can cause problems. There are some newer safer methods. But it depends on who's doing it.
Does this tranny have a filter like the 2005 does? If so then is the dealer going to replace the filter when they do the flush?
As for power-steering wheel fluid. No need for a flush. Might want to replace it. But a flush isn't needed. You can replace it easily yourself. Get a Turkey Baster and remove old fluid..then add new fluid. Check your owners manual for the right fluid.
As for synthetic oil......Depends...99% of the time it's NOT needed. You can switch anytime you want. Or switch back anytime you want..or just both at the same time. Doesn't matter. Is it worth it??? Well that's another debate.
MikeInNH is offline   Reply With QuoteReply With Quote
Old 10-17-2012, 03:54 PM #6
BOSMECH's Avatar
BOSMECH's Avatar
You want to flush it, it will acuate the valve body and clean it that is the most important part and then your tranny runs smoother.
Done
Old 10-17-2012, 04:02 PM #7
malu malu is offline
malu is on a distinguished road
Good thing that I have a 2008. I don't have to do any thing to the transmission because it's sealed off you don's have to add new oil. I did change my power steering and brake fluid but I don't think I had to. It was my choice.
malu is offline   Reply With QuoteReply With Quote
Old 10-17-2012, 05:09 PM #8
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
I would advise against a flush, unless you have service documentation indicating that the fluid has been changed regularly in the vehicle. Even the company who maintains our transmission fluid flush machine says if its over 90k without a flush, to drain and fill as it could cause problems.
A simple drain and fill should do fine, if you're really worried, do a couple drain and fills until the fluid looks nice and clean. You can switch to synthetic no problem, it should not cause issues.
In regards to a comment made about Toyota transmission filters, so far no one at our dealership has replaced a filter as part of a service. It bothered me that we didn't do this, upon some research I found that Toyota utilizes a metal mesh filtering medium unlike many other cars that "does not need to be serviced." I put that in quotations because I'm sure at some point you'll have to pull the filter off and scrub it, but there isn't any info on that.
As for power steering fluid, theoretically it never needs to be flushed (Hey, WS fluid theoretically doesn't need to be flushed too,) realistically it picks up bits of metal, gets cooked, and wears like any other fluid in the car. If the fluid is black as crude and smells burnt, I would go ahead and do a flush or two, maybe even look for possible leaks letting contaminants in. Otherwise, its its golden to dark amber colored, its fine. (This is assuming your using a P/S fluid that is golden in color to begin with.) It doesn't hurt to replace it regularly (60-90k is what I do myself) but it won't hurt to not do it either.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 10-17-2012, 05:16 PM #9
This is untrue, Toyota states that the WS Fluid is "lifetime fluid," but if you look at your owner's manual and Toyota's service information, the fluid must be changed at 60k if you do towing or use and then goes on a 30k interval for flushes.
I've stated many times in multiple other threads my disbelief in anything labeled as "lifetime fluid" especially transmission fluids. For those of us driving normally or moderately in our 4Runners a 100k flush & fill is probably a good idea. Our dealership even recommends it as a service item around that mileage.
Toyota like other manufactuers who use these "magical lifetime fluids" have conflicting literature in there service information. For example:
T-SB-0006-11
States in one line; World Standard (WS) Automatic Transmission Fluid (ATF) was introduced to reduce maintenance costs and increase the mileage between scheduled maintenance checks. Here are some important tips when working with ATF-WS in Toyota vehicles requiring its use.
Yet further in the TSB it also states; 100,000 Mile Maintenance Interval - Inspection only; ATF-WS does NOT require any flushing or changing during the life of the vehicle.
Old 10-17-2012, 06:46 PM #10
Presta24's Avatar
Presta24 Presta24 is offline
Presta24 is on a distinguished road
Presta24's Avatar
i wouldnt flush if its never been done......drain and fill, run for a few k miles, than drain and fill again....if you want
2003 4Runner SR5 V8 AWD + Daystar 2.5/1.5 + FJ Swap + Definity Dakota 285/75r16 MT's
2014 Taco 6spd TRD OR billies/dakar HD pack/33's
Presta24 is offline   Reply With QuoteReply With Quote
Old 10-17-2012, 11:10 PM #11
cabowally cabowally is offline
cabowally is on a distinguished road
Why?
What is it about a fluid flush that can "shock" a transmission?
cabowally is offline   Reply With QuoteReply With Quote
Old 10-18-2012, 12:01 AM #12
Merle Merle is offline
Merle is on a distinguished road
You should. I have the 2008 and if anything I planned on keeping my vehicle. So off to the dealer she went at 100,000. There are posts about how to do it yourself, but I saved myself the hassle of 4+ hours and just read a couple days of the WSJ.
Merle is offline   Reply With QuoteReply With Quote
Old 10-18-2012, 12:16 AM #13
Originally Posted by cabowally View Post
Why?
A quick note of what happens in your transmission, the fluid holds the duty of being a friction enhancer, lubricant, coolant, and hydraulic fluid. Over time small bits of the metal clutch discs and the friction material wear off, mixing with the fluid and turning into deposits on the inside of the transmission like you would find with clogging drains in a house.
When you perform a fluid flush you are often using a machine to force fluid through the system, our unit uses the transmission itself, but often those pressures can loosen deposits. You see this more with a "backflow" method that provides pressure against normal flow to break off deposits.
But in both cases it can loosen a large amount of deposits that can clog up the filter and or the valve body of the transmission impeding proper operation. That's why for transmissions that have not been serviced in 90k are often not flushed.
Old 10-18-2012, 09:20 AM #14
wadle5's Avatar
wadle5 wadle5 is offline
wadle5 will become famous soon enough
wadle5's Avatar
So I have owned mine for about 5 months and am coming up on 80k. Past owner/dealership have no past paperwork on it, so would you recommend a flush or what? 2006 SR5 v-6
wadle5 is offline   Reply With QuoteReply With Quote
Old 10-18-2012, 09:39 AM #15
Is this a change for 2008 and later. Because my 2005 owners manual specifically says it does NOT need changing unless the tranny temp light came on. Makes no mention if it's used for towing or not.
I do change my tranny fluid every 50k miles. It's cheap insurance. The filter gets cleaned..and not replaced. But in order to do this you have to drop the pan. And flushes usually don't do that.
Transmission Service: Drain & Fill or Machine Flush? budda919 4th Gen T4Rs 41 09-02-2016 11:14 AM
Transmission oil drain and flush quatin 3rd gen T4Rs 19 06-16-2015 12:48 AM
Transmission drain/flush 96Blacklimited 3rd gen T4Rs 10 04-10-2010 01:05 PM
Transmission Flush or Drain/Fill smokey7722 Maintenance/Detailing 9 04-09-2009 10:51 AM
transmission flush or drain? judoant 3rd gen T4Rs 6 03-13-2007 03:00 PM
