Old 04-10-2020, 06:31 PM #16
grave's Avatar
grave grave is offline
grave has a spectacular aura about grave has a spectacular aura about
grave's Avatar
In here just to say DO NOT order from marion b2b. The dude is a ****ing terrible flake. Assemblies take 4-6 weeks to arrive (I made the mistake of ordering a second after my first bad experience, thinking it would be better) even when the order confirmation email says a week or so and the guy does only responds to one out of four or five emails/phone calls and even then it’s just BS like he had a family emergency has been “super busy.”
One of his bearings failed on me in less than a year so I tried contacting him for a warranty through email and by phone to no avail.
I ended up getting a NAPA assembly during black friday deals and it’s been great so far ¯\_(ツ)_/¯
grave is offline   Reply With QuoteReply With Quote
Old 04-11-2020, 12:49 AM #17
terminal4's Avatar
terminal4 terminal4 is offline
terminal4 is on a distinguished road
terminal4's Avatar
I also was just informed by my dealer that it will be $800 for the front passenger wheel bearing. no thanks. so far i have read reputable reviews of wheel bearing hub assemblies from bluepit and jerseybuilthubs. Poll? Feedback is appreciated!
terminal4 is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 11:17 AM #18
Jaybob7 Jaybob7 is offline
Jaybob7 is on a distinguished road
Howdy guys and gals!
My front-right bearing is on its way out. I ordered a hub assembly from "Detroit Axel".
Does anyone have experience / reviews with Detroit Axel?
(Front Wheel Bearing & Hub Assembly #950-001-4WD/AWD-Lexus/Toyota)
Thanks!
Jaybob7 is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 08:16 PM #19
MikeinNH67's Avatar
MikeinNH67's Avatar
Thanks!
I did some research on this recently and the general consensus was Toyo or NSK as they are made in Japan. Reviews on Amazon are all over the place for the others. Seems if not stamped with these 2 brands then they are Chinese. I almost went with Detroit Axle as they had a good warranty but I decided to get a Beck/Arnley bearing without hub because the picture shows Koyo, I hope it's accurate.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 01-12-2021, 02:51 AM #20
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Just an FYI, there many Chinese counterfeit bearings out there with the Koyo name on them, the most telling factor of the bearing being counterfeit is price, normally for a genuine Koyo bearing alone without the hub the price should be around $80.
2004 Limited V8
Old 01-12-2021, 05:09 PM #21
MikeinNH67's Avatar
MikeinNH67's Avatar
I got it from Rockauto and it was over $80 so hopefully it's the real Mccoy. You can get the whole assembly in the same brand for the same price but the picture shows nothing stamped onto the bearing.
Mike
03 4runner Limited
Old 01-14-2021, 04:47 PM #22
MikeinNH67's Avatar
MikeinNH67's Avatar
It arrived and looks pretty real to me.
Hopefully get it installed this weekend.
Pre-pressed Hub Assemly options?-koyo-jpg
Mike
03 4runner Limited
Old 01-14-2021, 07:39 PM #23
Real Name: Skip
Real Name: Skip
Was the price you paid for just the bearing or the bearing and hub together?
2004 Limited V8
Old 01-14-2021, 10:17 PM #24
MikeinNH67's Avatar
MikeinNH67's Avatar
The bearing and 2 seals for that price. I will reuse the old hub I pulled from the other side.
Mike
03 4runner Limited
Old 01-15-2021, 04:49 PM #25
MikeinNH67's Avatar
MikeinNH67's Avatar
A bit more info on this, the Beck/Arnley box with just the bearing & seals says Made in Japan on it. The same brand with the completed assembly says China. The Japan one looks very well made.
Today I got the old bearing and race completely off the hub and cleaned the hub up. Got it mocked up for pressing in but I want to compare it to the one I pull off for peace of mind. It does look like someone replaced the bearing on the hub I'm using at some point as it had some gouges under the bearing that I did not put there.
Mike
03 4runner Limited
dorman , good , hub , option , pre-pressed
Hesitation anytime gas is pressed FrankieJoe14 3rd gen T4Rs 10 05-06-2018 01:48 PM
Shuddering When Gas Pedal is Pressed CowboyBob 3rd gen T4Rs 6 11-14-2017 06:00 PM
Headlights dim when brake pedal pressed...anyone else? Antman 5th gen T4Rs 60 12-10-2014 01:02 AM
Firewall flex when clutch is pressed frank_socal 3rd gen T4Rs 9 11-17-2013 12:36 PM
Spinning noise whenever cluntch is pressed dbg 3rd gen T4Rs 6 11-30-2008 07:43 PM
