Old 04-08-2020, 04:22 AM #16
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Originally Posted by joshik View Post
anyone else talk to Marlin? Did he say anything about others outside of this thread calling about the boot?
I texted him after I posted my pics...no reply.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 04-08-2020, 12:57 PM #17
ktom3001 ktom3001 is offline
ktom3001 is on a distinguished road
yep it is mag seat.
not sure what the the specs are on the wheels anymore but i put on 1.25" spidertrax spacers on a while back. I wanted the wheels to sit out a little further.
Looks like Marlin is going to have a lot of requests for washers!
So my 18" Limited wheels have the lugs with the captive washer, is that the mag seat? Never mind I found it.
JBA UCA post install thoughts - boot not fitting right?-lugs-png
ktom3001 is offline   Reply With QuoteReply With Quote
Old 04-08-2020, 01:00 PM #18
joshik joshik is offline
joshik will become famous soon enough
most likely yes. Mag seat is actually a shank style.
Lug Nut Seat Type
2003 4Runner Limited 4wd V8. JBA UCA, Dobinsons MRA Front Coilovers, Dobinsons MRA Long Travel rear. Cooper AT3 XLT 285/70R17
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. [SOLD]
joshik is offline   Reply With QuoteReply With Quote
Old 04-08-2020, 01:02 PM #19
hm, he was responding to me within the day at the least.... what number u texting?
Old 04-08-2020, 02:36 PM #20
hm, he was responding to me within the day at the least.... What number u texting?
(215) 660-3770
Old 04-08-2020, 03:53 PM #21
(215) 660-3770
ah yeh thats what i got
Old 04-08-2020, 05:37 PM #22
Just messaged him again. We'll see.
Old 04-09-2020, 02:41 AM #23
All Good Now!
I got my 2 washers today and installed them after the kiddos went to bed. Took about 30mins-ish per side but took longer because I had to replace the driverside ABS/speed wire. I also took time to bend open the brackets and adjust the wire so that the brackets could mount using the default hole and I could freely adjust the wire so it would not bend too sharp or be too tight.
So after I installed the 2nd washer it looked better. But after I went for a drive I guess it magically seated itself and looks great!
Old 04-09-2020, 03:13 AM #24
Nice! Looks like the washers did the trick! Now if only Marlin would text me back...
Old 04-09-2020, 02:15 PM #25
Shout out to Marlin! He replied who replied to my text early in the morning (apparently this sort of stuff is covered under "Warranty Ball Joint Washers") and shipped the washers out today! I gotta remember 60 ft-lbs for that nut.
This shouldn't change any alignment specs right?
Old 04-13-2020, 08:49 PM #26
How'd you get the ball joint back out? I took a quick stab today and couldn't get the UCA to lift up to get the threading out of the spindle!
Old 04-13-2020, 09:35 PM #27
Ah. I rented a pitman arm puller from autozone. I used it on my OEM balljoint and it took quite a bit of effort. The JBAs came off easily, I'm assuming since I had recently installed it.
Did you try whacking it a bunch with a rubber mallet?
Old 04-13-2020, 09:56 PM #28
I couldn't get the JBAs off at lunch so I put her back together for now.
I tried a mallet and it never popped out. I don't know if I'm not hitting it hard enough or what...it hasn't been very long since install.
Old 04-13-2020, 09:58 PM #29
the vids ive seen of peeps using a mallet are hitting it pretty hard.
the pitman/tierod pulller worked well.
Old 04-13-2020, 10:34 PM #30
I'll try with a 3lb sledge next time I take the wheels off lol.
abs , bracket , install , line , uca
Those thinking about a Daystar lift with XREAS - My thoughts and install experience Runn4est 5th gen T4Rs 99 07-24-2021 01:13 PM
Post Suspension install question WEAK_E90 5th gen T4Rs 6 05-13-2019 01:02 PM
Post suspension upgrade thoughts... tenguns 4th Gen T4Rs 3 01-26-2018 10:41 PM
post lift install JPWendtinc 4th Gen T4Rs 6 07-28-2011 11:27 AM
