Old 04-03-2020, 11:50 PM #1
joshik joshik is offline
joshik will become famous soon enough
JBA UCA post install thoughts - boot not fitting right?
I finally got around to installing my JBA UCA. My stock ball joints boots were torn and leaking grease... so i thought, might as well get whole new UCA with new ball joints!
Sorry, I don't have any pics. Install wasn't too bad. I was able to get them in on my own and as most people have stated, the inner washers are a PITA to squeeze in but I was able to figure out a way to do it on my own.
Driver's side I had to remove some of the brackets to allow for a torque wrench to fit in place. I also had to take out my battery to get the bolt out.
On the passenger side I had to remove some brackets as well to allow for a torque wrench. On this side, I had to remove the 3 bolts for power steering reservoir so I could push a hose out of the way a little to allow the UCA bolt to come out.
I also made the mistake on the first side of not disconnecting the ABS line braket. I popped the knuckle off with a pitman arm remover with the castle nut still in place so stuff didnt go flying everywhere. However, after I got the knuckle free, I removed the castle nut and of course, the UCA shot up and stretched the ABS line. It looked ok. I pushed the UCA down while I removed the bracket. After the install, i took the car for a drive and my VSC, ABS and TRAC lights are on. God the code read while getting an alignment today and confirmed I broke the driver side ABS wire.
Putting the brackets back onto the UCA was a PITA. The instructions state that you may have to bend the brackets to get it in place but I had to drill new holds and tweak the bracket to get the line to not stretch.
After the install I noticed that the ball joint boot is not seating properly allowing grease to come out. This is happening on both sides. Anyone seem anything like this before?
2003 4Runner Limited 4wd V8. JBA UCA, Dobinsons MRA Front Coilovers, Dobinsons MRA Long Travel rear. Cooper AT3 XLT 285/70R17
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. [SOLD]
joshik is offline   Reply With QuoteReply With Quote
Old 04-04-2020, 06:55 PM #2
I texted Marlin at JBA today and sent him some pics of the boot. He said he may need to send out some extra boot washers to push the boot up more to the bottom of the UCA.
Hats off to Marlin for answering texts on a Saturday!
Got my alignment today. Was able to achieve a caster of 4.4 and 4.7.
Old 04-05-2020, 07:00 PM #3
T4R916 T4R916 is offline
T4R916 is on a distinguished road
I had mine for 2 years and the boot is the same as yours. Do we have to contact him to get the boot washers?
T4R916 is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 07:06 PM #4
Yeh, call or msg him on his site (the chat feature) and ask him about the washers. After I got an alignment it doesn't look AS bad but will still add in another washer. I just don't want to have to take off my wheel and knuckle again.
I was searching for a washer that is in two pieces that i could squeeze in and that is held together by some sort of "clip". That way I don't have to take apart the knuckle :T
Old 04-06-2020, 11:52 PM #5
Marlin shipped out new washers to me today!
Old 04-07-2020, 09:37 AM #6
RivMan's Avatar
RivMan RivMan is offline
RivMan has a spectacular aura about RivMan has a spectacular aura about
RivMan's Avatar
Mine fit the same way, I should get a hold of him.
-Rob
RivMan is offline   Reply With QuoteReply With Quote
Old 04-07-2020, 09:40 AM #7
-Rob
wow yeh?
Can you pretty much stick your finger under the boot and into the slot where the ball joint moves?
Old 04-07-2020, 04:02 PM #8
ktom3001 ktom3001 is offline
ktom3001 is on a distinguished road
Originally Posted by joshik View Post
wow yeh?
Mine are the same too. The ABS bracket is a pain as I had to physically slide the harness to get enough slack and wrap with electrical tape to protect it.
It's on my list to go back in for a more permanent solution.
JBA UCA post install thoughts - boot not fitting right?-img_1700-jpg
ktom3001 is offline   Reply With QuoteReply With Quote
Old 04-07-2020, 04:22 PM #9
yeh it looks like u can pull down the boot easily and expose the ball joint.
Old 04-07-2020, 04:54 PM #10
Side note, I see you're running the Tundra/Sequoia wheels, which lug nuts did you use with those? Conical seat?
I'm going to try a set out to see if the offset works better with the JBA arms.
Thanks
Old 04-07-2020, 05:10 PM #11
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Thanks
Stock lugs - mag seating.
Fitment takes tire size and offset into account - I'm running +15 Trail wheels and 1.25" spacers to account for my tire size (whenever they get here).
Great, now I'm gonna have to go look at my UCAs for the boot fitment lol.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 04-07-2020, 05:26 PM #12
yep it is mag seat.
not sure what the the specs are on the wheels anymore but i put on 1.25" spidertrax spacers on a while back. I wanted the wheels to sit out a little further.
Looks like Marlin is going to have a lot of requests for washers!
Old 04-07-2020, 05:50 PM #13
Real Name: Skip
Real Name: Skip
I would say they need to redesign something or at the very least include extra washers with each sale!!
If you ask me I would think they're going to lose some sales over this "little" need another washer issue, which is a big issue if you ask me, IMHO they should also pay for the addition labor of taking it apart to install the extra washer!!
2004 Limited V8
Old 04-07-2020, 06:07 PM #14
Mine look identical to yours. I guess I need to message Marlin!
Old 04-08-2020, 01:22 AM #15
anyone else talk to Marlin? Did he say anything about others outside of this thread calling about the boot?
abs , bracket , install , line , uca
Those thinking about a Daystar lift with XREAS - My thoughts and install experience Runn4est 5th gen T4Rs 99 07-24-2021 01:13 PM
Post Suspension install question WEAK_E90 5th gen T4Rs 6 05-13-2019 01:02 PM
Post suspension upgrade thoughts... tenguns 4th Gen T4Rs 3 01-26-2018 10:41 PM
post lift install JPWendtinc 4th Gen T4Rs 6 07-28-2011 11:27 AM
