Old 04-04-2020, 02:21 PM #1
Bernardchan96 Bernardchan96 is offline
Real Name: Bernard Chan
Bernardchan96 is on a distinguished road
Is there a quick way to open a section of my timing cover 05 v8
Have an intermittent oil pressure light that comes on very dimly and i suspect its a wiring issue based on reading t4r. Now im wondering is there a quick/easy way to open crack open a section of the timing belt cover to inspect a harness. Picture for reference on the harness i want to check.
2005 4R LIMITED V8
FALKEN WILDPEAK AT3W&TRD RIMS/BILSTEIN 5100&FJ COILS/VOLANT CAI
Bernardchan96 is offline   Reply With QuoteReply With Quote
Old 04-04-2020, 02:55 PM #2
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr has a spectacular aura about xtremewlr has a spectacular aura about xtremewlr has a spectacular aura about
xtremewlr's Avatar
Real Name: Todd
Not really. There is a metal coolant tube that uses one of the retaining nuts for the cover that runs right in front of it that pretty much needs to come out to get that cover off. And the wiring harness runs in front of the cover as well. You can see the tube here.
xtremewlr is offline   Reply With QuoteReply With Quote
Old 04-04-2020, 04:08 PM #3
Hm, if i drained all the coolant top of air filter, radiator hoses could i get that cover off without removing serp belt and the pulleys and stuff? Dont want to remove like ac compressors
2005 4R LIMITED V8
Old 04-04-2020, 04:09 PM #4
This just makes it really hard because im not due for a timing belt replacement for a little while, and i wouldnt be able to tackle that on my own. Also im not 100% sure its sending proper oil to the engine but i still have to drive it
2005 4R LIMITED V8
Old 04-04-2020, 04:13 PM #5
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
AC compressor isn't even involved. You could drain out some coolant to be able to remove the one line but the rubber hose isn't easy to get to. Mine had to be cut off when I was doing the timing belt but that wasn't a big deal for me. Each of the plastic timing covers are individual and can be removed one at a time. Just that coolant tube makes it a pain in the ass on that side.
Old 04-04-2020, 04:37 PM #6
I really dont wanna get into removing the timing cover since i dont have to do the belt soon.. im not that comfortable doing that shit
2005 4R LIMITED V8
Old 04-05-2020, 01:22 PM #7
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 will become famous soon enough Warwicke36 will become famous soon enough
Warwicke36's Avatar
Is the OPS under the timing cover? Or does the harness just run through there? If the OPS is more easily accessible you can just run a new wire inatead if reparing the faulty section in the current ciruit.
2004 Sport 4.0, Bilstein 5100s w/ 2.5" Toytec springs, TRD wheels, Falken Wildpeak AT3W tires, Gibson stainless elite, Blackout headlights with LED, DIY Grille lights, Crux Bluetooth adapter and upgraded subwoofer
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 01:39 PM #8
Im not 100% sure tbh, i saw a guy on t4r with the same issue and this is what resolved it. Im going to be replacing the oil pressure sender/switch the sits right above the oil filter in the next week or so, but i dont have any other option but to keep driving the vehicle for now.
2005 4R LIMITED V8
cover , harness , open , section , timing
Only open this if you have an OME lift. Quick question. trey99ek 4th Gen T4Rs 9 07-17-2016 12:49 AM
Quick timing belt question with PICS Philbush1127 3rd gen T4Rs 65 11-04-2015 06:11 AM
Quick question for timing belt change KainDrag 3rd gen T4Rs 30 08-10-2015 01:42 AM
