Old 04-04-2020, 03:48 PM #1
rpete rpete is offline
Real Name: Rob
rpete is on a distinguished road
Real Name: Rob
Headlight questions. 03-05 assembly and 06+ assembly
Hey ya'll, weird question and am look for advice. I have a 2006 with the newer style headlight assembly. My runner has been an outside beast it's whole life so the headlights are considerably faded. I found someone local getting rid of a basically brand new replacement set after he bought them but ended up finding a deal a month later on a blacked out set so he went with those. I went to pick them up and found out they are the older 03-05 style assembly unit. I also have HIDs. I've read on a few of the different forums on here the HIDs can melt the lower quality assemblies which I assume these are because they didn't cost me an arm and a leg. From what I've read everything else with them matches up correctly it just has a different look. If I like the newer style and would like to stay with it what do you guys recommend? Could it be as simple as heating them up and swapping just the front half of the assemblies, the clear plastic part? As you'll see in the pictures the new ones are considerably more clear than the ones I currently am using.
2006 4 runner SR5
rpete is offline   Reply With QuoteReply With Quote
Old 04-04-2020, 03:49 PM #2
Real Name: Rob
Real Name: Rob
2006 4 runner SR5
Old 04-04-2020, 05:14 PM #3
Az4runnin's Avatar
Az4runnin Az4runnin is offline
Az4runnin will become famous soon enough Az4runnin will become famous soon enough
Az4runnin's Avatar
The 03-05 Lens Covers are different. Stick with what you have. Get a Good kit to get rid of the Haze
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
Az4runnin is offline   Reply With QuoteReply With Quote
Old 04-04-2020, 07:15 PM #4
hetzler_l33's Avatar
hetzler_l33 hetzler_l33 is offline
hetzler_l33 is on a distinguished road
They won’t fit
The newer ones are better anyway
hetzler_l33 is offline   Reply With QuoteReply With Quote
Old 04-04-2020, 08:44 PM #5
Real Name: Rob
Real Name: Rob
Thanks! And I agree with y’all I like the new ones way better. They are just hazed so bad I was hoping this option would work. I’ve tried a handful of different wax and polish kind of kits and they never seem to last. Any one in particular you guys would recommend?
2006 4 runner SR5
Old 04-04-2020, 09:27 PM #6
Az4runnin's Avatar
Az4runnin's Avatar
Thumbs up
Use a quality kit to make them look new again then use this
Optimum Opti-Lens Permanent Headlight Coating, headlight coatings protectants
Old 04-05-2020, 06:29 PM #7
huffcaps huffcaps is offline
huffcaps is on a distinguished road
On all my cars with plastic lenses I started just sanding them up to 600+ grit or however high you want to go to remove the oxidization. Then I spray with a UV resistant clear coat. You can easily find all this stuff at your local auto parts or hardware store. Makes a good Saturday project and takes 1 to 2 hours tops, especially if lenses are easily removed unlike my 05 Acura RL. I find this method gets me 2 to 3 years before I see the clear coat start to flake and I repeat the process.
Sent from my SM-G981U using Tapatalk
Edit: forgot to say this is also an inexpensive method. You should be able to do this for less than 20 bucks. I imagine removing the assembly on the 4runner is simple. If it isn't just mask around the lens to keep overspray at bay.
huffcaps is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 08:36 AM #8
Ventil8 Ventil8 is offline
Real Name: Armando
Ventil8 will become famous soon enough Ventil8 will become famous soon enough
Real Name: Armando
keep the insides of the OEM headlights. Buy a cheap set of headlights for your model year 4R. Take the lenses off by baking them in the oven. Swap out the lenses. I have done this with my OEM reflector headlights in case I ever need them. I currently have HID retrofit with morimotos on my 2005 4R.
Original Owner- 2005 Silver Metallic Sport Edition 4WD V6
Ventil8 is offline   Reply With QuoteReply With Quote
assembly , considerably , found , set , style
WTB 3rd gen headlight assembly Jduv10007 For Sale: T4R Items 2 02-19-2016 04:01 AM
headlight assembly cpavlenko 4th Gen T4Rs 2 04-08-2015 06:18 PM
OEM Headlight Assembly mshaner152 4th Gen T4Rs 4 04-06-2013 10:54 PM
5th Gen SR5 OEM Headlight Assembly L&R FX44 For Sale: T4R Items 0 09-09-2012 07:23 PM
Headlight Projector Mod vs. Buying OEM 2006+ Headlight Assembly triguy74 4th Gen T4Rs 26 08-07-2009 09:13 PM
