Old 04-04-2020, 04:47 PM #1
IRONSHIEK IRONSHIEK is offline
IRONSHIEK is on a distinguished road
265/70 on 17x9?
Is anyone running 265s on 17x9 wheels? The set of wheels I’m looking at are this size but it would be a deal breaker if I’ll run into problems. 2” lift and stock uca. Thanks
IRONSHIEK is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 12:37 AM #2
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
A bit wide but shouldn't be a problem - what's the offset?
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 12:32 PM #3
Offset options are 1 or 20 w Bore 106.
Old 04-05-2020, 03:54 PM #4
+1 will sick out further than +20 - if you ever plan on going bigger on tires or just like a wider stance - +1 is the better option, otherwise go +20 since it's only 10mm off factory offset. 106 bore should work.
Old 04-05-2020, 06:31 PM #5
zig553's Avatar
zig553 zig553 is offline
zig553 is on a distinguished road
zig553's Avatar
265/70 fit just fine on 17x9s. Here they are on my 17x9 Level 8Mk6 -12. This is stock height as well.
265/70 on 17x9?-4runner-jpg
zig553 is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 10:53 AM #6
265 is the stock width tire on 4th gen 4runners, 265/65/17. stepping up to a 265/70 is the same width but the tire is slightly taller on the 70 series. tons of guys run 265/70 including me with stock suspensions heights. shouldnt be any problem running that size especially with a 2" lift.
Old 04-06-2020, 02:26 PM #7
By a bit wide, I meant the wheels not the tires. Stock is 17x7.5.
Old 04-07-2020, 11:58 AM #8
I appreciate all your feedback. My main concern is having any sort of alignment limitation while running factory UCAs as well as having to cut fender off the body.
Old 04-07-2020, 02:47 PM #9
Shouldn't have any issues if you stick with that size.
Old 04-07-2020, 03:27 PM #10
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I’m not a tire installer/expert, and your results may vary, but the TireRack website says most 265-width tires are meant for 7”-8.5” wide rims.
ads2539 is offline   Reply With QuoteReply With Quote
Old 04-07-2020, 05:59 PM #11
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
Yeah, running a 9" wide rim is definitely going to give the sidewalls a stretch. They're going to be either perfectly vertical or perhaps bowed a smidge (where the rim face if flush with the tread edge, or even protruding further out).
I have a 285 on a 9" wide rim, and it's very "square". I really prefer the rim face to be sunk in slightly into the tire (a 305 wide tire would do this nicely on a 9" wheel).
I don't think this would be an issue for mounting... it just might not be aesthetically pleasing, but taste and mileage may vary person to person.
+20 is probably high for a 9" wide wheel, that's over an inch deeper into the chassis than my wheels. I don't think there'd be UCA contact, but it certainly would invite problems. Wheels that wide should be very close to 0, or more towards -10/-12 for that real "flush" look with the fenders.
Sorry, gotta go, hope this helps
Keros is offline   Reply With QuoteReply With Quote
Old 04-07-2020, 09:18 PM #12
Originally Posted by Keros View Post
Yeah, running a 9" wide rim is definitely going to give the sidewalls a stretch. They're going to be either perfectly vertical or perhaps bowed a smide (where the rim face if flush with the tread edge, or even protruding further out).
I'd go with +1 over the +20 to be sure, especially if he's gonna upsize at any point.
I'm gonna put 295s on my 7.5s.
Old 04-15-2020, 12:50 PM #13
I think I’m going with the +20 offset. I hope it works out.
17x9 , breaker , deal , run , wheels
17x9 with 275’s help! dr3ww3rd 5th gen T4Rs 7 07-26-2019 10:08 PM
? SCS F5 17x9 ALLPRO4 General Discussions 6 06-03-2019 04:25 AM
SCS F5 17x9 T4RWARRIOR Stealth Custom Series 12 08-17-2018 12:03 AM
SCS F5 17x9 ? Kimokona Stealth Custom Series 0 01-28-2017 01:41 PM
FS: MB 352 17x9 $400 Osmith For Sale: Suspension/Wheels/Tires 1 10-16-2015 03:10 PM
