Old 04-05-2020, 02:18 PM #1
drtyjerz47 drtyjerz47 is offline
drtyjerz47 is on a distinguished road
Suspension question (I know, y'all fixen' to shoot me)
Ok, I get it, there's 647 different threads, with 9 thousand different combinations.
Honestly have I read them all, no, have I tried to read a bunch YES.
Between my shit short term memory (due to a TBI *thanks deployment*) and probably my undiagnosed ADD I have no clue what the hell it all means. I am mechanically inclined, I have tools, I enjoy wrenching, but I've never been more lost with all this.
I'm looking for an affordable suspension kit to replace the leaking XREAS in my 04 v8 SE
Want something comfortable and affordable. I found a guy with fox 2.5 with the external resi Close by for 500$ or 600$ just for the coilovers. But then I saw online something about needing UCA's and then the back isn't solved. Some one just please point me in the direction of a turn key alll in the box kit and where to buy it. Or "buy the front here, and this piece from here" so I can just move on.
Or a solid customer service rep I can talk to on the phone who won't try to bend me over
Thanks in advance
[B] 2004 Sport edition V8 Natty white-
Sold: 1999 T4R Limited Imperial Jade mica, 2017 T4R SR5P magnetic gray metallic
drtyjerz47 is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 02:28 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss will become famous soon enough rdruss will become famous soon enough
rdruss's Avatar
Real Name: Ron
I have an '03 V8 Ltd. which had xreas originally. Couple years ago I replaced it with Bilstein 4600 and FJ coils and am very satisfied with the ride, although I am strictly street. I recently installed the Daystar 1" level kit and replaced the top hats. I use the no spring compressor method and it is very easy.
If I were to do it all over again I would go with Bilstein 5100's for their adjustability so a level kit would not be necessary, or maybe the Eibach Pro's which are also adjustable.
Hope this helps a little. There are many spring combo's to choose from and that is confusing.
Old 04-05-2020, 04:47 PM #3
gimlithepirate gimlithepirate is online now
gimlithepirate is on a distinguished road
I've got an Eibach Pro Truck suspension sitting in my basement for install next weekend. If you do some googling there are places that have that setup in your price range.
That gets you eibach springs, as well as their version of the Bilstein 5100, which is valve a littler differently supposedly.
End result is 2.75" lift up front, 1"in the rear. Shouldn't need new UCA's.
2007 v8 4Runner Limited: RSG Rocksliders, Eibach Pro-Truck Lift, Falken AT3W 255/80r17, FJ Cruiser Wheels, Window Up Mod, Rola Vortex w/ low profile brackets, Off Roading Gear Awning, Inclinometer, and Cali Raised USB Charger.
gimlithepirate is online now   Reply With QuoteReply With Quote
Old 04-05-2020, 04:49 PM #4
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 is a glorious beacon of light Bluesky 07 is a glorious beacon of light Bluesky 07 is a glorious beacon of light Bluesky 07 is a glorious beacon of light Bluesky 07 is a glorious beacon of light Bluesky 07 is a glorious beacon of light
Bluesky 07's Avatar
Check out the “X-REAS delete...” post linked in my sig. The setup I ended up with is affordable and rocks both on and off the pavement. Not suggesting the same exact gear necessarily, just the same approach.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 06:54 PM #5
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 will become famous soon enough Warwicke36 will become famous soon enough
Warwicke36's Avatar
I am very happy with my setup
Front Struts: Bilstein 5100 (lowest perch setting)
Front Springs: Toytec (eibach) 2.5" spring
Rear Shocks: Bilstein 5100
Rear spring: stock spring with Daystar 2" lift spacer
Parts sourced from Amazon : shocks abd struts as a kit for $369. Daystar spacer kit $80
Parts sources from toytec.com springs $169
Also needed front upper strut mounts sourced locally for $29/ea
Suspension question (I know, y'all fixen' to shoot me)-img_20200222_124629_313-jpg
2004 Sport 4.0, Bilstein 5100s w/ 2.5" Toytec springs, TRD wheels, Falken Wildpeak AT3W tires, Gibson stainless elite, Blackout headlights with LED, DIY Grille lights, Crux Bluetooth adapter and upgraded subwoofer
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 09:08 PM #6
Derekv Derekv is offline
Derekv is on a distinguished road
I have a 2004 Sport V8. I just finished upgrading the suspension. Been off-road a few times and it handles so much better without it handling poorly on-road.
Eliminated the XREAS.
Front;
Bilstein 6112ís on the 3rd/middle setting.
JBA UCAís.
CVJ CV axles with the red inner boots
Jersybuilt hubs
SS brake lines
Speedbleeders
Rebuilt factory calipers
New rotors
Rear;
Bilstein 5160ís
Toyota FJ rear springs
SS brake lines
Speedbleeders
New rotors
I would like to get new from the and rear calipers. Something nicer than oem and painted.
Derek V
Derekv is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 11:07 PM #7
mysticz's Avatar
mysticz mysticz is online now
mysticz will become famous soon enough
mysticz's Avatar
You have to ask yourself the main question, what do you use your Runner for? Then decide what sort of setup will work for your needs and you plan to keep for a long time.
Good all around setups.
Bilstein
OME
Toy Tech
More popular for off road setups.
Fox
Icon
King
Radflo
2005 T4R Silver SR5 V6 4wd with Mods.
mysticz is online now   Reply With QuoteReply With Quote
Old 04-06-2020, 01:38 AM #8
06_dark_knight 06_dark_knight is offline
Real Name: Mario
06_dark_knight is on a distinguished road
Real Name: Mario
Bilstein
OME
Toy Tech
Fox
Icon
King
Radflo
Agreed! Youíre going to have to ask yourself this question over and over when modifying your 4Runner... and probably just as important is the question of budget. How much do you want to spend for everything?
Iíve had the 5100ís on my Tacoma I had and for what I did/needed them for it was a great set up. This time around my budget and ambitions were bigger so I went with icons and I couldnít be happier.
06_dark_knight is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 04:04 AM #9
LeMax LeMax is offline
LeMax is on a distinguished road
Hello Warwicke36, i know it s off-topic but are your Falken tires Noisy on the highway? Thanks!
LeMax is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 07:03 AM #10
Warwicke36's Avatar
Warwicke36's Avatar
Theyre silent but I can't get them to balance for sh*t.
affordable , buy , kit , read , suspension
17x 9...please don't shoot!!!! emsmatt 5th gen T4Rs 11 12-04-2016 07:43 PM
Oh shoot help ASAP!!!! Ol'Blue 3rd gen T4Rs 20 08-26-2016 03:22 PM
Lift + sway bar question (don't shoot me I did search for like 30 minutes) PWD4R 3rd gen T4Rs 40 06-22-2016 01:14 PM
Trouble shoot help konig4 3rd gen T4Rs 3 10-09-2010 08:55 PM
Photo shoot! LINY4Runner 3rd gen T4Rs 25 08-31-2009 12:40 PM
