Old 04-06-2020, 02:01 PM #1
B.E. Coyote's Avatar
B.E. Coyote B.E. Coyote is offline
B.E. Coyote is on a distinguished road
Does the 4.7 have two coolant sensors?
2004 Limited with the 4.7
Does it have two coolant temp sensors?
B.E. Coyote is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 02:20 PM #2
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
There are 2, 1 is for the ECU the other is for the temp gauge.
Round connecter is for the temp gauge. The more rectangular one is for the ECU.
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 02:29 PM #3
Is the temperature gauge always used? I can't a plug anywhere that goes to to it. There is a guage on the dash but wondering if it gets info from the ecu
Old 04-06-2020, 03:01 PM #4
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
My 2003 has the same sensor but there is no plug in the harness for it. So in this case, Toyota used the sensor just to plug the hole. The temp gauge on your dash is sharing the information with the ECU from the larger sensor.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 03:17 PM #5
Thank you! I’m hoping that is what I have going on too.
Been a bad day broke off a few valve cover bolts trying to remove them. Leaking covers and the visible ones on the bottoms broke. I’m thinking someone cranked them down to try to get the leaking to stop. Could have almost taken out the top bolts with my fingers
coolant , limited , sensors , temp
V6- coolant not siphoning back from coolant overflow (not overheating) djtc 4th Gen T4Rs 32 08-27-2021 10:13 AM
Dealer Coolant Flushed with Wrong Coolant? peebee 4th Gen T4Rs 35 07-02-2021 05:52 AM
pink coolant and green coolant Larry Maintenance/Detailing 30 11-17-2014 11:09 PM
Coolant Leak- Drivers side coolant manifold? Shibby! 3rd gen T4Rs 19 12-28-2012 09:37 PM
22RE headgasket 'reversal' - coolant in oil, then oil in coolant kompression 3rd gen T4Rs 0 09-20-2005 12:23 AM
