Is the temperature gauge always used? I can't a plug anywhere that goes to to it. There is a guage on the dash but wondering if it gets info from the ecu
My 2003 has the same sensor but there is no plug in the harness for it. So in this case, Toyota used the sensor just to plug the hole. The temp gauge on your dash is sharing the information with the ECU from the larger sensor.
__________________ 2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
Thank you! I’m hoping that is what I have going on too.
Been a bad day broke off a few valve cover bolts trying to remove them. Leaking covers and the visible ones on the bottoms broke. I’m thinking someone cranked them down to try to get the leaking to stop. Could have almost taken out the top bolts with my fingers
