Old 04-08-2020, 09:48 PM #1
thewaydown thewaydown is offline
thewaydown is on a distinguished road
Bleeding front brakes after installing new calipers?
So, I found that I had three stuck caliper pistons out of 8 on the front brakes. Went and got some remanned calipers and installed them. I unscrewed the brake reservoir cap and the bleeder and gravity bled both front calipers independently.
What next? Do I just replace the reservoir cap and pump the brakes until I see no air bubbles coming out of the bleeder screw (with hose attached, of course)? I'm assuming I can do this on both front calipers independently and not do the back, since the front have independent brake lines?
Thanks
Zayne
Sent from my SM-G986U using Tapatalk
thewaydown is offline   Reply With QuoteReply With Quote
Old 04-08-2020, 10:05 PM #2
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
Yes, bleed the brakes as you would with any car for the fronts. If you have a helper open bleeder, press and hold pedal, close bleeder, release pedal. Do this til no air. Then have helper pump pedal a few times and hold it as you slowly crack the bleeder and watch for air bubbles. Close bleeder. Repeat. Test for a good brake pedal.
If you run into anything weird, consult the many threads regarding brake bleeding procedures.
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 04-09-2020, 10:24 AM #3
Derekv Derekv is offline
Derekv is on a distinguished road
Or get speed bleeders and bleed them without a heLper.
Derek V
Derekv is offline   Reply With QuoteReply With Quote
Old 04-09-2020, 12:37 PM #4
Ah yeah I remember reading about those.
Are these the same thing?
https://m.autozone.com/parts/brakes-...4aAhShEALw_wcB
Anyone have any experience with these particular ones?
Old 04-09-2020, 01:44 PM #5
Warwicke36's Avatar
Warwicke36's Avatar
Yes, I used dorman speed bleeders when I did my brake lines a couple weeks ago. They're great. If you go to the "what did you do to your 4runner today" thread I have a write up and follow up within the few pages of the thread. Disussing sped bleeding.
2004 Sport 4.0
Old 04-09-2020, 02:01 PM #6
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Bleeding the rears was really weird... it's got some type of booster pump that keeps the flow constant.
Careful not to let the master go dry.
Old 04-09-2020, 03:29 PM #7
djpope09 djpope09 is offline
djpope09 will become famous soon enough
My understanding is that the rears use the abs pump so all you have to do is turn the key on, open the bleeder and press the brake and the abs pump will do the work for you. Definitely agree, don't let the reservoir empty out while you're doing it.
djpope09 is offline   Reply With QuoteReply With Quote
brakes , calipers , cap , front , reservoir
DIY: Front Brakes (Rotors, Calipers, Pads, and Lines) with pics 46runner Maintenance/Detailing 7 03-28-2018 10:30 PM
Need help with replacing front brakes/rotors/calipers ddicosmo 4th Gen T4Rs 19 02-25-2017 02:36 PM
Installing Drilled and Slotted front brakes... NorcalGPS44 3rd gen T4Rs 15 12-14-2013 12:19 PM
WTB SoCal: 3rd gen OEM front brakes/calipers for 15" wheels ryhi Want to Buy/Trade 0 06-15-2013 10:05 PM
Tips on bleeding front brakes. Teqeeler 4th Gen T4Rs 6 02-22-2013 12:55 PM
