Originally Posted by eleven14
Same boat, but with the door handles (FYI bug spray and sunscreen dissolve the finish).
That's a pretty big expanse to try and touch up, if I were you I'd be tempted to pull that piece, lightly sand and re-spray.
I won’t ask how you know that lol, but will keep that in mind next time I clean mine. I know bug repellent is some nasty stuff. We use it (bug off) at work to wipe off permanent black marker on our ID tags and wipes off/dissolves like nothing.
I was thinking a touch up pen or paint marker. Maybe I’ll look at the testors model Silver metallic paint marker. I’d considered having it hydro dipped in a carbon fiber, but my OCD would make me do all the Siler trim pieces. Not that it’s a bad thing but since it’s my daily driver I’d be without it and couldn’t afford to have it lost or damaged in transit.
The silver metallic Sharpie isn’t a bad idea either. I’ll check them out also. Definitely couldn’t look any worse, only would improve, especially with a little blending.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
