Old 04-09-2020, 01:10 PM #1
Jacobzky's Avatar
Jacobzky Jacobzky is offline
Jacobzky is on a distinguished road
Jacobzky's Avatar
Rear Sway Bar Bushing install question
Do you need the rear jacked up just to replace the rear sway bar bushings?
Jacobzky is offline   Reply With QuoteReply With Quote
Old 04-09-2020, 02:52 PM #2
jacob7071 jacob7071 is offline
jacob7071 is on a distinguished road
No. You may need to disconnect the end links though
Houston, TX - 2007 2wd Limited Build Thread
Dobinsons 296/220 front and 505/705 rear, Graphite Tundra split spokes, 5th gen Tube Running Boards
Sold '02 Sport Edition
jacob7071 is offline   Reply With QuoteReply With Quote
Old 04-09-2020, 05:13 PM #3
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
I did mine a few weeks ago, and I had to remove the wheel, jack up the truck, as well as place a second jack under the rear axle to push the sway bar up for the driver side. The passenger side was easy to do while the truck was on the ground with no jacks. 2008 SR5 4WD.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 04-10-2020, 12:10 PM #4
JCTanner's Avatar
JCTanner JCTanner is offline
Real Name: JT
JCTanner is on a distinguished road
JCTanner's Avatar
Real Name: JT
I did mine on the ground. (2008 V8) But it was a PITA. Really tight and tough to get leverage on a wrench at times.
Would of been much easier if it was on stands.
2008 4Runner V8 4x4 Sport Edition
JCTanner is offline   Reply With QuoteReply With Quote
Old 04-10-2020, 05:21 PM #5
terminal4's Avatar
terminal4 terminal4 is offline
terminal4 is on a distinguished road
terminal4's Avatar
It's recommended, good install video--> https://www.youtube.com/watch?v=sSuNjEZX6Dc&feature=youtu.be
terminal4 is offline   Reply With QuoteReply With Quote
Old 04-10-2020, 06:20 PM #6
P_nlsn's Avatar
P_nlsn P_nlsn is offline
Real Name: Parker
P_nlsn has a spectacular aura about P_nlsn has a spectacular aura about
P_nlsn's Avatar
Real Name: Parker
I replaced mine while it was on the ground and it wasn't too bad. I would imagine it's a little easier without the tire to work around though. Lift size, tire size, and wheel spacing probably slightly changes the difficulty per person too
4wd V6 '03 Sport w/ 340k miles (175k engine swapped @ 326k) // 3" Suspension Lift + 3" Body Lift on 35" K02's
@toto.runner // Build Thread // Engine Swap Write-Up
P_nlsn is offline   Reply With QuoteReply With Quote
Old 04-11-2020, 11:52 AM #7
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
As others have said, it can be done on the ground.
The sway bar is a big spring with 4x connection points. When there's pressure on one of these connection points it's gonna be a real bugger to work loose or put back on.
Taking the tension out of the spring by having all 4 points inline would likely make the job a lot easier. As jacob7071 said, disconnecting the endlinks will make everything a lot easier as that's now just a pipe going through some bushings on the axle.
My rear sway bar was rusted onto the truck... tension or not, it was a bugger to get off.
Keros is offline   Reply With QuoteReply With Quote
bar , bushing , install , rear , sway
Sway bar bushing install - Broken frame thread insert Will816 4th Gen T4Rs 22 06-03-2021 08:27 PM
Rear Sway Bar Bushing Bracket Install ScarfaceT4R 5th gen T4Rs 15 03-10-2021 12:54 PM
sway bar link bushing question jayk2k3 3rd gen T4Rs 7 11-01-2019 12:08 PM
Question about sway bar bushing bolts Jimbo03T4R 4th Gen T4Rs 16 12-26-2016 05:48 PM
Successful Front & Rear Sway Bushing Install treverd 3rd gen T4Rs 1 07-22-2016 04:53 PM
