Originally Posted by pauldub
It's very possible that your lean is caused by a front spring being too soft, especially if it takes an 1-1/2" spacer in the rear to make it level.
I'm gonna agree with this concept. All things being equal, the springs should be the same size and lift equally. If your rear end is shorter on one end there is something else amiss. I'd eliminate everything else before putting spacers in.
If it were my car I'd rule out every stupid thing I could think of. Realistically, I don't think the axle is somehow bent, nor do I think the mounting points could be jacked up, but check them out just for kicks. What about the sway bar and links? Confirm both links are correct and that somehow a longer one didn't somehow get installed or some other stupid thing. Again, rule everything out that you can in the rear and then look at the front.
If nothing else measure the distance from the axle to the ground on both ends and the distance from the spring seats to the body mount without the shocks and springs. I know it'd be a huge pain to remove the springs and everything, but you'd have to do it to confirm where the problem is. I'm getting repetitive but there's gotta be something going on to cause that lean.
