Originally Posted by FoRunin
I know what you meant , but how does tire tread matter when I'm measuring from the center hub to fender. When I'm talking about it leaning I mean visually from the front not looking in at the wheel gap.
And when I say thread I mean the thread showing on the king coil overs. I'm just interested in any idea why my passenger side would sit so low in comparison as I had to crank that coilover more just to get somewhat level.
It's all relative. Let's say the tread on one of your tires is half an inch lower than the rest of the tires, that may contribute a slight imbalance. Same with your tire pressure.
Also, do you have a sub or anything else heavy on the passenger side?
Finally, maybe the oil or nitrogen level is off on that one side. The simplest way to test this is to swap the driver and passenger side coilovers to see if the same thing happens on the driver side.
