Old 04-17-2020, 03:04 PM #16
jsimms243 jsimms243 is offline
Real Name: Justin
jsimms243 is on a distinguished road
Real Name: Justin
Originally Posted by 72W442 View Post
I was able to break them loose from under the vehicle with a 1/2 breaker bar 14mm I think, just to get them started, they were tight but no rust and i am in buffalo ny.
72W442 just wanted to get your thoughts on how to used the breaker bar to remove the starter bolts. You went from under, right? Did you have to remove the drive shaft or exhaust? Any other detail to can provide? I'm really hoping to not have to remove these if it's possible.
Thanks.
jsimms243 is offline   Reply With QuoteReply With Quote
Old 04-17-2020, 03:47 PM #17
djpope09 djpope09 is offline
djpope09 will become famous soon enough
When I took my starter off, I removed the wheel and used a few extensions/u-joints to get to the bolts. I would jack that side of the front up and go at it through the wheel well with the breaker bar.
I tried a big earthquake impact (rated for 1200 ft-lbs) to get the crank bolt off one time. My experience is that they don't have as much torque as advertised. The earthquake didn't work and I used a breaker bar and the whole handle from my jack as a cheater bar to get it off.
djpope09 is offline   Reply With QuoteReply With Quote
Old 04-17-2020, 05:44 PM #18
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Originally Posted by jsimms243 View Post
I did spray it down with PB Blaster the other day, so we can check that off the list.
Originally Posted by y=mx+b View Post
I'll update for OP if the aft/acetone mix works on these bolts, could help to free up the starter bolts
Update that on the rusty skid bolts. I broke 2 bolts the other day that I had pretreated 2 days prior by spraying with pb blaster. I whipped up the atf/acetone mix yesterday and soaked the bolts in it. Today I came back out to try the atf/acetone bolts and they came out. Both the pb and atf/acetone bolts were torched and hammered.
OP, I think the atf/acetone really worked, so I would give it a try as well. I've also been using a propane torch, heating up the bolts, then wacking with a hammer. Have you tried heat and hammer?
Admittedly I've never done the starter removal before, but I found this video for the here: Starter Removal and Solenoid Repair. 11:05 is where he removes the starter. I know its for 3rd gen, but 1gr-fe starters are also on the side of the transmission, so a similar technique could be used. You mentioned not enough room to get leverage on the beater bar, looks like hes using a bunch of extensions and a U joint to get the breaker bar out behind the transmission. Maybe a soak the bolts the day before, torch them for a bit, hammer directly on head if possible, then try a bunch of extensions to bring the breaker bar into a manageable space.
y=mx+b is offline   Reply With QuoteReply With Quote
Old 04-17-2020, 08:26 PM #19
72W442 72W442 is offline
72W442 is on a distinguished road
I did it from underneath with a craftsman 1/2 breaker bar and a 12 point socket had just enough room to break them loose a little
72W442 is offline   Reply With QuoteReply With Quote
bolts , budge , click , problem , starter
Tie Rod End wont budge TurtleAdventure 3rd gen T4Rs 16 10-10-2017 10:09 AM
FS Budge Industries Cover 4Runner Glock1985 For Sale: T4R Items 1 06-04-2016 01:01 PM
Starter Bolts 4runmak 3rd gen T4Rs 5 10-22-2015 08:29 PM
Installing bull bar, factory bolts won't budge Locombiano 3rd gen T4Rs 8 01-17-2012 11:40 PM
87 T4R: liftgate won't BUDGE...please help! Philbert Classic T4Rs 4 04-11-2008 05:13 PM
