Real Name: Skip
Real Name: Skip
I would guess maybe the switch is going bad, or whatever it is that makes the servo stop when closed is going bad, that could be something in the servo or maybe something on the door, either way at some point it could make the servo die, or not.
So you could replace one or the other and if it solves the issue you're good to go if not then replace the other, or just wait until it doesn't work at all and try and fix it.
2004 Limited V8
