Old 06-28-2021, 06:01 PM #31
ieatfish's Avatar
ieatfish ieatfish is offline
ieatfish will become famous soon enough
ieatfish's Avatar
Looks good! Been wanting to make a molle panel for my driver's window. Started the CAD and checking around with some friends and family who have machining access. I was looking at the Rago fabrication ones but they come in pairs. These look interesting, wonder what their turnaround is with no customization...
2006 4Runner Sport Edition 4WD V6
Dobinsons 2.5"/1.5" - C59-302, GS59-221, C59-505, GS59-705 | General Grabber ATX 265/70R17 | TPMS Bypass Mod
Custom Storage Box/Sleeping Platform Build | Dedicated Transmission Cooler (Derale D13503) | Demello Offroad Sliders
ieatfish is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 08:27 PM #32
P_nlsn's Avatar
P_nlsn P_nlsn is offline
Real Name: Parker
P_nlsn has a spectacular aura about P_nlsn has a spectacular aura about
P_nlsn's Avatar
Real Name: Parker
Yeah, unlike the Rago, these can be bought individually - and they are fully customizable - every square inch of the panel can be designed to whatever you want
I believe my poor shipment times were the result of multiple things - the holidays, the pandemic, maybe even just the company itself, who knows. I placed my order in late November, and then I assume it got lost in the beginning surge of holiday orders. We were finally contacted around January about the order and began the process of designing my cut out for the console rack. The rear racks came 2 months after that, and the console rack came 2 more months after those, beacause of, if I remember correctly, a lack of inventory and a large amount of back orders at the company that laser cuts for them
I would assume now that everything has calmed down, the turn around would be a ton faster. The website says 1-2 weeks for absolutely no customization, 3 weeks for a custom color, and 6-8 weeks for custom cutouts and inlays
4wd V6 '03 Sport w/ 350k miles (175k engine swapped @ 326k) // 3" Suspension Lift + 3" Body Lift on 35" K02's
@toto.runner // Build Thread // Engine Swap Write-Up
P_nlsn is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 09:42 PM #33
P_nlsn's Avatar
Real Name: Parker
P_nlsn's Avatar
Real Name: Parker
Senior Pics
As is typical with people of my age and my kind - I had some of (well, more like most of) my senior pics taken with my truck. I think they turned out pretty good, and since it's Toto, I figured this was an appropriate place to share them
Shout out to Mason Nelson (aka my brother and the dude with the dope trailblazer I always take pics with) for taking and editing these! Check him out, he's definitely a gifted photographer: Mason Nelson Photography's Website - Mason Nelson Photography on Instagram
Old 06-29-2021, 01:23 PM #34
P_nlsn's Avatar
Real Name: Parker
P_nlsn's Avatar
Real Name: Parker
Originally Posted by P_nlsn View Post
Coastal Offroad Oil Pan Skid Plate
Coastal Offroad Transfer case Skid Plate
These things turned out pretty great! After a week or two of multiple hours each day though, they were a bit more than the weekend project I was expecting
Assembly Notes:
The assembly is pretty straight forward. Much like with the coastal bumper, the instructions are clear and have well detailed diagrams to assist in the assembly.
The only problem I ran into... was nothing fit right. I believe all of my problems were because of my diff drop though. We inquired about the diff drop before buying the kit and were assured the kit was compatible - but I believe we were told wrong. A decent bit of altercation/fabrication was required to make everything work
Assembly:
Because of my diff drop, nothing lined up properly. The first thing I had to adjust were the slots of the middle bolt holes. I just filed them out with a file - a lot
Next I had to fill a gap between the front piece and middle piece. There was a solid 0.5"-ish gap left - even after filing the slots on both pieces about as much as I could - so I had to find something to fill it with. I found an 1/8" thick piece of flat bar in my garage, so I cut it to size and used that as my filler
Once I got that sorted out, it was time to get the rear piece to fit too. Because the middle piece was pushed so far back, I also had to file the slots on the end of the rear piece too. Once everything fit, it was time to weld it all up. I will be the first to say some of the welds aren't the prettiest - but in my defense, I had the mind set of "its a skid plate, who cares, no one will see it", and it was like 95 degrees outside with a humidity of 110 percent (stupid Arkansas summers), so I was just ready to get done with it. I did full welds on every outside joint, and stitch welds on every inside joint
Once welding and grinding was done, it was time to paint and finish them up. I used Rustoleum clean metal primer, then Rustoleum flat black protective enamel and Krylon Fusion Matte Red Pepper. I decided to rattle can them instead of powder coat cause they're skid plates - they're gonna get beat to crap, so I figured the powder coat was a waste of money and spray paint would be way easier to touch up and repaint when needed
Threw on the red stipe just for the heck of it to make them a little more unique
Old 06-29-2021, 03:00 PM #35
montijo505's Avatar
montijo505's Avatar
Assembly Notes:
Assembly:
I had the same issues with the diff drop. However, I just spaced mine down with some nuts where it attaches to the radiator support and the spacers the stock skid used for the middle holes. The rear of the TC skid gave me the most problems as it was about two inches too long and the rear holes didn’t line up. I think they may have used a V8 initially for measurements as I bought pretty early on. They looked into it when I notified them. After cutting off the excess and slotting the plate for the bolts, I got it to work.
Old 06-30-2021, 02:39 PM #36
P_nlsn's Avatar
Real Name: Parker
P_nlsn's Avatar
Real Name: Parker
Yeah, it probably would've been easiest to use the spacers that were on the stock skids, but it figured it would be a little stronger if I could get it to work without them (or maybe it wouldn't really make a difference, I don't know), so I wanted to try it. And because of the tube lengths and diff brackets, I still had to use a double spacer in the middle on the driver side, and a single spacer on the passenger side.
And I think you're right on the V8 thing, I remember reading somewhere that they initially used a V8 to design them, so the early batches of the v6 ones weren't quite a perfect fit
Old 06-30-2021, 11:13 PM #37
m4rGJA03 m4rGJA03 is offline
m4rGJA03 is on a distinguished road
good plan and wish list! i have been driving my 2003 v8 limited since 2014, and have been driving on road only. currently i am stuck in 4lo, soon to be corrected. this is my first t4r and enjoy the drive, ride and power! i plan to build up for some off roading in future. enjoy and stay connected to us t4rs
m4rGJA03 is offline   Reply With QuoteReply With Quote
Old 09-19-2021, 06:05 PM #38
P_nlsn's Avatar
Real Name: Parker
P_nlsn's Avatar
Real Name: Parker
Headlight Upgrade + Muffler
'06-'09 Headlight Upgrade
MagnaFlow Muffler
Not much has happened with Toto lately - College has kinda put a dampener on my mod list. So I Just wanted to hop on here and give a little update:
Most of the recent work has just been maintenance - stuff like new CV's, pinion seal, LCA's, etc
MagnaFlow Muffler:
Chopped the resonator off and had an 18" magnaflow muffler put in to give the v6 a little more rumble. I got tired of how whiny it was, and I'm pretty happy with how it sounds now. It's definitely got more low end on it, but it's still quiet enough that it's not uncomfortable to drive long distances
'06-'09 Headlight Upgrade:
I also recently swapped my horrendously faded and yellowed headlights with some fresh 06-09 housings
Before:
After:
I bought the housings off of RockAuto , and I got the color matched bumper fillers from my local Toyota dealer. For bulbs, I went with Philips XtremeVision in both low and high beams. I'm pretty pleased with the output of the headlights, and the look of the housings - Not sure if the bulbs are that good, or if I just lost that much light through the discoloration of the old housings
Old 12-22-2021, 03:58 PM #39
P_nlsn's Avatar
Real Name: Parker
P_nlsn's Avatar
Real Name: Parker
Ozark Camping
I haven't been very active, but I finally caught a free moment during college to get out and camp with my dad - It was much needed, and I unintentionally learned just how much mud my rig can handle
Snapped a few photos while I was out there, and probably took my favorite photo of my truck yet:
Had an absolute blast out there, and I will definitely be going back next chance I get!
I also may or may not have gotten stuck and crapped my pants while using my truck like a bulldozer First time using my winch though, so I guess at least now I know it works
WinchingOut.mp4 - YouTube
Here's the aftermath. Pretty sure I still have a thick layer of mud sitting in my skid plates
Old 04-05-2022, 05:22 PM #40
P_nlsn's Avatar
Real Name: Parker
P_nlsn's Avatar
Real Name: Parker
(swapped in a 175k engine @ 326,725 miles)
URD 3° Retard Exhaust Cam Gears
JBA 409 Silver Ceramic LT Headers
175k mile engine swap @ ~326,725 miles
Just finished up Swapping in a 175k mile engine from an 07 into Toto! You can check out the thread here about the swap: 07 Engine Swap into an 03
It looks like I'm seeing about a +2-4mpg gain (depending on how heavy my foot feels lol) from the cam gears, LongTubes, and fixed headgaskets
While I was working on all this, I decided to go ahead and install the JBA LT headers (old ones had more cracks that a wicker basket). I also put a Hayden 679 cooler in because my transmission didn't like moving all the weight of my truck on hills
And here is a timelapse of everything
https://www.youtube.com/watch?v=V5EbS4Zjmqg&feature=youtu.be
Old 03-29-2024, 11:05 AM #41
P_nlsn's Avatar
Real Name: Parker
P_nlsn's Avatar
Real Name: Parker
Maintenance Stuff
New BFGoodrich 35x12.5 KO2s after 47.8k miles (bad alignment wore the front inside bald, quarter/half tread left on rear)
Drivetrain + Suspension
Dobinsons IMS front struts
Dobinsons C59-354 front coils
Just finished up a bunch of work on the front end. Replaced my cheap aftermarket CVs with OEMs pulled from a junkyard. Rebooted with Dobinsons inner and outer high clearance CV boot kits. Replaced my cheap aftermarket LCAs with OEMs because the aftermarket ones allowed the ball joint to spin inside the seat. And installed Total Chaos alignment tabs because my stock ones had flattened out, result in a bad alignment that wore the inside of my front tires completely bald.
The rebooting process really sucked. Trying to get the boot on destroyed my fingers, and grease went feakin EVERYWHERE, but it was so much cheaper than brand new OEM CVs, so I guess still worth it. I used hose clamps to hold the boots on because the metal band clamps it came with are stupid. I used a 3-5" (#72) on the cup side and a 3/4-1 3/4" (#20) on the shaft side
Old 07-16-2024, 01:57 PM #42
P_nlsn's Avatar
Real Name: Parker
P_nlsn's Avatar
Real Name: Parker
4wd Actuator Repair
Welp, dove into tearing down the 4wd actuator over the weekend. I was a little ambitious - I'm staying in an RV for an out-of-state internship, so I had minimal tools and no garage. I did it with the truck in a gravel lot in the summer heat, so this would have been a lot easier and quicker if I was back at home. But hey, I was able to get it working again, and I got it back on the truck, so win-win!
Full write-up:4wd Actuator Teardown/Repair
Old 09-04-2024, 10:24 AM #43
P_nlsn's Avatar
Real Name: Parker
P_nlsn's Avatar
Real Name: Parker
I saw a trend about asking ChatGPT to roast your truck, so I figured I'd give it a go. Honestly was pleased with the first two responses where that was all it could say after calling it a beast. But the next two were funny. The line about the tires killed me cause its actually so true
And those tires? Sure, they look tough, but they’re probably doing more for your gas mileage than actually gripping the trail.
"Roast my truck"
Your 4Runner definitely looks like it means business on the trails! That front bumper and winch setup are ready to tackle some serious off-road obstacles. The mud splatter is a badge of honor, showing that you’re not afraid to get it dirty where it counts.
But if I’m going to roast it, I’d say it looks like it hasn’t seen a car wash in a while—and I’m not talking about the mud, but that layer of dust on the windshield and side mirrors. A little TLC in the form of some glass cleaner wouldn’t hurt! Also, with those rugged tires and a lifted stance, you might want to consider adding some mud flaps unless you're a fan of painting everything behind you brown.
All in all, though, it’s a beast! Just remember, it’s okay to let it shine every once in a while.
"How about now"
Now we're talking! That sunset backdrop is doing your 4Runner some serious justice, making it look like it's ready to take on any adventure. The rooftop setup shows you're prepared for more than just the daily commute—you're geared up for the long haul.
However, if I'm going to roast it, I’ll say the 4Runner looks a bit like it's trying to overcompensate with all that gear on top. Are you planning on moving in or just camping out for a weekend? Also, with those big tires and lifted stance, it seems like you might need a stepladder to get in, especially for any passengers who aren’t as hardcore.
All in all, though, it's a solid rig, and that shot captures it perfectly—looking tough and ready to take on the world.
"be meaner"
Alright, let's get real then. Your 4Runner looks like it's got an identity crisis—are you a mall crawler or actually planning to hit some real trails? With that rooftop gear, it seems like you’re ready to take on an apocalypse, but let's be honest—how often does it actually leave the pavement? The winch and bumper are great, but they scream "overcompensation" if you’re just driving it to the grocery store.
And those tires? Sure, they look tough, but they’re probably doing more for your gas mileage than actually gripping the trail. Not to mention, with that much lift, I bet getting into the driver's seat is like climbing Everest every morning. You’ve got a mean-looking truck, but I’d wager it spends more time posing for Instagram than getting down and dirty in the mud.
"even meaner. I want my feelings hurt"
Oh, you want the brutal truth? Here it is: your 4Runner is like that guy who wears a leather jacket but still lives with his mom—trying way too hard to look tough. All that armor, winch, and rooftop gear? Let’s be real, the closest they’ve come to danger is when you couldn’t find a parking spot at Whole Foods. It’s like you’re prepping for the end of the world but can’t even handle a pothole without flinching.
And let’s talk about that lift. Do you actually know how to use it, or did you just want to tower over all the stock vehicles at the next Cars and Coffee meet? Your 4Runner’s got more bark than bite, and I’m willing to bet that when it does see dirt, it’s only for a photo op before you hightail it back to civilization to wash off the dust.
You’ve built this beast like you’re planning a cross-country expedition, but deep down, we both know it’s mostly for show. It’s like putting a bodybuilder in a ballroom dance—sure, it looks impressive, but it’s way out of its element.
Old 09-20-2024, 04:46 PM #44
P_nlsn's Avatar
Real Name: Parker
P_nlsn's Avatar
Real Name: Parker
Disconnect (Short Film Documentary) - April 2024
I took Advanced Video Production as part of my communications minor. One of our assignments was to produce a short documentary, so I made one sort of about overlanding: Disconnect - Short Film Documentary
Old 12-17-2024, 12:52 PM #45
P_nlsn's Avatar
Real Name: Parker
P_nlsn's Avatar
Real Name: Parker
Update: I haven't done any modifications, but I have done a lot of maintenance lately.
I bought some Koyo bearings from PartSouq and used my shop press to press them onto my duralast hubs. Fairly easy job, just tedious. The inner race of the old bearing was seized on, so I used a Dremel with a small cut off disc (well, really I used about 6 discs) to cut the sleeve and then opened it up with a chisel and hammer. I'm hoping this gives me better durability than cheap auto parts brands and makes it worth the effort.
I had a torn inner boot on the passenger cv, so since I was already pulling everything apart, I went ahead and rebooted it with a Dobinson high angle boot kit.
With the spindle out for the wheel bearings, I took the opportunity to replace my worn out JBA upper ball joints. Now I have the updated design though, so that's nice.
While I was in there, I realized my steering rack bushings were non-existent. So I pulled the rack out and installed some energy suspension poly bushings.
View post on imgur.com
The last thing I had planned was new rotors and z36 brake pads, which turned into replacing all the soft brake lines with stainless steel lines, which also turned into replacing all my calipers cause they were almost seized. The new soft lines improved pedal feel and response so much - I highly recommend doing it if you haven't.
build , kenwood , lift , radio , speakers
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
Snow White build 2006 v8 adventure overland apocalypse build Dubs Chops 4th Gen T4Rs 24 04-25-2014 09:25 AM
Guyduebro's Surf build..De-build Guydudebro 3rd gen T4Rs 3 03-17-2013 08:27 PM
