Old 04-27-2020, 06:47 PM #31
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
Originally Posted by spdrcr29 View Post
Aside from swapping the coils and injectors to another cylinder and seeing what happens, i'm going to go out on a limb here and say its possible that you have a head gasket problem and a small amount of coolant is getting into at least one or both of those cylinders. Do you notice the misfire at cold start up at all? After driving it for a while, you can pull one or both of those plugs and look for any steam coming out. You might have to hold a mirror over the plug hole when doing this. Something else you can do is drive it for a while and then park it overnight. Pull either #1 or #2 plug or both and use a borescope to see if you can see any traces of coolant on top of the pistons. Good luck finding the issue!
Thanks for your help. It's not the head gaskets though. I was on the interstate when it started and I stopped at an Advance Parts store and bought a tool set and moved the coils around to different locations and nothing changed, (the misfires stayed on 1 and 2). I also pulled the plugs and they were worn some but no sign of coolant or oil or anything. They looked perfectly normal, just worn from age. I went ahead and replaced the ones on the passenger side. I didn't do the driver's side since I was working with very poor tools and in the parts store parking lot. I continued home which was between 150-200 miles. It only misfires under load so I drove in 4th gear and kept the rpms up a little and was able to limit the misfires. Through all of that it never heated up, steamed, or showed any signs of head gasket failure. The coolant level didn't move at all either. Anyway, I haven't had a chance to work on it since then because I'm hunkered down in our mountain vacation place which is about 300 miles from home. Once I get home I'll start back on it and I'll probably call Identifix and see if they can help. Thank you again for taking the time to reply.
importman is offline   Reply With QuoteReply With Quote
Old 04-27-2020, 06:49 PM #32
Real Name: Danny
Real Name: Danny
Originally Posted by Bptbd View Post
I am glad I am not the only one having this issue with the 4.0 engine. I am working on a 2005 4Runner Sport V6 4 Wheel Drive. This has been ongoing for 8 months already. Change something and it is good for a couple of weeks. Then back to same issue. It first started out around 40 mph under load and now it is hesitating at other speeds. The engine light has not been coming on again since the throttle body was replaced about 2 months ago. The hesitation at times is not too bad and at others it's bad. If anyone has suggestions and/or if you come up with solution please let me know. Thanks in advance.
I'll be sure to let you know as soon as I get it straight.
Old 04-28-2020, 09:48 AM #33
spdrcr29's Avatar
spdrcr29 spdrcr29 is offline
spdrcr29 is on a distinguished road
spdrcr29's Avatar
No problem! When comes to hard to diagnose issues, i sometimes like to think outside the box when "everything else as already been checked" but still having issues. Not saying that my outside the box thinking is always correct, because i'll be the first to admit that I don't know it all. Sometimes just thinking differently about how to diagnose issues can end up helping to solve the problem. Well, hopefully you will figure it out soon and be sure to let everyone know what you found!
spdrcr29 is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 06:28 PM #34
Real Name: Danny
Real Name: Danny
I will definitely let everyone know once I get it figured out. Thanks again for your help!
Old 04-28-2020, 06:54 PM #35
Bptbd Bptbd is offline
Bptbd is on a distinguished road
Thank you. It is greatly appreciated. I keep saying the car is possessed or something.
Bptbd is offline   Reply With QuoteReply With Quote
Old 04-26-2023, 03:22 PM #36
Rockyc Rockyc is offline
Rockyc is on a distinguished road
Hi, I’m having the same problem, random misfire...I turn the engine off (in neutral) then start it up on the fly, and the misfire goes away for a bit, did you solve the mystery?
Rockyc is offline   Reply With QuoteReply With Quote
Old 04-26-2023, 06:07 PM #37
djpope09 djpope09 is offline
djpope09 will become famous soon enough
I'm impatient so I dug through importman's thread quotes and found that his issue was a bad spark plug, see post #4 here:
Having Misfire codes P0300,P0302, P0303
djpope09 is offline   Reply With QuoteReply With Quote
Old 04-27-2023, 11:44 PM #38
Bleu62 Bleu62 is offline
Real Name: Clay
Bleu62 is on a distinguished road
Real Name: Clay
Much smarter people have had some good ideas on this thread so far. I hope I’m using the right terminology. Aren’t there 2 filters, a 14 mm bolt just by the #1 and #2 cylinders? I think it’s the vvti filters but I’m going to have to dig into my fsm to verify. Could those be affecting this somehow? To be honest I’m not sure what they do completely.
Just checked. It is the variable valve timing oil filter. Not too sure if it could be the issue but depending on the mileage and since it’s fairly new to you, maybe the po wasn’t the best at oil change intervals? Anyway looks easy enough to clean and reinstall. Im sure you have the info at hand, sorry for not providing the information here.
Bleu62 is offline   Reply With QuoteReply With Quote
Old 05-01-2023, 12:04 PM #39
Real Name: Danny
Real Name: Danny
Thank you for posting this. Until this minute I didn't realize I never posted the conclusion to this. My apologies to everyone. I always try to make sure I let everyone know what the problem was. (And I talk crap about people who don't). Again, I'm sorry I left everyone hanging. To see the answer, go to the link djpope09 so graciously posted above.
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
master , misfire , misfiring , tech , time
Misfire Problem - Could use some help mtbtim 3rd gen T4Rs 126 05-09-2020 01:41 PM
My weird problem - help! 4runner316 Classic T4Rs 15 06-02-2010 11:34 PM
Misfire problem on 2004 V6 Skyline 4th Gen T4Rs 2 09-19-2009 03:09 PM
Transmission/Misfire Problem GamecockRooster 3rd gen T4Rs 6 05-01-2008 12:31 PM
'99 SR5 hesitation & misfire; dealer can't locate problem bsackamano Problems & Warranty Issues 3 09-27-2005 10:29 PM
