Old 04-18-2020, 10:13 PM #1
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
Half inch difference in tire diameter
Just upsized tires on my 4runner. However, I have discovered the only thing more difficult than finding 5 FJ Cruiser wheels is finding 1 so I can rotate it in...
One of the options I've considered is getting a different sized spare. A 265/70/18 is only half an inch or less smaller than my normal tires... However, I keep reading that's a bad idea because of the center torsen diff.
How close do the tire diameters need to be?
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 04-18-2020, 11:02 PM #2
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
I think you'll be ok for a short trip - your current sire size is 33.1, the stock looks like ~32.6. Knowing the tire's manufacturer would give you a more accurate measurement.
.5" i think would be ok for short distances (to patch, etc) until you find a spare. Fitting that spare underneath though...
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 04-18-2020, 11:51 PM #3
ProjectKing's Avatar
ProjectKing ProjectKing is offline
ProjectKing is on a distinguished road
The axle diffs are what have to rotate more due to different size tires. I’m not sure it has any effect on center diff.
Center diff operates when vehicle is in turn because from and rear axles are turning at different rates.
I don’t think a half inch will matter.
ProjectKing is offline   Reply With QuoteReply With Quote
Old 04-19-2020, 10:19 AM #4
Yeah, I gave up on fitting the spare when I went to the big tires. It ain't happening.
The reason I'm concerned is with such a weird tire size, most of the time I'm not going to be able to drive to the closest tire shop and get one. That could mean a not so short trip on the spare.
If I'd been able to find another FJ cruiser wheel for something closer to what I paid for my other 4x, I'd probably just bite the bullet and do the 5 tire rotation. However, I will probably pay half of what I paid for 4x to get a 5th! Just seems a little crazy.
A spare is ~120$ and fits my old limited wheels. A matching wheel and tire is going to be ~330$. If that's the cost of wheeling, its the cost of wheeling, but I wanted to make sure its not a case of being overly cautious.
Old 04-19-2020, 03:55 PM #5
L8Shift's Avatar
L8Shift L8Shift is offline
L8Shift will become famous soon enough L8Shift will become famous soon enough
L8Shift's Avatar
OT - I run 285/70-17 and have a 255/75-17 for the spare. Fits underneath without hitting the pan hard on my V8. 1/2" diameter difference between the two.
If I need to use the spare, temporarily, I would air down the other 3 tires.
I don't drive enough to rotate in 5 tires.
I would want a new set sooner in my case.
2007 T4R Sport V8 4WD, 145K, Seat Warmers, Pioneer NEX
2007 T4R Limited V8, 4WD, 181K, OME 2"
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
2006 T4R Limited V8 - R.I.P.
L8Shift is offline   Reply With QuoteReply With Quote
Old 04-19-2020, 09:56 PM #6
OzarkRunner's Avatar
OzarkRunner OzarkRunner is offline
OzarkRunner is on a distinguished road
Here's some previous input on the subject - https://www.toyota-4runner.org/2606354-post4.html. Recommendation was 3~4/32".
2008 Sport / V8 / Bright Silver FN FX Pro / 255/75 Duractracs / Fox 2.5" Factory Front Coilovers / JBA / Superpro / Fox 2.0" Rear / Wheeler's T12 / Limited Grill / Rigid Duallys / Flowmaster 70 Series / ScanGaugeII on Blendmount / 5k LEDs / Homelink Upgrade
OzarkRunner is offline   Reply With QuoteReply With Quote
Old 04-20-2020, 10:13 AM #7
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
i have the fj wheels x4 and run a mismatched 255/75/17 fullsize spare on a tire carrier and steel 17". itll be tough to find the single FJ i think...theres a lot of 255 75 17 from jeep takeoffs used on craigslist...maybe you could grab one of those and itll be close to your 255 80s...find a spare 17" steelie like i have for it and you should be fine until you fix your main setup. just wont have the matching 5 for rotations. also, 255/75 and i thought 255/80 can fit in stock spare location, with a bit of air deflated from it im pretty sure.
hinmo24t is offline   Reply With QuoteReply With Quote
Old 04-20-2020, 01:25 PM #8
Also, have you checked places like wheelsandcaps.com? Looks like they have a matching wheel for $135.
OEM Alloy Wheels for 2009 Toyota FJ Cruiser
finding , half , inch , tire , tires
Rear axle difference between 15 and 16 inch wheel atcpup 3rd gen T4Rs 10 06-18-2020 05:09 PM
Tire Diameter Sizing nix92 5th gen T4Rs 3 07-14-2017 10:45 PM
Some Tire Advice - Diameter! bradentyrer 4th Gen T4Rs 2 11-26-2013 06:19 PM
Inch and a half cut enough to ruin brand new tire? BooRad06 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 09-15-2013 11:55 PM
So it just hailed on my 4R. The hail was 1 inch in diameter. What's the biggest Christiantdoug 3rd gen T4Rs 3 03-19-2013 01:36 AM
