04-07-2017, 02:11 PM
MRpink's Build Thread
I wasn't planning on making a thread but the forum has been a huge help to me so hopefully others will find something here useful. Now onto the truck! My current goal is OEM+, this is my daily driver so modifications must be reliable and low maintenance. She'll be on pavement most the time but will see snow and dirt when I'm feeling adventurous.
Current parts:
-OEM All Weather Floor Mats
-Weathertech Cargo Liner (42230)
-Yorkim LEDs
-Bilstein 5100 (set to 0")
-Wheeler's T1 and T12 springs
-Wheeler's 1/4" spacer (front left to correct driver side lean)
-KYB Strut Mount Plates (SM5640)
-FJ wheels ('10-'13)
-BFG KO2 265/70/17 Load Range C (set to 40 psi)
-Hella Optilux 9006 Yellow Bulbs
Parts to be installed:
-Blue Ridge Overland Visor Organizer
Stock with 155K miles and 10 year old suspension.
Current.
2007 Limited 4WD V6 | Bilstein 5100 | Wheeler's T1/T12 Springs | FJ Wheels | BFG KO2 | Build Thread
04-07-2017, 02:20 PM
Yesterday I received some packages from Wheeler's Off-Road!
Doing the install myself so I'll take a lot of pictures and detailed pre and post measurements. Suspension will go on early next week, then I'll schedule tire mount & balance and alignment.
If anyone cares, this is why I picked Bilstein 5100 and Wheeler's T1/T12 springs:
I was torn between the Bilstein 5100 and OME (Slee's Low Lift). I wanted the highest lift possible while retaining the stock UCA, alignment specs, and safe CV angles. I was sold on OME's quality and performance but ultimately decided to go with the 5100 because I was able to save money, they met my driving needs, and they're proven among many platforms. The only negatives I read were that they ride too firm on the 4th gen, but I wanted a firmer ride (sporty) and I think most complaints came from people setting the perch too high and consequently adding too much preload to the springs. I guess I'll find out soon enough.
As for springs, I'm taking a bit of a gamble and going with Wheeler's T1 and T12. I searched every forum and found no 4th gens with this combo. The T12 is re-branded Eibach/SAW 1.5 so I know what I'm getting, but I found conflicting information about the T1 actual lift height (Wheeler's say 1.75"). Either way, I should be getting close to my 2" lift (higher if you consider my sagging 155K suspension) and slightly higher than stock spring rate
04-17-2017, 04:00 AM
Finally installed my Bilstein 5100 (set to 0") and Wheeler's T1 & T12 springs! I'm very happy with the results so far, firmer ride (not rough) and exact lift I wanted.
Below are my before and after numbers (18" Limited wheels + Bridgestone Dueler 265/60/18). Hub to fender and floor to fender numbers shown. I gained 4" in front and ~2.5" in the rear. On the front left, I did add a 1/4" spacer to correct the driver side lean.
The install was fairly straight forward, a 2nd person definitely helped. The fronts were a breeze using the no spring compressor method, but I had a lot of trouble getting the rear springs in and ended up having to use spring compressors.
before
after
before
after - passed the Heineken test
pleased with the CV angle
I followed these 3 write ups:
Bilstein & FJ Suspension Install - Write-Up
OME Install - no spring compressor - Toyota 120 Platforms Forum
OME Suspension Install on 4Runner - Toyota 120 Platforms Forum
For anyone attempting to do this install, be sure to clock the end of the spring toward the rear and for the Bilstein rear shock, here is the correct bushing orientation.
04-17-2017, 09:06 AM
Interesting....
My rear FJ's are starting to sag/bounce a bit and considered this setup as well as I wanted to keep about a 2.5 lift.
I'm curious to see if those springs settle a bit.
SOLD 2008 V6 SR5 4X4 @ 165K: 265/70/17 Falken Wildpeak | SPC Racing UCAs | Method NV wheels | Wheeler's T1/T12 springs| Bilstein 5100
2020 Off Road 4X4: 265/70/17 Falken Wildpeak | OME 883/ Wheeler's T13 | Bilstein 5100 | Sprint Booster
04-17-2017, 03:11 PM
Originally Posted by DEF4Runner
Interesting....
I'll take new measurements after I log some miles. The T12 are rebranded SAW 1.5 and I've heard nothing but positive reviews.
04-19-2017, 05:06 AM
04-21-2017, 01:23 PM
04-21-2017, 02:39 PM
Real Name: Matt
Real Name: Matt
Rig looks really good! Can't wait to see what else you do to your rig
05-09-2017, 10:47 PM
Did your springs settle down at all?
05-10-2017, 03:24 AM
i like your suspension set up... I'm about to do basically the same thing..
i want 265/70/17 KO2s.. bilstein shocks.. and have 1.5 wheel spacers already..
im torn on the springs though.. was hoping for your input.. I was going to go with the 2.5 eibach front and T12 1.5 rear.. do you think that will make the 4Runner nose high and or make the wheels look tiny.. if it makes it nose high, should I just go 2' toytec springs in the back to match the 2.5?
your saying your at about 2 inches in the front with the T1? do you have a slight forward rake? pictures don't alway tell the story.. so your lift is really 2/1.5?
thanks..
2007 Toyota 4runner Sport Edition 4x4, 15% tint, 1.5 inch ALL PRO spacers, de badged, Full interior LED swap (cluster, hvac, etc), plastidip wheels, blacked out headlight housing, K&N, smoker kit, carbon fiber shifter knob, carbon fiber interior wrap, diff breather mod, added VSC off mod, added Compass rearview mirror, independent fog lights, DTRL delete, zXe bulbs, Jensen VX7022 NAV head unit, back up camera, custom rear storage
05-11-2017, 11:59 AM
Not yet, but it hasn't been a month yet. I'll take new measurements after some more time.
thanks..
1) Toytec’s 2.5 and Wheeler’s T1 springs are both made by Eibach. From the information I could find online, I believe they’re the same or very similar. With that said, I don’t think Toytech/Eibach 2.5 front and T12 rear will be nose high. My measurements are below, but with my T1 and T12 combo, my rear was 1.5” – 1.75” higher compared to the front. So even if the Toytec spring is slightly taller compared to the T1, I think the T12 rear will still be taller overall.
About the rear springs, Wheeler’s T12 is relatively new, but they’re just rebranded SAW 1.5, which have been around for a while. Again, they’re also made by Eibach and everyone reported higher than advertised lifts with them, so I think T12 will give you very similar (if not the same) amount of lift as the Toytec 2.0 superflex.
Basically, I think any combination of Toytec/Wheeler/Eibach front and rear springs will give you the appropriate rake and same spring rates. Ultimately, I went with Wheeler’s over Toytec because I wanted black.
2) As for my actual lift, most people (including myself) report higher than advertised lifts because they’re replacing older sagging suspension. Below is my before (stock 18" wheels and tires) and after (17" FJ wheels and KO2) measurements.
My net gain was 3.25” - 4” front and 2.5” - 3” rear.
3) Just my personal opinion but I think the stock tire size is too small for that much lift. BFG KO2 in 265/70/17 looks good though! Here’s a comparison between stock --> 5100/T1/T12 --> FJ/KO2.
05-11-2017, 09:08 PM
I have the same T1/T12/tire size set-up and gained pretty much the same measurements. Using center of the hub to the bottom of the fender stock heights of 19" (F) and 21" (R), I have a 2.25-2.5 lift in all 4 corners, leaving 2" rake, measuring 21.5 in the front and 23.5 in the back.
05-12-2017, 02:45 AM
Great that it's consistent for both of us, that info should help someone make a decision.
Did you ever raise your 5100 to the second notch (0.85) or just kept them at zero?
05-12-2017, 03:02 AM
i think you can get more caster. everyone here told me that with stock uca you can get it more to 3 minimum. also make sure to readjust your headlights and fogs, my thing was so high after the lift.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
05-13-2017, 08:54 PM
No. I left them at the '0' setting. It rides great now, but I think the sway bar is hitting the coils at some point though.
