Old 01-05-2018, 02:19 PM #1
TiN's Avatar
TiN TiN is offline
Real Name: Trevor
TiN will become famous soon enough
TiN TiN is offline
TiN's Avatar
Real Name: Trevor
3D Printed Switch Panel for Sunglasses Holder
Order Information:
Color Options:
  • Black Plastic: [$40 Shipped to Continental US]
  • Tan Plastic: [$40 Shipped to Continental US]
Here's some basic info:
  • You will receive one mounting bracket and one low-profile switch panel (both 3D printed in ABS), along with 2 M3x20 machine screws and 2 M3 nuts
  • Installation will require some permanent modification to the sunglasses holder (full instructions below)
  • For now, I am only offering two options: A standard 4-switch panel constructed of black or tan ABS. Additional colors (gray and more) and configurations ("blank DIY" and "SPOD") will be added shortly
  • The switches to be used are the Contura-V series. If you find that other Carling switches are compatible, please let me know
Installation Instructions:
  1. Remove map light console from headliner
  2. Remove the damper roller and coil spring from the outer side of the sunglasses door
  3. Remove the sunglasses holder door from its pivots either by popping it out or drilling out its studs
  4. Pop out the rubber bump stops in the open sunglasses holder area
  5. Wire up the switches on the switch panel
  6. Place the switch panel in the sunglasses holder, popping the rearward protrusions into the pivot holes one at a time
  7. Use the supplied M3 Bolts (x2) and M3 nuts (x2) to bolt the frontward portion into the bump stop holes mentioned earlier
  8. For easier removal, epoxy the nuts to the backside of the sunglasses housing. This should allow for the removal of the switch panel without taking out the whole map light console.
  9. If more clearance is needed for your wiring and connectors, cut-away some of the upper housing (black plastic) with a rotary tool. Be mindful not to cut away the mounting holes.
Pictures:
Low profile switch panel installed in the vehicle (Courtesy of @ParkerSmith ). This item was printed on a different machine and is not representative of the final print quality of the product, however, it does show the convenient size and placement of the switch panel
Low profile switch panel w/o bracket. This item is a production piece and is representative of the items that will be shipped.
-----Original Post------
I have been working on an easily installable rocker switch panel for the sunglasses holder location in our 4th gens. I have seen some custom approaches to this project, but I wanted to offer a more drop-in solution.
@momo.75 has been very helpful with this project, so it should be in its final stages very soon.
2004 SR5 V8 2WD
TiN is offline   Reply With QuoteReply With Quote
Old 01-05-2018, 03:13 PM #2
Inv4drZm's Avatar
Inv4drZm Inv4drZm is online now
Inv4drZm's Avatar
First to hit the 'like' button!
Well done!
Inv4drZm is online now   Reply With QuoteReply With Quote
Old 01-05-2018, 04:32 PM #3
LC2013's Avatar
LC2013 LC2013 is offline
Real Name: Jeremy
LC2013 is on a distinguished road
LC2013's Avatar
Real Name: Jeremy
One please.
Sent from my SM-N950F using Tapatalk
Previous: 2013 and 2007 JKU/JK....1970 FJ40 w/ Cummins 4bt.
Current:
'03 Titanium Metallic (Need to sell) SR5 4X4 V8 4Runner; DO bumper. King 2.5 Adjustable C/Os. JBA UCAs. MetalTech LT rear setup. MetalTech OPOR sliders. BFG KM2 35/70/17. Prinsuroof rack. Smitybilt X20 winch. OrangeBoxxFab PSD.
'12 Limited 4Runner; OME 3 in. lift. JBA UCAs. BFG KM2 285/70/17. Some other stuff...
LC2013 is offline   Reply With QuoteReply With Quote
Old 01-05-2018, 04:50 PM #4
Raid_Runner Raid_Runner is offline
Raid_Runner is on a distinguished road
Count me in I need more switch spots
Raid_Runner is offline   Reply With QuoteReply With Quote
Old 01-05-2018, 05:35 PM #5
skippy07 skippy07 is offline
skippy07 is on a distinguished road
Definitely need to get one of these! Let me know when you start to produce them!
skippy07 is offline   Reply With QuoteReply With Quote
Old 01-05-2018, 05:36 PM #6
wadle5's Avatar
wadle5 wadle5 is offline
wadle5 will become famous soon enough
wadle5's Avatar
in like Flynn!
-2013 T4R SR5-MYSALSA-KO2's
-(SOLD)2006 T4R SR5. Nautical Blue Metallic. 255/70/17 General AT2. LED Interior Swap. Toytec Ultimate 3inch lift/Icon 2.0s Rear, SHROCKWORKS Front Bumper, OEM FJ wheels, WM Roofrack, slowly working it up. My Build thread HERE
-(SOLD)2005 Subaru Impreza WRX STi. BMW Mica Blue paint job. Cobb stage 2 tuning. Other modifications.
wadle5 is offline   Reply With QuoteReply With Quote
Old 01-05-2018, 06:33 PM #7
Flash Runner's Avatar
Flash Runner Flash Runner is offline
Real Name: Blake
Flash Runner is on a distinguished road
Real Name: Blake
That seems awesome! I had ideas of doing a custom project down the road. After your cup holder though, I'd gladly pick one of these up!
22 SR5 Prem 4X4- Magnetic Gray
07 V8 Limited 4X4 - Natural White (SOLD)--> "Moby Dick" Build Thread
Flash Runner is offline   Reply With QuoteReply With Quote
Old 01-05-2018, 08:33 PM #8
yotaguy674's Avatar
yotaguy674 yotaguy674 is offline
Real Name: Caleb
yotaguy674 has a spectacular aura about yotaguy674 has a spectacular aura about
yotaguy674's Avatar
Real Name: Caleb
Very interesting...
2006 T4R Sport 4x4 V8 My Build
1.5 AllPro wheel spacers, Bilstein 5100's with OME 886's with 1/4" Toytec spacers, OME 2896 rear coils, SPC UCA's, LT285/70-17 BFgoodrich KO2's on 2016 wheels, ARB on-board air system, LFD Off Road Skid Plate, DV8 Offroad Tacoma steel bumper with Smittybilt XRC Winch, PIAA 530 Fog Lights, Diff Breather Mod, Limited grille, CBI ditch light brackets and light pods, ARB awning, Wilco Offroad Tiregate,Full size spare tire, RCI Rock Sliders, HCF delete, Smokers kit, Interior LED swap, Map light mod, Pionner AVH-X391BHS HU, Tentbox RTT, Cobra CB, Flowmaster exhaust
yotaguy674 is offline   Reply With QuoteReply With Quote
Old 01-05-2018, 08:48 PM #9
Anonymous4Runner Anonymous4Runner is offline
Anonymous4Runner is on a distinguished road
Looks great!
Anonymous4Runner is offline   Reply With QuoteReply With Quote
Old 01-05-2018, 09:55 PM #10
momo.75's Avatar
momo.75 momo.75 is offline
Registered User
Real Name: Morris
momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of
Registered User
momo.75's Avatar
Real Name: Morris
For now, I'll leave you with a teaser render. Updates Soon
Great job man!
momo.75 Build ThreadClick to order T4R.ORG Decals • @urban_overland
momo.75 is offline   Reply With QuoteReply With Quote
Old 01-05-2018, 09:58 PM #11
CharlieV CharlieV is offline
Real Name: Charlie
CharlieV is on a distinguished road
Real Name: Charlie
Yes, add me to the list!
CharlieV is offline   Reply With QuoteReply With Quote
Old 01-05-2018, 10:48 PM #12
4RunAmok's Avatar
4RunAmok 4RunAmok is offline
4RunAmok is on a distinguished road
4RunAmok's Avatar
Consider a version that can be used for SPOD HD button pad/switch pro???
Please???
Mitch - Build Thread
Silver '06 4Runner V6 Sport Edition 4WD
Certified Emergency Vehicle Electrical Technician/12 Volt Vehicle Upfitter
4RunAmok is offline   Reply With QuoteReply With Quote
Old 01-05-2018, 11:25 PM #13
xxGxx xxGxx is offline
xxGxx is on a distinguished road
Looks great - count me in for one.
xxGxx is offline   Reply With QuoteReply With Quote
Old 01-05-2018, 11:50 PM #14
SAC-CA-Runner SAC-CA-Runner is offline
SAC-CA-Runner is on a distinguished road
Heck yeah...I'd be in for one! I wouldn't mind a place to add more switching.
SAC-CA-Runner is offline   Reply With QuoteReply With Quote
Old 01-06-2018, 12:20 AM #15
TiN's Avatar
TiN TiN is offline
Real Name: Trevor
TiN TiN is offline
TiN's Avatar
Real Name: Trevor
Please???
Do those SPOD units just have two mounting studs on the back? If so, I should be able to adapt the design easily.
2004 SR5 V8 2WD
overhead sunglasses holder grumman41 Maintenance/Detailing 4 03-29-2018 02:56 PM
Need a sunglasses holder Door? Where Do I get one. 4RUNIN 3rd gen T4Rs 18 03-31-2017 09:23 AM
3rd gen sunglasses holder - $35 SRQ-Runner For Sale: T4R Items 11 07-13-2015 11:24 PM
Modded sunglasses holder (roof) 4D7 4th Gen T4Rs 16 07-18-2012 02:53 PM
Sunglasses holder??? WV4Runner Engines / Suspension / Wheels / Tires / Audio / Accessories 2 10-18-2003 12:54 PM
