Old 04-18-2020, 08:38 PM #1
Bernardchan96 Bernardchan96 is offline
Real Name: Bernard Chan
Bernardchan96 is on a distinguished road
RAS Swap & Front Suspension questions
So im looking at doing a couple things this year and pricing them.
For those who have swapped RAS to Coils, i was wondering whether the OEM top spring isolator would work with an aftermarket coil? Im planning to go with Metal Tech conversion kit. and they sell them with and without the isolator. The OEM top isolator is flat and does not go into the coil
Lexus GX470 Rear Coil Conversion Kit Complete
I Will be doing some front end work. and seeing what to buy, This is the list im currently pricing out
UCA: JBA Upper Control Arm
LCA: OEM takeoffs with Senkei 555 ball joints
Shocks: i Currently run bilstein 5100 +Fj coils but want to stick with my Bilsteins + Dobinsons/Toytec/OME. Mild offroading, more daily.
2005 4R LIMITED V8
FALKEN WILDPEAK AT3W&TRD RIMS
DOBINSONS SUSPENSION 2.5" F 2" R / JBA UCA / POLY PERFORMANCE TACO TAB/ 2ND GEN REAR LINKS
VOLANT CAI/ RA MOTORSPORTS SKID & DITCH LIGHT MOUNT
MAGNAFLOW MUFFLER
Bernardchan96 is offline   Reply With QuoteReply With Quote
Old 04-19-2020, 08:46 AM #2
jcaino jcaino is offline
jcaino will become famous soon enough jcaino will become famous soon enough
Yes, the OEM upper isolator/secondary bumpstop will work with after-market springs.
That said, if you are planning on doing aftermarket air bags to retain some load adjustability, skip the expensive OEM isolator and just get the moog one that is flat w/ no bumpstop. You'll save money and wont have to cut down the expensive OEM part.
Plans for the frontend look good, but I'd probably skip the take-offs. Check out the LCA's from SuperPro. I wish they were available when I did my LCA's.
SuperPro LCA
2003 Galactic Gray Mica Limited V8
Inside: Pioneer AVH-2300NEX w/ backup cam | Dometic CFX3 55im | Custom floor w/ table & drawers
Outside: Hefty Fab Bumper | Warn ZR 10-S | RCI skids & sliders
Electrical: 150w solar panel | Victron MPPT controller | BlueSea breakers and panels
Suspension & Tires: Bilstein 5100's w/ Dobinson c59-314 & c59-329 | 5th Gen Trail wheels & Wildpeak A/T3W 275/70/17
jcaino is offline   Reply With QuoteReply With Quote
Old 04-19-2020, 01:06 PM #3
SuperPro LCA
So for the rear im getting rid of the airbags cause i dont tow that often for the need. In terms of the rear spring isolator OEM comes with the spring cone isolator but i can use these moog ones instead with my aftermarket coils?
Moog K160061 Coil Spring Insulator, Insulators - Amazon Canada thinking of upgrading bumpstops anyways since im looking at 2” lift on the rear atleast.
I wish i could afford the LCA i got a deal on good condition take offs with brand new ball joints in box for $50
2005 4R LIMITED V8
MAGNAFLOW MUFFLER
Old 04-19-2020, 01:25 PM #4
Yes, I used the Moog ones.
Old 04-19-2020, 09:21 PM #5
So my purchase list would just be
1) Coil spring insulators/isolators Could i go with either these
A) Moog K160061 Moog K160061 Coil Spring Insulator, Insulators - Amazon Canada
or B)2005 TOYOTA 4RUNNER 4.7L V8 Coil Spring Seat / Insulator | RockAuto
Then for the bottom of the springs get the
im curious because i see youtube videos and guys doing conversions are using the bottom spring seat like the metal tech stage 1 kit, is this a necessity?
2005 4R LIMITED V8
MAGNAFLOW MUFFLER
Old 04-20-2020, 07:11 AM #6
You need an isolator for the top and bottom of the spring. Moog is the one for the top, kit comes with the bottom one.
Old 04-20-2020, 02:09 PM #7
Yeah ill get the metal tech stage 1 kit for the bottom isolator. The top one either i go moog top isolator, or the rockauto one that i linked
2005 4R LIMITED V8
MAGNAFLOW MUFFLER
Old 04-21-2020, 04:15 PM #8
Mikes3rdgen Mikes3rdgen is offline
Mikes3rdgen is on a distinguished road
Wait, so youre running the 5100s with the bags still in? What do you think of the ride and what setting do you have them at? I might do that as well and then pull the bags with i get more money to do the swap..
Mikes3rdgen is offline   Reply With QuoteReply With Quote
Old 04-22-2020, 11:23 PM #9
Yeah 5100 all around, the front is nice with the coils, but the rear is stiff, very stiff. Maybe the bags are just old or something but i definitely think itll be much better with coils since im not towing all the time.
2005 4R LIMITED V8
MAGNAFLOW MUFFLER
coil , coils , isolator , oem , top
5th Gen TRD-Off Road to TRD Pro suspension swap questions kott3670 5th gen T4Rs 5 10-02-2019 02:31 PM
front suspension swap 01thunder 3rd gen T4Rs 5 05-23-2017 05:38 PM
front diff swap questions yotatake2 3rd gen T4Rs 15 03-30-2017 10:11 AM
Suspension Swap questions cyber_cop 4th Gen T4Rs 6 05-21-2015 11:22 PM
Solid front Axle Swap Questions Steve8v92 Classic T4Rs 1 04-13-2009 04:08 PM
