Old 04-23-2020, 02:32 PM #1
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
Best spacer to correct driver side lean?
Anyone have any recommendations for a spacer to correct the driver side lean? I'm about 0.75" lower on the driver side than the passenger after my lift. Also, will I need an alignment after adding a correcting spacer?
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 04-23-2020, 03:31 PM #2
HIMILESV8SPORT's Avatar
HIMILESV8SPORT HIMILESV8SPORT is offline
HIMILESV8SPORT is on a distinguished road
ironman 4x4 offers 20mm and 25mm spacers I believe. OME has a 10mm one. As far as an alignment after, I'd see how it drives first.
Eibach pro truck with WOR springs on 1st notch in front. 5100's in rear w/ FJ OEM takeoff coils. 255/70R18 on 18" Limited wheels. 1.5" spacers on rear(one trimmed a bit to correct lean). Gibson catback, 06+Headlamps, auxito 16K bulbs in high, low, and fogs!
HIMILESV8SPORT is offline   Reply With QuoteReply With Quote
Old 04-23-2020, 03:41 PM #3
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Just the front right? 20mm spacer would probably work for you unless someone makes a .75" one.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 04-23-2020, 05:27 PM #4
roy326 roy326 is offline
roy326 is on a distinguished road
Ironman4x4 requires you to take off the bumpstop , so make sure you're accounting for that difference in height
03 4runner V8 4x4
12 GX460
17 Tacoma OffRoad
roy326 is offline   Reply With QuoteReply With Quote
Old 04-23-2020, 05:46 PM #5
The Ironman 20mm looks to be rear.
I really only need a front one, which kind of surprises me tbh. I wouldn't mess with it, but my tires rub in one very specific set of circumstances on the driver side, and will clear nicely when leveled.
One thing I'm seeing on a lot of them is it will be a 0.25" spacer, but then it will say it gives a half inch of lift. Any idea what's up with that?
Old 04-23-2020, 06:26 PM #6
Looks like Toytec makes the perfect one for you.
TOP1-T Front Top Plate Spacer Kit
correct , driver , lean , side , spacer
Driver side lean? jmv7680 4th Gen T4Rs 13 07-31-2019 03:36 PM
Driver Lean Spacer Alternatives? FamousAv8er 5th gen T4Rs 13 07-24-2018 06:54 PM
Is OME rear trim spacer necessary to correct driver side lean? andrewbares 3rd gen T4Rs 9 01-14-2016 09:43 PM
driver side sag/lean jmeeller 3rd gen T4Rs 18 12-01-2014 11:36 AM
Best Driver's Side Lean Correction Spacer for use with Toytec Ultimate Lift? EdmundGTP 4th Gen T4Rs 11 06-25-2013 09:22 PM
