03-17-2014, 09:56 PM
Correcting Driver Side Lean
I have always been curious what the easiest method was for correcting driver side lean. Before I got my CBI bumper and just had my radflo front and rear set up if I took a tape measure and measure from the top of the tire to the fender in the rear it sagged about 1 1/2 in on the driver side. Now after I having my bumper and all pro 3.5's installed it still leans on the driver side but only 1in. I'm curious what the easiest way to correct this is. Previous to having my all pros installed I had been messaging
@ aha2988
about running a daystar 1.5in spacer under the driver side rear coil but for some reason the mechanic had a problem with me doing that and I took his advice and held out. What I would like to know is, is that my best option to run a spacer under the driver side coil or could I correct my cranking up the driver side coilover in the front up? I would really appreciate some input, thanks.
03-17-2014, 10:02 PM
It's not a huge difference but enough that I'm always thinking about it. And wow it looks naked without a roof rack.
03-17-2014, 10:08 PM
Real Name: Pete
Real Name: Pete
http://www.weightwatchers.com/index.aspx
j/k
With my allpro extreme lift on my 82 pickup I just assumed a lean while in the drivers seat with no passenger was part of having a well articulating soft suspension.
Does yours lean all of the time?
03-17-2014, 10:19 PM
Moderator
Real Name: The Chosen One
Moderator
Originally Posted by DaGimp
OK, I was thinking find a passenger that out weighs you.
'89 4Runner SR5 - stock
03-17-2014, 11:36 PM
@ aha2988
Hey! I'm running daystar spacers in the back on top of MT LT coils that are 19.75" long, so I don't think the overall height of the coils would be a problem. As far as running uneven spacers being a problem, a lot of guys do that with the 4th gens specifically, because the lean seems to be so prominent. I know that
@ LTDSC
for one is running it on top of super flexes in the rear of his truck.
One thing I would caution with running that much height is because of a problem I had recently. I deformed my gas tank skid ever so slightly on an obstacle, and because of my lift height combined with the flex, my driveshaft was able to come into contact with the gas tank skid under certain flexed conditions. Just something to watch out for.
03-18-2014, 02:03 AM
Im running a daystar spacer on driver side rear with my all pro coils to fix the lean I also had to crank driver front coilover a little more to help too
03-18-2014, 02:09 AM
Real Name: Alex
Real Name: Alex
Convert to right-hand drive.
2004 Toyota 4Runner SR5 PreRunner - A slow but steady build!
GOODϟYEAR Wrangler Silent Armors, K&N Air and Oil Filters, Borla PROXS Muffler, Mobil 1 Full Synthetic Oil, and a few other things
- Helpful DIY Videos
03-18-2014, 08:23 AM
@ aha2988
HAVE BEEN RUNNING 1.5 SPACER SINCE 08 NEVER A PROBLEM AND I DO WHEEL IT ( with 895E ome coils )
03-18-2014, 08:57 AM
Real Name: Matt
Real Name: Matt
Just run the daystar spacer. It's a cheap, proven fix. Been running mine for 12k with zero issues.
HokieRunner 2005 4Runner Sport Edition V8 4x4 Silver Build Thread
Radflo 2.5 F 700#/R 220# / Desert Racing Uniball UCA / 285/70/17 Duratrac on 17x8 Konig Six Shooter / RCI Full Skids / BAMF LCA Skid / Shrockworks 3 Hoop Bumper / Custom WhiteKnuckle Sliders / Custom WMW Roof rack / CVJ Reman'd Axles / 06+ Facelift / Custom sound system / AIP Bypass / LED Gauges,Dash,Interior / Wiring, aux. lighting, dual battery, custom cargo box in progress...
03-18-2014, 08:58 AM
Real Name: Austin
Real Name: Austin
Superman3043 and I both run a daystar 1.5" spacer on the driver side rear. Lean is corrected and have not had any issues.
-Austin
A-Ha's Build
03-18-2014, 09:35 AM
Great looking Runner! I personally love the no roof rack look (although I think you're waiting on a WMW, right?) and considering I never use the stock one, I'm going to be deleting mine this summer.
Current: 17' GX460 Luxury with DSP, Nightfall Mica / Black
Sold: 05' 4R Sport v6, 07 4R Limited v6
03-18-2014, 04:12 PM
What size spacer are you running?
03-18-2014, 05:16 PM
1.5 the daystar one
08-29-2014, 02:15 PM
Bumping up older thread, since it looks like a good spot to put this --
I swapped in FJ springs, and added a single 1.5" Daystar spacer on the rear driver's side to correct the lean. It worked -- my 4R is within 1/8-3/16" of level front and rear.
In searching on this topic, before I added the single spacer, I didn't see any discussion of this possible explanation for the lean -- just speculating here, but could it be that Toyota laid out the 4Runner (and Prado, and FJ, and GX) with the heavy items on the left side (battery, fuel tank) in order to compensate for the weight of the driver on the right? Since Japan is RHD, this makes sense.
11-04-2017, 12:49 AM
I just noticed today i have an almost 2" lean on the rear of my '14 4runner towards my drivers side while my fronts are perfectly level.
Currently have icon stage 2 lift kit with OME 889 rear coils.
Would the daystar 1.5" lift on JUST the rear driverside coil correct it enough or should i tone it down with a 1" lift correction with cornfed spacers?
2014 sr5 white. Icon stage 2. OME 889s. gobi rack. and other crap i dont remember. i just want to go camping in my car.
