Old 04-27-2020, 04:02 PM #1
DwightS DwightS is offline
DwightS is on a distinguished road
2006 4Runner Limited - TRD tire size ?
Hi, been a member around here for a while, but I have only come looking when I needed to figure out something on the wife's 4Runner.
The time has come, my son will be soon turning 16 and he want's my wife's 4Runner over my 1998 Land Cruiser, which is OK cause love my LC.
In order to make it more his, we're planning on updating the wheels/tires. I've found a set of 2019 TRD wheels to help make it more manly and less mom.
What is the best tire size for a 17" 7.5" wide wheel? Stock suspension, no lift. If we do a lift, it will be a mild lift. We're stepping back from the stock 18" to a 17", so I'm a little lost....
Thanks!
DwightS is offline   Reply With QuoteReply With Quote
Old 04-27-2020, 04:15 PM #2
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
Stock tire size for a 4th gen is 265/65r17 on a 7.5” wide rim.
Without a lift, you might be able to squeeze in a 265/70r17. Someone on here has probably done it.
ads2539 is offline   Reply With QuoteReply With Quote
Old 04-27-2020, 04:20 PM #3
knarfwhite knarfwhite is offline
knarfwhite is on a distinguished road
I'm interested too. I was able to fix 265/70/17 on stock SR4 rims for my 2005. It is not lifted and doesn't rub. I did remove the front mud flaps and they probably would have rubbed if I kept the flaps. But you do have to look at the type of tire you use. My tires are Kumho all-terrain. I believe some of the mud tires like the KO2 in that same size are larger in diameter and could rub. I think the 5th gen TRD rims are a different offset so that may also affect what size you can fit.
knarfwhite is offline   Reply With QuoteReply With Quote
Old 04-27-2020, 07:13 PM #4
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Not sure if you mean 2019 TRD Off-Road rims (7.5 inch width) or do you mean 2019 TRD PRO rims (7 inch width). Tire choice should be a reflection of what the 4Runner will be used for (e.g., daily driver, off-roading). Tire size for the 5th Gen 17" rims is 265/70R17.
Largest tire "sizes" for stock 17" rims???
Going Bigger - 5th Gen Tire Fitment Guide - Toyota 4Runner Forum - Largest 4Runner Forum
Can 5th gen wheels work on my 4th gen 4 runner
Do 5th Gen Trail Edition wheels fit on our 4th Gen's?
The 4th gen TRD PRO wheel picture thread
Max tire size on stock 17"rim?
Biggest Tire Size?
max tire size
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 04-27-2020, 07:20 PM #5
TRD Off-Road rims. For the most part, it will be street driven. He may eventually get interested in some lite off-road. I appreciate the help.
2006 4Runner Limited - TRD tire size ?-1260050c-248e-4116-9196-b9a8cb7341e2-jpeg
Old 04-27-2020, 07:25 PM #6
Bossman's Avatar
Bossman's Avatar
Yep, those are nice rims. I run those exact same rims for my winter set with 265/70R17 Toyo Observe GSi-5 tires on my 2011 Limited. I then switch back to the 20 inch Limited rims for the summer.
Old 04-27-2020, 09:25 PM #7
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
265/70R17 came with that wheel. It's a great wheel (yes, I'm highly biased lol)!
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 04-27-2020, 09:34 PM #8
ads2539's Avatar
ads2539's Avatar
Yes, 265/70r17 is the stock tire size on 5th gens. They must have slightly bigger wheel wells, because 265/65r17 is the stock size for 4th gens.
Assuming the same tire brand and model, the 265/70r17 is about an inch taller than the 265/65r17 (~31.5” vs. ~30.5”).
The 4th gen speedo and odometer are both calibrated for a 265/65r17 (or 265/70r16) tire.
Old 04-27-2020, 10:35 PM #9
70 series fit just fine, plenty of people have that on this forum, even with no lfit.. I ran stock 5th gen tires on my stock sport wheels (and no lift) for a bit until I moved up to 295/70R17s (post-lift of course) on 5th gen Trail wheels. It was fine.
Old 05-18-2020, 08:49 PM #10
Finally got the wheels installed. Stuck with the stock 4-gen tire size for the time being. Goodyear Wrangler Duratrac tires. Now looking to do a minimal lift.
2006 4Runner Limited - TRD tire size ?-e7c23c1a-f5e9-4ce0-9549-e4eedf68182f-jpg
Old 05-19-2020, 02:37 AM #11
Honestly, you should have went with the 70 series since you’re now thinking of doing a minimal lift...
Old 05-19-2020, 11:56 PM #12
Southpaw07 Southpaw07 is offline
Southpaw07 is on a distinguished road
Biggest Tire Size?
max tire size
Helpful links. Thank you
Southpaw07 is offline   Reply With QuoteReply With Quote
4runner , lift , stock , trd , wifes
Maximum Tire Size on 2006 4runner Ruta Off-Roading 25 10-26-2021 12:20 PM
Tire Recomendations for 2006 4Runner Limited kll320 Engines / Suspension / Wheels / Tires / Audio / Accessories 16 12-30-2020 12:00 PM
2006 4Runner SR5 Full Size Spare + TPMS and Tire USMC5541DD For Sale: Suspension/Wheels/Tires 0 10-05-2011 02:25 PM
Max tire size for 16x8 on 2006 SE t-rex grrr Engines / Suspension / Wheels / Tires / Audio / Accessories 2 08-17-2006 03:28 PM
2006 - Max Tire Size? K513 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 03-18-2006 05:08 AM
