Old 04-28-2020, 09:37 PM #1
paraordnance's Avatar
paraordnance paraordnance is offline
paraordnance is on a distinguished road
removing oil cooler from engine block during power steering rack replacement
I'm replacing a lot of parts: TB, water pump, bearings tensioner, seals, power steering rack, hoses from PS pump (high-pressure side) and the low-pressure side. I almost got everything removed but to slide the power steering rack out I need to loosen up the oil cooler. Where are the bolts that holding oil cooler?
removing oil cooler from engine block during power steering rack replacement-20200428_192916-jpg
2004 4Runner Limited V8 4WD
Toytec Ultimate 3" (X-REAS & RAS - delete). LS460 + STi retrofit, Switchback Halos, LEDs in/out, Fog light mod.
CBI front bumper. 285/70/17 Duratracs.
JVC KW-V50BT with Hertz HCP4D & Hertz HCP1D, Hertz ESK-165 components and JL 10TW3 in custom stealth enclosure. Backup camera and steering wheel controls.
paraordnance is offline   Reply With QuoteReply With Quote
Old 04-29-2020, 01:11 PM #2
V8Man's Avatar
V8Man V8Man is offline
V8Man will become famous soon enough V8Man will become famous soon enough
V8Man's Avatar
Remove the oil filter, screw the fitting out.
removing oil cooler from engine block during power steering rack replacement-cars-4run-blue-8-jpg
I currently own 4 T4R 4th Gen
#1) 2003 Sport V8 2WD purchased new, totaled @ 175,000.
#2) 2003 SR5 V8 2WD running w/engine from #1(Son#3 is Driving)
#3) 2003 Sport V8 4WD
#4) 2004 Sport V8 Supercharged 4WD
V8Man is offline   Reply With QuoteReply With Quote
Old 04-29-2020, 07:41 PM #3
You saved my day, I gave up trying to figure out how to take oil cooler with the filter in place! I watched the video on youtube by EricTheCarGuy how to remove the rack but it skips through the oil cooler part and his assembly moves away with the filter on. That's what confused me. Thanks, I'm finally removing parts again and will start to put it all back together with new stuff this week.
cooler , oil , power , rack , steering
4th Gen 4Runner 2003-2009 Power Steering Rack Replacement How-to / DIY HokieRunner 4th Gen T4Rs 29 01-27-2024 02:04 AM
Power Steering rack replacement.... info needed! fightman80 3rd gen T4Rs 76 03-24-2023 04:24 PM
Replacement power steering rack bushings DerJaeger 3rd gen T4Rs 124 01-29-2022 12:13 AM
Power steering rack replacement Bootboy 3rd gen T4Rs 22 12-24-2020 11:18 PM
Steering Rack and Power Steering Pump Replacement thebrandon 3rd gen T4Rs 5 07-02-2013 10:07 AM
