Old 04-28-2020, 10:22 PM #1
RivMan's Avatar
RivMan RivMan is offline
RivMan has a spectacular aura about RivMan has a spectacular aura about
RivMan's Avatar
Recovery points with ARB Bumper???
Anyone have recovery points with an ARB bumper?
The ARB bumper doesn't include any recovery points, and seems to cover the points used by most add-on recovery points.
Does anyone have any recommendations for a front recovery point that's compatible with the ARB?
Thanks
-Rob
RivMan is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 10:24 PM #2
RivMan's Avatar
RivMan's Avatar
This is the front mount on the ARB.
Recovery points with ARB Bumper???-ea399106-5988-46ba-bd69-c2352b49a900-jpg
2006 Sport V8 4x4 4Runner | Mods: ARB Front Bumper | Warn XD9000 Winch | Custom Sliders | ECGS 4.56 Gears | Eaton Truetrac rear | JBA UCA | SuperPro LCA | Icon 2.5 Front Coilovers | MetalTech Icon 2.0 Long Travel Rear Shocks | Dobinsons Long Travel Rear Springs | Energy Suspension Front Bumps | Durobump Rear Bumps | Falken WildPeak 285/70/17 | SCS F5 wheels | Custom Roof Rack | Gobi Ladder | OrangeBoxx Molle Panels | Icom IC-2730a HAM Radio | Rigid Ditch Lights | Custom Rear Drawers | 23Zero Walkabout 62 | ARB Awning | Dual Battery System | CVJ Axles | Victory 4x4 Rear Bumper with Dual Swingouts | Front Runner Table
Old 04-28-2020, 10:36 PM #3
UnJeep's Avatar
UnJeep UnJeep is offline
UnJeep is on a distinguished road
UnJeep's Avatar
Maybe look at Demelo"s...
Sent from my SM-N950U using Tapatalk
2007 Limited 4x4 - UnJeep - AKA "DAS 4RNR"
l Radflo Stage 3 l DO X-Wing Sliders l DO 3 Hoop bumper l Smittybilt Wench l MB TKO Wheels l Nitto Trail Grapplers 35x11.5x17 l Eagle Eye Headlights l Led Fogs l Rigid Light Bar l IPF Spots l RCI Skids l ARB Rear Locker l FJ T-Case swap l
UnJeep is offline   Reply With QuoteReply With Quote
Old 04-29-2020, 09:17 AM #4
RivMan's Avatar
RivMan's Avatar
It doesn't look like Demello sells a recovery point, just a full bumper. I already have an ARB bumper, just looking to add some recovery points up front.
-Rob
Old 04-29-2020, 09:58 AM #5
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
You continue to use the factory recovery points.
techno is offline   Reply With QuoteReply With Quote
Old 04-29-2020, 10:18 AM #6
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
That's the main reason I went with Shrockworks over ARB. That said, I believe you can buy an add-on recovery point from ARB.
eleven14 is offline   Reply With QuoteReply With Quote
Old 04-29-2020, 12:09 PM #7
RivMan's Avatar
RivMan's Avatar
Looks like the BBG points for the 5th gen will fit, just ordered up a set.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
-Rob
Old 04-29-2020, 12:50 PM #8
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
I still use the factory ones, seem to be pretty solid unless you bash one into a rock and break it off...
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 05-06-2020, 09:01 AM #9
RivMan's Avatar
RivMan's Avatar
Just confirming that these fit great with the ARB bumper on a 4th Gen.
-Rob
Old 05-07-2020, 12:30 PM #10
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
The factory points will rip off if you are being winched out of a mud hole or a hard spot.
In the past I have simply used a tree strap through one of the arb vertical supports and it's ok.
I plan on cutting a 3/4" piece of plate and bolting it straight to the frame then coming out of the arb bumper where I cut a hole.
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 07:45 AM #11
gulinx gulinx is offline
gulinx is on a distinguished road
-Rob
Looks good! I installed the same one last year.
- GL
gulinx is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 11:33 PM #12
WetCoastRunner WetCoastRunner is offline
WetCoastRunner is on a distinguished road
-Rob
Did you have to remove the bumper to access and remove the nut from the upper mounting point?
WetCoastRunner is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 08:39 AM #13
RivMan's Avatar
RivMan's Avatar
I didn't.
I was able to get the ARB hardware out, and the new hardware in through the larger hole towards the rear of the truck. It's a bit difficult, but not too bad.
-Rob
Old 02-25-2021, 10:55 PM #14
RJFJR RJFJR is offline
RJFJR is on a distinguished road
Hi Rob,
How were you able to get the ARB hardware out of the top most hole? I want to do same, but am concerned that the nut will just spin without having a wrench around it. Also, how did you retrieve the ARB nut from within the frame?
RJFJR is offline   Reply With QuoteReply With Quote
Old 02-25-2021, 11:02 PM #15
RivMan's Avatar
RivMan's Avatar
Originally Posted by RJFJR View Post
Hi Rob,
My bolt went into a “nut on a stick”. I was able to loosen it and fish the hardware out by its handle. I can post a pic when I get home, but it looks similar to what came with the recovery points.
-Rob
arb , bumper , front , points , recovery
Front recovery points benztech82 4th Gen T4Rs 46 04-12-2022 12:34 PM
Want to keep stock bumper, but add recovery points/shackles to the front... muscle_doc 5th gen T4Rs 46 06-21-2021 05:36 PM
Front recovery points without aftermarket bumper. RogueYota 3rd gen T4Rs 10 03-25-2019 05:48 AM
5th gen recovery points Dario Off-Roading 2 11-10-2014 09:34 PM
Recovery points Ohcrymore Off-Roading 8 01-30-2014 08:51 PM
