Old 05-02-2020, 08:35 PM #16
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
I was very lucky the first time but stripped it the second. Fortunately I had to take it in to the shop for an axle seal anyway and they removed it for me since they had to refill the fluid.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 05-03-2020, 07:23 PM #17
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Originally Posted by Bumbo View Post
I'm all for doing my own work, but that 10mm lex on front diff man... when a good DIY turns into an OMG
I had to take it to someone to air hammer off loose after I stripped it.
I agree, front diff is a pain. I stripped mine even after grinding the hex flat, hammering it down, and using a propane torch. Torch was heating everything up instead of just the bolt, so that wansn't working well. I had to weld a nut onto mine for it to break free.
Newbie 4wd question
y=mx+b is offline   Reply With QuoteReply With Quote
Old 05-04-2020, 01:34 AM #18
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Originally Posted by cooper30 View Post
I might have missed it...is your truck full time 4wd?
I was a bit curious myself, but it's probably easier to ask if its a V6 or V8.
I suspect V6 based on the how the question was asked.
Old 05-04-2020, 10:50 AM #19
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
I suspect V6 because it says so in the first post
techno is offline   Reply With QuoteReply With Quote
Old 05-05-2020, 03:06 PM #20
cooper30 cooper30 is offline
Real Name: Ted
cooper30 is on a distinguished road
Real Name: Ted
Note to self: focus on reading comprehension.
2008 4Runner Limited 4wd V8
2005 Tundra SR5/TRD Off Road 4wd V8
cooper30 is offline   Reply With QuoteReply With Quote
Old 05-05-2020, 03:29 PM #21
toy3rdgen toy3rdgen is offline
toy3rdgen is on a distinguished road
What wire gauge? for transfer case actuator
I have a 2001, 4Runner sr5, F/T AWD, 3rd Gen.
I need to repair a single wire at the end going into the 4WD position switch of the actuator as it has an area of exposed insulation and the wire is bad.
What gauge wire do I need? And is there a special type that I need to use?
Thanks all!
toy3rdgen is offline   Reply With QuoteReply With Quote
Old 05-05-2020, 09:48 PM #22
y=mx+b's Avatar
y=mx+b's Avatar
Thanks all!
Admittedly I've never dealt with the transfer case wiring, but may be ably to point you in the right direction to manually figure it out. Times are odd right now, but if you can get one of your hands on one of these wire gauges, then you might be able to figure out the size.
Another option would be to look on the wire to try and see if it has any markings on it. For example, this wire below is marked with 18 awg. I have no idea if this is required, but I took apart a dinosaur of a computer power supply to rob wire and they were all labeled like this.
put , scared , sign , turn , work
Newbie with TB Question LA4RUNNERGUY 3rd gen T4Rs 4 03-04-2012 09:07 PM
Newbie With A Question Watchdog Classic T4Rs 2 08-18-2009 07:20 PM
Newbie with a question drago Classic T4Rs 2 04-13-2008 11:14 PM
A Newbie Question .... hjohn5120 4th Gen T4Rs 2 09-18-2006 10:54 PM
REALLY REALLY BIg NEWBIE QUESTION! SH0ck-D Off-Roading 2 06-22-2006 01:30 AM
