Originally Posted by mymalade
Well, 2 questions.
1. How the hell did you get the wiring through that rubber grommet/hose going from the liftgate into the vehicle? My cable has an RCA connector and it's almost pretty much impossible to get it through that grommet. Is it safe to use WD40 on those wires inside the grommet?
2. Where did you run the wires inside the liftgate? I can't really tell where the window slides down and I have a lot of excess cable. I am most likely going to just zip tie them to the factory wiring, but will this make the cables too bulky and in the way of the window?
My rear camera came with a disconnect in the wiring that made fishing the cable through the grommet much easier. I too used a little bit of silicone spray and then a coat hanger to pull it through, made it much easier than doing it without.
I ran the wires along the bundle up the left side of the hatch, it was tight fishing it through and then as mentioned, I used zip ties to keep it out of the way of the rear window track to the best of my ability.
2004 4Runner V8 Limited - TRD Exhaust, LED Interior Swap, Pioneer HU, Tacoma TRD Front Suspension, FJ Rear Springs, 10" + 32" Light Bars, Prius Shift Knob, 275/65R18 Falken Wildpeak, 18x9 Level 8 MK6 Et0, GOBI Ladder, 06-09 Headlight Swap, TOTALED NOV 2019, RESURRECTED APR 2020
Build Thread
1998 Volvo S70 T5 - Custom Airlift Suspension, BBS Nebula Wheels, Brada Seats, Engine Bolt Ons -
StanceWorks Build Thread
2010 Subaru Forester 2.5X - Wifes Car
