Old 05-04-2020, 04:54 PM #1
stormrunner925 stormrunner925 is offline
stormrunner925 is on a distinguished road
Thorley Headers and 1" BL, will steering shaft clear?
Hey guys Ive tried searching to find a concrete answer for this and haven't been able to come up with anything. I have Thorley headers that I plan on installing in august after I smog(CA bs). I am looking at ordering a toytec 1" body lift but have found a very limited mixed bag of results if it will work with the headers. I don't want to do all the work of putting it in to just have to uninstall it in a few months. Anyone running this setup? I have a 2007 with the 4.7. Thanks in advance
stormrunner925 is offline   Reply With QuoteReply With Quote
Old 05-04-2020, 05:04 PM #2
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Long tube or short tube headers?
My long tubes clear the bolt after I ground it down quite a bit. Running a 1.5" BL.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 05-04-2020, 05:16 PM #3
They're the short tubes, Im planning on running the hi flow magnaflow cats with them. Good to know it worked with some modification, did you have to dent the headers in at all? I also have bilstein 6100 @ 2" and 5160 with 1.5" springs in the back if that makes any difference
Old 05-04-2020, 05:20 PM #4
Inv4drZm's Avatar
Inv4drZm's Avatar
I didn't have to dent them, but maybe I should have because the bolt doesn't have much left on one side.
I believe the short tubes have less clearance than the long tubes, that's the rumor anyway. It should work, even if you have to do a combination of denting and grinding. Or find a lower clearance bolt.
Old 05-04-2020, 09:42 PM #5
KrazedJD's Avatar
KrazedJD KrazedJD is offline
KrazedJD is on a distinguished road
KrazedJD's Avatar
I am interested in this as well, I want to do the headers but keep my 1" Body Lift. Inv4drZm, can you snap a picture of the modification you made to the steering?
KrazedJD is offline   Reply With QuoteReply With Quote
Old 05-04-2020, 11:01 PM #6
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
If your going with Long Tubes here is how they fit with a 1" BL. Plenty of room on mine.
Thorley Headers and 1" BL, will steering shaft clear?-20200205_220227-jpg
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 05-05-2020, 08:02 AM #7
KrazedJD's Avatar
KrazedJD's Avatar
Living in NJ makes long tubes difficult as NJ does visual inspections to make sure I have proper emissions hardware. I don't think there are garage style inspections anymore as NJ has weeded them all out. With the Long Headers I would likely do the upgraded y pipe as well.
Old 05-05-2020, 08:54 AM #8
Real Name: Brett
Real Name: Brett
I was going to modify the DT Y pipe by putting high flow cats where the resonators are, but my sudden unemployment killed that idea for awhile. There are no inspections what so ever here in Florida, so it doesn't matter, but I would rather not pollute. What's irritating is in some states you could put a system that works better than OEM emissions, pass a sniffer test, but they would still fail it because you didn't use factory manifolds and cats. A shielded high flow cat might fool a visual because they look close to factory, but I'm sure the headers wouldn't.
Old 05-09-2020, 07:19 PM #9
Inv4drZm's Avatar
Inv4drZm's Avatar
Here's the pic.
Old 05-11-2020, 05:18 PM #10
Big thanks for the pics and responses guys! Ill look for a higher clearance bolt before installing as that seems like it will do the trick
bag , headers , limited , thorley , work
!!Doug Thorley Headers 4.7L V8!! BootyFister 4th Gen T4Rs 224 08-30-2022 09:12 PM
Installing Doug Thorley Headers on 2005 4.7L V8 w. 2" BL Cpt_Romania 4th Gen T4Rs 85 09-05-2021 05:22 PM
Doug Thorley Headers w/ or w/o EGR? DavidAlexander 3rd gen T4Rs 8 07-13-2016 10:57 PM
Thorley Headers on my 95? santanvalleydirt Engines / Suspension / Wheels / Tires / Audio / Accessories 0 03-08-2015 04:07 AM
