Old 05-06-2020, 01:22 PM #1
SHagood's Avatar
SHagood SHagood is offline
SHagood is just really nice SHagood is just really nice SHagood is just really nice SHagood is just really nice
SHagood's Avatar
4th Gen iPad/Tablet Mount
I do not take credit for this idea. My friend Trung has this in his 4th gen and I mirrored it after his setup.
I previously posted a few pictures of a recent mount that I installed in my dash for an iPad or a Tablet and received some inquiries on how I did it. So, here's how I did it:
Mounts
RAM base plate adapter-
Amazon.com: RAM Ball Adapter with AMPS Plate: Electronics
2 of these
RAM double socket arm-
Amazon.com: RAM Double Socket Arm: Automotive
RAM X-grip-
Amazon.com: RAM X-Grip Universal Holder for 9"-10" Tablets: Automotive
Go to the RAM website and it will help you figure out what iPad/tablet mount you will want. I picked this one and it works for me, but there are cheaper options that will still have the same function.
Steps
1. Take your dash apart.
-This is the first time I have ever done this without the help of someone else. It can seem intimidating at first, but literally all you need to do is take out three or four 10mm bolts. I am not going to list each step one-by-one, because it's all on this 7min YouTube video:
YouTube
It takes all of 15mins.
2. Line up your base plate adapter just under the hazard lights. I used a punch pin on one hole, drilled that one out, then bolted it to the dash. Then, I continued doing them one hole at a time until all 4 were done, while attempting to keep the base plate as straight as possible.
Here is what I used:
#10-32 x 3/4in Round Head Combo Machine Screws
#10-32 Stainless Nylon Lock Nuts
2 washers that fit (lol)
You have limited room on what backing you can use here, so I did two larger washers and two smaller washers. My buddy used a rectangular piece of steel for the backing, use whatever you can with the limited room. Obviously the stronger the backing, the better chances you have of how sturdy this is while driving on bumpy roads/trails.
3. Put it all back together, you're done.
Notes
Overall, this was not a difficult project at all. I would rate this a 1/10 difficulty, anyone can do this.
RAM website helps narrow down what actual iPad/tablet mount you will want.
2008 Urban Runner
MY BUILD THREAD
SHagood is offline   Reply With QuoteReply With Quote
Old 05-06-2020, 01:40 PM #2
smeister smeister is offline
smeister is on a distinguished road
Clean install man!
'03 4Runner Sport V6 4x4 Galactic Gray Mica with 340k+ miles
Lil B's Front Bumper | Dobinsons Long Travel | SCS Stealth 6 | 285/7r17 Wildpeaks C-Load | etc.
www.instagram.com/trungsnaps
smeister is offline   Reply With QuoteReply With Quote
Old 05-06-2020, 05:57 PM #3
mysticz's Avatar
mysticz mysticz is offline
mysticz has a spectacular aura about mysticz has a spectacular aura about
mysticz's Avatar
Looks great, I had a Proclip Ipad mount but only swap that in when I am on a off road trip. The rest of time I have the Garmin using that mount.
2005 T4R Silver SR5 V6 4wd with Mods.
mysticz is offline   Reply With QuoteReply With Quote
Old 05-06-2020, 06:37 PM #4
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
I was really considering one of those floor/seat bolted mounts... but this looks pretty good too.
Any testing off-road to see how it holds up to vibration or terrain chop?
From my experience 1" ball doesn't hold up that well with a bigger load when you start throwing it around. We are running larger diameter ball mounts in the sports side x side, but that also tends to be a much rougher high speed ride. We also had to reinforce the plastic bits for the ball adapter with some thinner metal plate to help with rigidity.
Old 05-06-2020, 08:18 PM #5
SHagood's Avatar
SHagood's Avatar
Haven't checked yet, I literally just did this on Monday. It seems incredibly sturdy, but I'll know for sure the next time I go on a ride and will update with findings.
Hope this helps.
2008 Urban Runner
MY BUILD THREAD
Old 05-06-2020, 08:51 PM #6
mysticz's Avatar
mysticz's Avatar
I have a RAM mount on the lower part of my center console for my ham radio setup and it handles everything its been through from high speeds in Pismo dunes to crawling the waterfalls up Big Bear.
Old 05-06-2020, 08:59 PM #7
Bumbo's Avatar
Bumbo's Avatar
@mysticz
Nice Kenwood, I have its little brother the TM-V71a I use at home as my crossband repeater.
Can I bother you for a few links to the mounting products you used?
Old 05-06-2020, 09:08 PM #8
mysticz's Avatar
mysticz's Avatar
@mysticz
I will find out and PM you cause I put this in 2006 so I have to go look for the info and if they even offer it.
Old 05-06-2020, 09:32 PM #9
SHagood's Avatar
SHagood's Avatar
Nasty setup man!
2008 Urban Runner
MY BUILD THREAD
Old 05-06-2020, 10:05 PM #10
mysticz's Avatar
mysticz's Avatar
Originally Posted by SHagood View Post
Nasty setup man!
Thanks!
Old 05-06-2020, 10:23 PM #11
jacinda jacinda is offline
jacinda is on a distinguished road
nice work
jacinda is offline   Reply With QuoteReply With Quote
Old 05-11-2020, 11:47 PM #12
SHagood's Avatar
SHagood's Avatar
Update on durability:
I have not driven off-road with it yet, but I did drive 2hrs 45mins to the other part of Florida today and back. 0 noticeable issues, one part around town had a road that was probably 1.5 miles and was bumpy as hell.
No complaints thus far. We are going on a trip to GA in two weeks, will update with the strength of this mount after that trip.
2008 Urban Runner
MY BUILD THREAD
Old 05-12-2020, 09:13 AM #13
15minprior 15minprior is offline
15minprior is on a distinguished road
I don't recommend the floor seat RAM mount, I currently have it set up to hold the head unit of the ID-5100a. It wobbles far too much and the only solution would be using a bracket to secure it to the center console but we'd be back to square one with drilling. If I were to do all over again, I would have just directly mounted a different RAM mount to the console.
15minprior is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 11:17 AM #14
ac1617 ac1617 is offline
ac1617 will become famous soon enough ac1617 will become famous soon enough
I did the exact same except I wasn't smart enough to buy nylon locking nuts (just regular nuts with threadlocker). I did however also buy the Ram mount double sided tape to add additional strength. Had it mounted for my entire trip to Alaska including driving the crater filled Dalton Highway without issues with my iPad Pro 11. I plan on installing a new double din next week so I'll swap out the nuts with nylon locking ones for added security.
ac1617 is offline   Reply With QuoteReply With Quote
Old 05-17-2020, 06:48 PM #15
BagiMT's Avatar
BagiMT BagiMT is offline
BagiMT will become famous soon enough
BagiMT's Avatar
RAM mount and charge port
This thread reminded me that I have been wanting to add a RAM mount to that location for a while. I also added a double USB port with a volt meter to charge the tablet without running long cables. I first saw that design by @rickashay
https://www.toyota-4runner.org/2590276-post16.html
There is no need to disassemble the whole dash. After taking out the HVAC controls you can drill the holes and put the screws in with the large cover piece in place. Much easier. I put a metal plate on the back to re-enforce the plastic a bit. Rock solid.
This is the charger I used:
https://www.amazon.com/gp/product/B07DGNQNLR/
4th Gen iPad/Tablet Mount-image1-jpg  4th Gen iPad/Tablet Mount-image1b-jpg  4th Gen iPad/Tablet Mount-image2-jpg  4th Gen iPad/Tablet Mount-image3-jpg
Black 2008 Sport V6 4WD | Toytec BOSS 3/2 | JBA UCA | BFG KO2 255/75/17 | Rocksteady Skids | White Knuckle Sliders | TJM Front Bumper | Superwinch
BagiMT is offline   Reply With QuoteReply With Quote
backing , mount , plate , ram , washers
Mount for Ipad/Tablet Bernardchan96 4th Gen T4Rs 1 04-11-2020 04:09 PM
Show me your Ipad/tablet mounts ( PIC THREAD) Signal 5th gen T4Rs 14 07-31-2019 12:07 AM
How did you mount your iPAD, Nexus 7, other Android Tablet ect? (PICTURES!!!) BrianSD_42 3rd gen T4Rs 47 12-31-2018 02:40 PM
Custom dash mount for phone, iphone, iPad, or tablet JMS87 5th gen T4Rs 20 03-24-2015 01:23 PM
tablet mount rick.deckard 5th gen T4Rs 11 07-21-2014 04:24 PM
