08-22-2010, 10:11 PM
Rear hatch opener melted!
Hey guys,
So I have noticed over the past few months that the rubber grip over the rear hatch opener button was getting sticky. I thought something got on it and didn't give it much attention. Well today when I went to open it my fingers sunk into it and I pulled my hand back covered in a sticky black goo. It was over 100 degrees here in Houston today and I guess the rubber button cover couldn't handle the heat. It has completely melted. Has anyone else had this problem? Does anyone know the part number to replace it?
Any info would be helpful.
Thanks
2007 4Runner Sport Edition V8 4x2 - Salsa Red Pearl
2.5/1.5 Daystar Lift
265/70/17 Revo's/Spidertrax/Graphite Sequoia Wheels
DDM 55w 5000K HID lows, Hoen Endurance Fogs
08-22-2010, 10:35 PM
It's probably just rotted or somehow the grease or some solvent leaked or the wiring got too hot and melted it. 100 degree heat should not melt rubber. That is really strange, though am curious to see if anyone else has had this problem.
2005 V8 4Runner 4X4 SR5, FJ TRD Bilstein Suspension, KO2s
2020 Mercedes GLE450
2014 Wrangler Rubicon, Synergy suspension + 35 MTRs + way too many mods
08-22-2010, 10:41 PM
not me at 112 in Las Vegas. Probably got some sort of solvent on there at some point.
08-22-2010, 10:42 PM
The same thing has happened to my wife's 2007 Sienna. I too think it is the heat. This has not happened to my 4runner but it is garaged during the day where as the Sienna is always outside.
08-22-2010, 10:49 PM
I know exactly what you're talking about. My rear hatch switch is doing the same thing, and apparently it's happening to others.
Check out this thread I started on Toyota120.com
Rear Hatch - Sticky Handle - Toyota 120 Platforms Forum
2007 SE V8 4WD
Black
20" Liquid Metal wheels w/ Michelin 275/55/20
08-23-2010, 08:01 PM
Ya I saw that, did you figure out if that 45 dollar part was correct? Right now I have tape on it to keep the sticky off my fingers...
08-25-2010, 01:29 PM
I hat eto revive an old thread. But this same problem is currently going on with my 4runner I have read both post. But there was never and solution posted on what needs to be done. If anyone fixed theres... Did you just get the part from the dealer? or is there somewhere else i can purchase it? If so do you have the part number and a place to buy it?
Thanks
2006 SE 4runner, Magnaflow, K&N Intake, Husky Front Liners, Blacked-Out Headlights, 255/75 R17 BFG Mud Terrains other than that stock..... for now.
08-26-2010, 03:39 PM
Sticky rear hatch opener
I have an 07 Sr5 and the same thing has happened to mine. I live in S. Florida and it gets crazy hot down here. I thought it was the heat also. I would like to change it out or something. Does anyone know if it could be switched out and how much?
Originally Posted by ZandT4R
Hey guys,
Thanks
08-26-2010, 08:13 PM
Noticed the same thing with mine - plenty hot. Went 90 days at or above 90! It is not so bad that I bothered looking at it. But do feel it getin worse. Anyone got a parts pix?
C O L E M A N F U
DAYTONA USA
04 4Runner 4x4 SR5, OME.
08-27-2010, 04:42 PM
according to the thread over on 120 drbiii backorderd the part from his local stealership and will post the part number when he gets it and confirms it is correct. I think he said its 60 bucks....
08-27-2010, 09:07 PM
That's correct. I reserved the part from my dealership. The parts manager told me he should be recieving them soon since they ordered a few of them about 3 weeks ago. He said the part was $59 and change.
I didn't get a chance to get the part number, but once I get the part in my possession I'm going to post the part # and hopefully and DIY for removing the switch and replacing it.
2007 SE V8 4WD
Black
08-30-2010, 07:04 PM
I have a 2008 Sport with 25K miles that has always been garage kept. I live in the DFW TX area and my hatch opener has also melted! I guess I should take it to the stealership for replacement since it is under factory warranty.
CURRENT: '14 Limited Mag Gray, '17 Limited Mag Gray, '19 Mercedes GLC300, '08 Urban Runner | SOLD: '96 4runner SR5, '08 Urban Runner, '14 Limited Blizzard Pearl
09-07-2010, 02:16 PM
Dealership is going to replace under warranty! - They said they had never seen that happen before.
09-07-2010, 04:22 PM
Sweet! Wish I was still under warranty....
09-07-2010, 04:55 PM
I also have this same problem with my 07, thanks for bringing this back up.
2007 4Runner Sport V6 4WD Shadow Mica, Tint, Extended differential breather, Carbon filter removed, Bilstein 5100s - 0 setting with Old Man Emu 884s, ToyTec Superflex coils and 5100s rear, Dobinsons UCAs, P265/70/17 Michelin Defender LTX M/S, Spidertrax, Xtreme Phillips 4300K HIDs, ICON Sway Bar Relocation Blocks
Former 1999 4Runner Highlander V6 4WD Black
