Old 05-07-2020, 10:06 PM #1
sstyota's Avatar
sstyota sstyota is offline
sstyota is on a distinguished road
sstyota's Avatar
What on earth is this sound?
It's coming from the rear wheel/tire area. Sound speeds up when accelerating and slows down when decelerating.
squeek.m4a - Google Drive
2008 4runner Limited v8 Shadow Mica Stock @ ~58K miles.
Future Mods: Pioneer 9" Headunit for CarPlay Wireless (CES 2020, release date 3/20) and upgraded sound system; Noise cancelling material (4 doors); Doug Thorley Headers and all that exhaust stuff (assuming I can pass Denver inspections); 2.5-3" suspension lift for mountain trails. If I ever have money to burn, I'll supercharge it
sstyota is offline   Reply With QuoteReply With Quote
Old 05-08-2020, 12:11 AM #2
Jpilot Jpilot is offline
Real Name: Joe
Jpilot will become famous soon enough Jpilot will become famous soon enough
Real Name: Joe
Sounds like
Sounds like a sticky brake caliper, rubbing the rotor. Drive the truck a bit and then see if you can tell a difference in the temp of the rotors R vs L, then see if you can tell a temp difference in the bearings.
Jpilot is offline   Reply With QuoteReply With Quote
Old 05-08-2020, 02:46 AM #3
dalandshark's Avatar
dalandshark dalandshark is offline
dalandshark is on a distinguished road
What have you checked so far? Brake squealer maybe or rock stuck between disc and shield?.
2003 4runner sport (V8, RWD, Mostly Stock)
dalandshark is offline   Reply With QuoteReply With Quote
Old 05-08-2020, 01:29 PM #4
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Brakes / frozen caliper or perhaps wheel bearings?
Squealer is a good guess. I would also check calipers with an IR thermometer. If you see a temp difference between L & R after some driving that is how I checked.
Wheel bearings I don't have experience with. Just a guess.
Old 05-08-2020, 02:41 PM #5
sstyota's Avatar
sstyota's Avatar
Thanks for the ideas. I am going to look into it more this afternoon with that In mind. I’ll report back!
Old 05-09-2020, 10:44 PM #6
Nahrah's Avatar
Nahrah Nahrah is offline
Nahrah will become famous soon enough Nahrah will become famous soon enough
Nahrah's Avatar
Did you replace the rear rotors recently? If you didn't back off the parking brake you can damage the hardware and cause one of the holding pin to stretch and hit the hub.
Current - 21 TRD ORP, Method 316 on 285/75/17 Toyo MT, Bilstein 5100’s OME 885/889, Spc UCA
Old(still in the family) - 07 Sr5 V6 2wd, Bilstein 5100's, Ome 884/895e, TRD ORP wheels, SPC UCA and CBI front skid plate.
Nahrah is offline   Reply With QuoteReply With Quote
Old 10-15-2020, 04:01 PM #7
sstyota's Avatar
sstyota's Avatar
You found the issue!!!
I had been meaning to bump this post with what I found out was the cause.
I had hit a newly constructed stuffed curb last winter with the rear wheel and that apparently damaged the parking break hardware and that caused the squeaking as well as VSC and parking lights coming on at certain speeds while headlights were on.
Toyota replaced the rotors and parking brake hardware and that solved the issue! Not cheap unfortunately.
accelerating , area , decelerating , slows , sound
Earth to Sky BackOff Off Topic 2 08-13-2019 10:41 PM
Fastest Man on Earth NoDak Off Topic 1 07-04-2014 02:00 AM
What on earth is that SUPER LOUD SOUND?!?!? 2014 Warthog 5th gen T4Rs 23 05-19-2014 10:47 PM
Greetings from Planet Earth! ShockTherapy New Members 11 06-27-2011 05:27 PM
Google Earth BenSD 4th Gen T4Rs 2 08-17-2005 10:19 PM
