Originally Posted by daprotege5
any suggestions for putting the sealant on the cover??? just from how you have to angle it, i was thinking might be better to put the sealant on the engine side first.... just found it weird that those two bolts on the bottom are there, would be much easier to seal the cover if you didnt have to slide the bottom into those bolts.
That bit was a pain. I took three attempts (which meant cleaning up wet FIPG twice) before I was happy with it. Was awhile ago now so honestly can't remember precisely how we did it, but I think I did get a very small amount of gasket maker and held the O-ring in place in the cover when I did it. Obviously, the way the engine was originally put together was that the sump went on last, so this isn't normally an issue. We're just trying to take a short-cut here.
The FIPG box says that you have like 2-3 minutes to mate the surfaces up. Honestly, it took us more like 5 minutes to get the timing cover FIPG on (especially as you need to apply two FIPGs - one for the water inlets and one for the outside seal), and you don't want to miss anything. Then it probably took us about 5 minutes to be confident that it had mated up well and we hadn't lost the O ring, and another 5-10 minutes to get everything torqued up. And it sealed perfect and haven't had an issue. So don't rush it because of the drying time (but I wouldn't do this job in dry heat either - I think it was a cooler, rainy day when we did it which would have extended drying time).
Last thing I remember doing is trying to put the timing cover on on a slight angle so that the O ring was the last thing to mate. It's a bit hard because the studs limit the angle you can get. Also, put a smidgen of oil on the sump cover where the O-ring is going to slide. Think it through though, because you don't want the oil mixing much with the FIPG. Just the tiniest amount to help it slide and not grab. Don't put it on the O ring because then it will smudge some oil in front of the FIPG and mess up the bonding.
Good luck! If I ever do the job again, I may consider dropping the sump (but that is a big job in itself as from memory the diff may have to come out). Fingers crossed this job lasts the rest of the life of the engine though - just make sure you really fill that gap in the timing cover properly so it doesn't leak again.
