Old 05-11-2020, 05:38 PM #1
JBend JBend is offline
JBend will become famous soon enough
JBL sub enclosure
Was wondering if anyone has installed the JBL stock sub enclosure into a non-JBL 4runner.
1.) Does that enclosure have a mounting spot for an amp?
2.) If so how easy/snug of a fit is it.
3.)what size sub does it hold?
Thanks
JBend is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 08:24 AM #2
JVC8790's Avatar
JVC8790 JVC8790 is offline
Real Name: John
JVC8790 has a spectacular aura about JVC8790 has a spectacular aura about JVC8790 has a spectacular aura about
JVC8790's Avatar
Real Name: John
Thanks
Lots of people have, here are some answers from someone that has a JBL stock system.
1. Yes, there is a flat portion on the left side of the enclosure that holds the normal stock JBL amp. You could easily run a micro-amp in that space for just a sub.
2. It fits nicely into the 4Runner since it was made for it, you will want to source the plastic panel in front of it that has a speaker grille as well, otherwise your options are to remove that panel and it will look kinda unfinished, or install your own speaker grille.
3. You'll want an 8" shallow mount sub. Depending on the sub, you may have to trim some of the inside of the box, but that can easily be done with some tin snips/dremel.
I have pics of my sub swap (in factory housing) in my build thread in my signature, a quick search will turn up lots of similar threads of people swapping theirs.
2004 4Runner V8 Limited - TRD Exhaust, LED Interior Swap, Pioneer HU, Tacoma TRD Front Suspension, FJ Rear Springs, 10" + 32" Light Bars, Prius Shift Knob, 275/65R18 Falken Wildpeak, 18x9 Level 8 MK6 Et0, GOBI Ladder, 06-09 Headlight Swap, TOTALED NOV 2019, RESURRECTED APR 2020 Build Thread
1998 Volvo S70 T5 - Custom Airlift Suspension, BBS Nebula Wheels, Brada Seats, Engine Bolt Ons - StanceWorks Build Thread
2010 Subaru Forester 2.5X - Wifes Car
JVC8790 is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 04:41 PM #3
Awesome. Thank you so much. I'm still super new to this forum and am finding it to be difficult to get accurate search results for what I want some times. I tried looking and found myself 7 pages deep of threads and still no real answer. I know it's out there, just can't seem to find it. I appreciate it.
Old 05-13-2020, 07:42 PM #4
stormrunner925 stormrunner925 is offline
stormrunner925 is on a distinguished road
Hey man another option is using a wood spacer and trimming the ribs inside the box. I did this and fit an alpine type r 8" in there after the aftermarket pioneer shallow mount sub blew. Much better sound quality with the alpine and worth the effort
stormrunner925 is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 11:09 PM #5
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
This video will show you a lot. Some trimming may be required to make the amp fit. 8-inch sub. Plenty of options out there.
2003 - 2009 Toyota 4runner 4 Channel Amp and Sub Install - YouTube
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 01:40 PM #6
hankd's Avatar
hankd hankd is offline
Real Name: Harry
hankd is on a distinguished road
hankd's Avatar
Real Name: Harry
i've just got the base sr5 with the stock stereo and i'd love to have a sub somewhere. it's one of the few things i've had trouble searching for - usually my search results come up for other gens.
has anybody successfully installed one of those compact powered subs under a front seat? or maybe installed a sub and amp into the rear panel on a vehicle that didn't come with a factory sub?
hankd is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 02:32 PM #7
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
The video I linked in the post above shows how to install a sub in the factory location in a vehicle not equipped with one.
Old 01-05-2021, 10:07 PM #8
JH225 JH225 is offline
JH225 is on a distinguished road
If you’re picky about it, the stock subwoofer box has an internal volume of 0.415 cubic feet.
The stock amp is pretty small in terms of physical size, so do your homework about amplifier dimensions. Also keep in mind that a little bit of power goes a long way. 300 watts will probably get you where you want to be.
JH225 is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 10:21 PM #9
As far as one of the compact sub/amp combos, there’s actually some room behind the rear panel you can work with.
Here’s some pics of my amplifier setup. I didn’t have a stock sub. I had to cut that plastic tray off the back of that panel. I have 2 Rockford 4-channel amps (fully active front and rear) with a DSR1 digital signal processor. I fabricated brackets and mounting for everything.
If you look to the right of my amplifier mounting plate, there’s all this empty space. I was considering adding one of those amp/sub all in one combos, so I did the measurements. Most of them on the market are 9”x14”x3” and if you’re willing to make a custom bracket, it can definitely fit. I didn’t go this route because I wanted to fit both of my 4 channel amps and it was a LOT easier to spread out the 4 channel amps. I ended up without enough room for the sub.
Old 11-27-2023, 10:27 PM #10
damon323 damon323 is offline
damon323 is on a distinguished road
I hope you get this message man, it’s been a few years since you posted this. You had to use a wood spacer to get the Alpine Type R to fit? I’m looking at putting a Gen 2 Type R in there.
damon323 is offline   Reply With QuoteReply With Quote
Old 11-28-2023, 01:32 AM #11
So you are certain on the JBL sub enclosure is .415 cubic ft? Had a guy on Reddit say it was closer to 1 cubic ft. Mentioned that he filled it with water and weighed or something. Lol! Not even joking. Where did you get that .415 from? Spec sheet?
Old 11-28-2023, 06:26 PM #12
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
Chances of a reply are pretty low as neither of these members has been active for awhile.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
amp , easy/snug , enclosure , fit , jbl
CA: 4th Gen Sub Enclosure hgill For Sale: T4R Items 1 09-05-2019 12:21 AM
WTB JBL sub enclosure 4th gen Antoddio Want to Buy/Trade 0 10-27-2015 08:42 AM
WTB 4th Gen JBL enclosure fullboogie Want to Buy/Trade 0 10-07-2015 06:12 PM
WTB: 4th Gen JBL Sub Enclosure dodnof Want to Buy/Trade 1 09-20-2011 05:29 PM
