Old 05-13-2020, 12:05 AM #1
Jclason.neuro1 Jclason.neuro1 is offline
Jclason.neuro1 is on a distinguished road
front differential clunk
So I have spent some time reading through different threads trying to diagnose what is wrong in my front diff but I haven't been able to figure it out.
I have a clunk that occurs when shift from drive to reverse or reverse to drive. It is just one clunk. When I put my 4runner in 4 Low, the clunk comes on when driving forward every 5-10 seconds when I am going about 5 mph. It started after I replaced my OEM CV axles with Napa CVs. I know it is in the front and probably has something to do with the CVs but I am not sure what it could be. There isn't any clunks when I jack my car up and spin the tires. No leaks from the front dif and I regreased the driveshafts as well. The CVs don't have any play in them either. I was wondering if my front U joint happened to come to the end of its life at the same time I replaced my axles. Any ideas? Thanks!
Jclason.neuro1 is offline   Reply With QuoteReply With Quote
Old 05-13-2020, 08:29 AM #2
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
Would be helpful to include your vehicle details.
You sure it's in the driveline?
the 4th gen calipers/pads make a clunk often when switching from R/D and vice versa.
That wouldn't explain what you are hearing in 4L but it could also be something with the axles binding. Are you typically just driving straight?
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 05-13-2020, 09:47 AM #3
Piggity Piggity is offline
Piggity will become famous soon enough
Ya, we need to know if its a V6 or V8. Did you do any fluid changes at the same time during the CV change?
Past: 06' Limited 4WD V6 Nautical Blue Metallic
265/65R18 Cooper A/TW tires with TT - 2018 Forest River 201BHXL
Present: 08' Tundra Limited
33" Duratrac, spacer Lift with TT - 2022 Keystone 252RD
Piggity is offline   Reply With QuoteReply With Quote
Old 06-08-2020, 11:23 PM #4
2004 v8. I did change the fluids and double checked that the fluid is at the proper level. I have checked the brakes before and there is nothing I can see that is wrong with those. I went for a pretty long offroad drive this past weekend. Clunking is still there but its not effecting my ability to get over and through obstacles. I am wondering if the CV just isn't made to the same tight dimensions that a OEM CV is.
Old 06-09-2020, 09:29 PM #5
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
Is the clunk in question coming from either side of the vehicle? Or is it specific to only driver or only passenger?
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 06-10-2020, 11:39 AM #6
spdrcr29's Avatar
spdrcr29 spdrcr29 is offline
spdrcr29 is on a distinguished road
spdrcr29's Avatar
Hmmm...Think i've got the same issue going on. Bought my 4Runner last November, but the front diff was bad when i got it. Replaced the front diff with a brand new one from the Toyota dealer. "While at it", I also replaced both CV avles, front calipers, pads, and rotors; all from Napa. Since then, i've been noticing a single clunk or pop type noise that is coming from the front end. Almost always happens first thing in the morning when backing out of my driveway and then shifting to drive. Some random mornings, it doesn't do it at all. When it does do it, it always does it on the change of direction and will only do it one time. Usually never does it the rest of the day unless it sits for a longer period of time. Sometimes the noise sounds like its coming from the driver side and other times the passenger side. I was thinking that maybe its simply brake pad shift causing the noise when changing directions, but really not sure and I've honestly done nothing to look into it any further. It does drive me nuts though! If I actually take some time to look into it and figure something out, i'll let you know...
spdrcr29 is offline   Reply With QuoteReply With Quote
axles , clunk , cvs , front , replaced
Center differential + rear differential + front differential = confusion! badburro 5th gen T4Rs 37 01-29-2019 12:40 PM
Front end clunk what could it be? V8 4WD K_Labs 4th Gen T4Rs 49 12-01-2017 05:46 AM
WTB: Transfer case, front differential, front axles for 1st gen 1989 V6 5-speed Entropy85 Want to Buy/Trade 0 05-26-2014 10:52 AM
Help - Clunk from Rear Differential Four-CLT 3rd gen T4Rs 22 05-24-2013 01:54 PM
Clunk from the front? ICallHimGamblor Problems & Warranty Issues 2 12-22-2007 01:41 PM
