Originally Posted by MY06T4R
Parts needed
1 Mercedes E320 engine fan
1 Painless performance 185 on 175 off fan switch part #30111
1 Auto Meter radiator hose sensor adaptor part #2283
10' 8 gauge red wire
10' 8 gauge black wire
1 Toyota 4 pin relay with big spades
10' wire loom from harbor freight
1 fail-safe 170 degree thermostat part# 7302-170
1 felt pro thermostat gasket part # 35555
1 15 amp mini fuse
2 gallons of antifreeze
4 3/8 nuts
15' of 18 gauge wire
2 National Hardware® 5" x 7/8" Zinc Flat Corner Brace
Model Number: N234-955
2 National Hardware® 4" x 5/8" Mending Braces
Model Number: N272-732
10 zip ties
1 pack of washers Grip Fast® 1/4" Grade 8 Zinc Flat Washer - 93 Count
Model Number: G8FW14-93
1 pack of lock washers Grip Fast® 1/4" Grade 8 Zinc Split Lock Washers - 93 Count
Model Number: G8LW14-93BB
1 pack of bolts Grip Fast® 1/4"-20 x 2" Zinc Grade 8 Hex Bolt - 16 Count
Model Number: G8HB142-16
1 pack of nuts Grip Fast® 1/4"-20 Yellow Zinc Grade 8 Coarse Thread Hex Nut - 54 Count
Model Number: G8HN14-54
1 10 gauge wire end loop for ground
Optional Parts
1 can of Rust-Oleum, Cherry Red 252459 Automotive 12-Ounce Enamel Spray Paint
1 Denso radiator part#221-3124
I used the pre-wired air suspension relay location and 50 amp under hood fuse, I ran a 18 gauge wire to the inside and used a blank fuse location that was ignition on and a 15 amp fuse. I ran the fan ground wire to the battery.
Here is a link to the video showing the duty cycle of this fan and how quick it cools the coolant down. I just uploaded it a few minutes ago.
YouTube
This is not going to work and you will have to remove it. I tried this exact setup years ago and this MBZ fan was not strong enough to cool the engine while towing or crawling. Driving around town was fine but this fan still had much less cooling capacity than the fan from an MBZ S600, even that fan wasn't enough for high engine loads. I think you are wasting your time and losing power by installing this.
FYI - CFD calcs on the factory fan are 10,000cfm. Have you done CFD for this fan or discovered its max CFM?
