Old 05-16-2020, 01:53 PM #1
mderienzo's Avatar
mderienzo mderienzo is offline
mderienzo is an unknown quantity at this point
mderienzo's Avatar
Unplugged 4WD switch, now stuck in 4Hi
I'm hoping someone has experienced this before and solved it.
While installing a new radio in my 2007 SR5, I unplugged the 4WD switch while the ignition was on by mistake. Now the 4Runner is in 4Hi (indicated and it really is) and the switch has no effect. I currently have the battery unplugged, hoping the system will forget my mistake but I don't have much confidence that this will work. The radio installed is a Scion T10015 using adapter cables from Toyota so I did not mess with any factory wiring.
Besides having a dealer reset the 4WD system, is there anything else I should try?
Thanks in advance!
Mark
mderienzo is offline   Reply With QuoteReply With Quote
Old 05-16-2020, 03:48 PM #2
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Thanks in advance!
Mark
Are you certain that the plug is fully seated in the switch receptacle? If it’s not quite in, the switch will not work.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 05-16-2020, 04:31 PM #3
mderienzo's Avatar
mderienzo's Avatar
Thanks - Yup the connector is fully seated. I just reseated it and it clicked into place. Still in 4WD Hi no matter I do with the switch.
Old 05-16-2020, 05:25 PM #4
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
To Bluesky's point, I've seen multiple people have the same issue that was the result of a bent pin on the plug, so be sure it's good-to-go. And you're sure it's actually in 4Hi?
eleven14 is offline   Reply With QuoteReply With Quote
Old 05-16-2020, 05:49 PM #5
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
I’m in the same boat. Worked on my stereo last night and unplugged the front panel. While the key was on and unplugged it showed 4Hi, once plugged back in shows 4Hi still on. I’ll mess with it some more and check the plug as well.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 05-16-2020, 07:17 PM #6
KrisB410 KrisB410 is offline
KrisB410 is on a distinguished road
Same happened to me, ended up a bent pin on the 4wd selector switch. Straighten the pin with a small needle nose pliers. Plugged back in, and success.
Sent from my SM-G965U using Tapatalk
KrisB410 is offline   Reply With QuoteReply With Quote
Old 05-16-2020, 07:36 PM #7
mderienzo's Avatar
mderienzo's Avatar
Mine is fixed! Turned out to be a bent pin on the switch not making contact. Thanks for the help!
Mark
4wd , mistake , switch , system , unplugged
P2441, Secondary Air Injection System Switch Valve Stuck Closed (Bank 1) 71gs3504sp 5th gen T4Rs 8 09-28-2020 10:55 PM
My ignition switch is stuck (won't turn) 00 4runner airmax233 3rd gen T4Rs 28 01-25-2020 03:01 PM
Unplugged TPS, no CEL? 4runjunkie Classic T4Rs 4 03-12-2013 09:35 PM
Fog lights stuck on with switch off. Where's the relay? Jon 3rd gen T4Rs 4 01-11-2013 10:50 AM
Stuck in Park -Brake Switch Faulty? supergooch Classic T4Rs 1 01-09-2009 01:05 PM
