Old 05-16-2020, 02:08 PM #1
atalarico's Avatar
atalarico atalarico is offline
atalarico will become famous soon enough
atalarico's Avatar
5th Gen Power Stop Z36 kit
Hey all,
Previous owner said he did a 5th gen brake upgrade, and I had to replace the front calipers he used because of seized pistons last year. The rear calipers looked fine, but I replaced the fronts with these Power Stops S6278 which are for a 5th Gen.
I need new rotors and figured I'd go big (live in CO, so lots of mountain driving) and get these Power Stop Z36 front and rear setup. Just want to make sure they're good to go, and shouldn't have issues with the calipers.
Reviews are mixed, but I guess I also just want to double-check before I pull the trigger in case there's some weird fitment issue I'm not thinking of here.
2004 Sport Edition V8. 3" OME lift. 5th Gen Brakes. 285/70 Duratracs. JBA UCAs. SCS Ray10s. DT Headers.
1997 4-Runner Limited w/ factory locker. Totaled in February 2018. Still miss it.
atalarico is offline   Reply With QuoteReply With Quote
Old 05-16-2020, 02:19 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Originally Posted by atalarico View Post
Hey all,
Reviews are decent, but I guess I just want to double-check before I pull the trigger in case there's some weird fitment issue I'm not thinking of here.
If that rotor kit is for 5th Gens you may experience issues with the rear rotors not being exactly centered because the rear rotor for the 5th Gens have a larger center/hub hole which has for some members on here allowed the rotor/s to be slightly off centered which causes the parking brakes to drag, even if you are lucky enough to get both rears installed perfectly centered on first try if you ever have to remove either rear tire the rotor could get off centered since the tire being installed would be the only thing that was keeping them centered.
Haven't heard anything bad about the Power Stop rotors, but I would buy the fronts and rears separately to avoid issues on the rears.
2004 Limited V8
Old 05-16-2020, 02:30 PM #3
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Originally Posted by AuSeeker View Post
If that rotor kit is for 5th Gens you may experience issues with the rear rotors not being exactly centered because the rear rotor for the 5th Gens have a larger center/hub hole which has for some members on here allowed the rotor/s to be slightly off centered which causes the parking brakes to drag.
Both generation rear rotors are the same diameter and thickness but different hub bore. But the 4th-gen rear calipers actually have larger pistons than the 5th-gen, 2" vs 1.89". Same brake pads too.
All specs taken from Raybestos Brakes' website
Old 05-16-2020, 02:43 PM #4
atalarico's Avatar
atalarico's Avatar
Good advice then! Glad I didn't hit buy. I was going to pass on that kit anyway I've been reading that drilled/slotted for off-road use are a no-no because of debris getting caught in them.
I'm thinking of just doing:
FRONT:
5th Gen Centric Fronts These
or
5th Gen Raybestos 980784
or
RAYBESTOS 980784PER
REAR:
4th Gen Centric Rears CENTRIC 12044128
or
4th Gen Raybestos 96929 rears
Thoughts on those? Centrics come up a lot for a good OEM style replacement. I need something good though since I'm driving down long stretches of steep grades on mountain highways here.
As for pads, Akebono all around. Sounds like it doesn't matter if they're 4th or 5th gen pads then since they're the same size. Am I reading that right?
Old 05-16-2020, 03:11 PM #5
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
I found that out too about the drilled and slotted feature can trap dust and mud which actually creates more heat, which I did notice after several trail rides. So I buy the Z36 pads and use the Z24 rotors and have been happy with them. Just can't get the good price on the full Z36 kit when it comes along. @Ed_C good stuff, didn't know that about the Calipers.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
5th , calipers , front , gen , power
TBU Power Stop Z36 or Z23? swampy_swimmer 3rd gen T4Rs 12 11-09-2022 07:42 AM
Power Stop Z23 v z36 pads (on oem rotors?) gn9119 4th Gen T4Rs 5 01-19-2020 11:43 PM
power stop Z36 WRENCHHEAD 4th Gen T4Rs 8 09-12-2018 07:33 PM
Power stop brakes for third gen dgherfurth General Discussions 10 10-07-2016 03:00 PM
Power Stop brake kit Cygan1008 4th Gen T4Rs 8 08-16-2014 08:04 PM
