Old 05-17-2020, 01:29 PM #1
Texas_4Runner Texas_4Runner is offline
Texas_4Runner is on a distinguished road
Rear Sagging 2008 V8 4x4 LTD
Forgive me but I’ve used the search feature and read write ups until my head hurt and I’m still not sure what to do.
I bought this truck 3 years ago. The previous owner had pulled both the XREAS and RAS and swapped it for Bilsteins and FJ Springs.
I noticed a bit of sag anytime I put a lot of gear in the back. It wasn’t terrible but it was noticeable. I recently bought a 2500 lb Casita travel trailer and I’m not happy with the rear end. It sags too much and a noise comes from the rear until I hit the off button on the ride height. I’m assuming it’s trying to inflate the nonexistent air bags.
1) should I upgrade the entire suspension?
2) is there a modification I could do to the rear end shocks or springs?
3) can I add RAS with the current set up?
Thanks. And I apologize for my lack of suspension knowledge up front.
2008 V8 LTD
Texas_4Runner is offline   Reply With QuoteReply With Quote
Old 05-17-2020, 01:36 PM #2
IMG_9102.PNG - Google Drive
Picture of the current rear setup.
2008 V8 LTD
Old 05-17-2020, 03:27 PM #3
camryn.samples's Avatar
camryn.samples camryn.samples is offline
camryn.samples is on a distinguished road
You might need new coils
I would invest and get a heavy duty coil I’m not really sure about the shocks I would say if you have shocks with 50,000 or more miles on them replace them.
camryn.samples is offline   Reply With QuoteReply With Quote
Old 05-17-2020, 08:56 PM #4
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Yea - would defintely start with rear springs - old man emu, dobinsons, toytech some options to start looking at
Old 05-18-2020, 12:28 AM #5
Thebeastlives Thebeastlives is offline
Thebeastlives has a spectacular aura about Thebeastlives has a spectacular aura about
Sagging under load is a common issue with a 4 runner and the best fix is airbags. That way you don't have to sacrifice your suspension ride with stiffer springs. You can adjust your ride height according to the load you place in your truck and the trailer you are towing.
Thebeastlives is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 07:41 AM #6
Direwolf82 Direwolf82 is offline
Direwolf82 will become famous soon enough
Agreed, airbags are the way for coil springs and changing load weights. My RAS system has been great both light offroading and towing.
Edit,
Get an aftermarket airbag helper set and hook it up to the existing compressor, adjust the ride height sensor for whatever height you want to sit at and call it a day. It will automatically level your truck to whatever you want it to be regardless of trailer or load weight, I would just try to find some working pressures on the compressor and bags to make sure they are compatible but in theory it should be fine no matter what. I'm just guessing this would work, it's what I'm going to do at some point when I get mine lifted but still need to tow with it so I'm very confident of being able to make it work.
Direwolf82 is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 09:55 AM #7
Thanks for the replies.
I was hesitant to put stiffer springs on since I only tow a fraction of the time. I think I’ll try the RAS route but I didn’t know if it could work the same after the previous owner pulled then XREAS.
2008 V8 LTD
Old 05-18-2020, 05:21 PM #8
I used airbags on my tundra for 10 years no compressor just use standard air pump to pump them up. Manual systems work forever with nothing to fail on you.. I might tow twice a year so nothing to worry bout in between times.
Old 05-18-2020, 06:34 PM #9
I didn’t even know that manual was an option. Thanks.
2008 V8 LTD
bought , i’m , rear , springs , suspension
Sagging Rear BackpackingDad 5th gen T4Rs 24 08-15-2016 09:47 AM
sagging rear collinlemasters Classic T4Rs 2 05-25-2015 01:05 PM
sagging rear end smithoman Classic T4Rs 3 10-20-2008 08:56 PM
The old sagging rear end..... bryanintexas 3rd gen T4Rs 4 01-25-2008 01:44 PM
Rear end sagging Crosman451 Classic T4Rs 4 12-07-2006 08:49 PM
