Originally Posted by MikeT4R
Installing some icon 2.5 coilovers with king e300-14-600 springs. Anyone have a suggestion on preload? Should I stick with icons 2.13"?
How much lift do you want? How much lift do you have in the rear?
Preload does the same exact thing as adding a spacer, spacing the spring away from the frame.
You can adjust preload fairly easily on the truck if you don't have remote reservoirs blocking the wrench.
2005 4R Sport 4WD
"The last of the V8s!" - Custom TIG'd SS Dual Exhaust - King 2.5" +2 LT. - ARB Front & Rear - 37's - Dana 60 -
Build Thread
1977 Celica Liftback - LFX Swap -
Build Thread
