Old 05-19-2020, 03:01 AM #1
Catahoulabulldog Catahoulabulldog is offline
Catahoulabulldog is on a distinguished road
Suspension question
I have the Bilstein 5100’s on my 06 V-8 Limited 4WD and used my OEM springs and I’ve decided to upgrade my springs. What should I go with? Right now I’m looking at the Toytec/Eibach front springs and Toytec Superflex rears. I’m also wanting to upgrade my UCA’s and looking at the SPC’s. From what I understand if I upgrade my springs I don’t want to use the height adjustment on the 5100’s? Any ideas on the springs and what to go with and the UCA’s? Whatever I go with I still want that level look without the front droop and upgrade my off road ability a bit. Any help is appreciated. Thank you.
Catahoulabulldog is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 08:43 AM #2
Syr4RinNC's Avatar
Syr4RinNC will become famous soon enough
Syr4RinNC's Avatar
So I suggest looking through the threads on "lift and tire central" in the 4th gen section as well as '4th gen suspension options"
Theres too many details wed need to make recommendations IE - what lift do you want, what size tires do you want to run, how much weight do you carry or tow occasionally or regularly
Lots of people are willing to sell you springs, so do some research and know what your end result goal is
the front bilstein setting also depends on the lift youre looking for and the height of the coil overs. IE you can get 2 inch taller coils and put bilstein at lowest perch if you want a 2'' lift or you can can get stock sized springs and put bilstein at the 1.75 perch
2008 SR5 4WD Black. Bilstein 5100, 5th gen coils/ rear springs. 265 70 17 AT for everyday use. Back up camera install. Expert at replacement rear hatches
Old 05-19-2020, 03:43 PM #3
I would be running the stock 18 inch wheels with my Nitto Ridge Grapplers. Iím wanting just a 2Ē-2.5Ē lift nothing crazy. Weight would be a few hundred pounds of gear and towing would be an A-liner A frame pop up camper which would be connected to the back quite a bit since next year the wife and I are hitting the road full time.
Old 05-19-2020, 04:08 PM #4
Bossman's Avatar
Bossman Bossman is offline
Bossman is a jewel in the rough Bossman is a jewel in the rough Bossman is a jewel in the rough
Bossman's Avatar
4th Gen Suspension Options/FAQ
Bilstein 5100's, stock front springs, Toytec superflex rear
V8 Bilstein 5100 2.5" front and Toytec Superflex rear???
Bilstein 5100s with FJ Springs Front and Toytec Superflex Rear, Bad Combo?
Superflex rear springs, how much lift?
Superflex HD Spring Issue??
SPC Light Racing UCA
SPC or Icon UCA?
Summer: Michelin Premier LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 06:35 PM #5
Ok great readings! From what I gather 885 OME and Toytec rear Superflex coils make a good combo? SPC UCAís have a history of unreliability so I will go with either Icon UCAís or total chaos.
Old 05-20-2020, 02:03 AM #6
So with the OME 885ís are they specifically for extra weight in the front compared to the 884ís?
Old 05-20-2020, 10:35 AM #7
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Correct - about 200 pounds, which you may or may not notice without weight
Old 05-20-2020, 04:46 PM #8
Ok so the 884ís would be a good choice then?
front , iím , springs , ucaís , upgrade
Question about FJ suspension swap (not a common question) cacarbuff 4th Gen T4Rs 2 02-18-2014 10:37 PM
New to me 97 SR5 - suspension question NSX JR 3rd gen T4Rs 1 10-10-2012 10:35 AM
Air suspension question JosephD05 4th Gen T4Rs 8 05-02-2008 02:56 PM
2nd gen vs 3rd gen suspension question MCE 4th Gen T4Rs 0 03-01-2004 11:47 PM
suspension question? pdx-97runner Engines / Suspension / Wheels / Tires / Audio / Accessories 6 01-15-2004 02:18 AM
