Old 05-31-2020, 03:20 PM #1
anonymousgromers's Avatar
anonymousgromers anonymousgromers is offline
Real Name: Brody
anonymousgromers is on a distinguished road
Real Name: Brody
transfer case leak?
hey guys i noticed this weird leak on my transfer case and after some research it appears to be a output shaft but it can also possibly be the actuator. what do you guys think?
2004 Toyota 4Runner Limited 4.7L V8 | Practically stock | Gibson cat back exhaust
anonymousgromers is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 08:48 AM #2
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
You may have to start with some cleaning to determine the area of the leak. Unless its clearly coming from somewhere, it may be hard to tell with that amount of fluid on the outside. Start by cleaning it off with some brake cleaner, dish soap, and a small brush to agitate the surface. All the fins and such make it a pain to clean, but it will be worth it to see where the leak actually is coming from.
If it does end up being the output seal, and there's a pretty good timmy the toolman video on replacing the seal on a 3rd gen. Mine has a really slow leak from there, so I'll be working on that eventually/
y=mx+b is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 11:29 AM #3
Real Name: Brody
Real Name: Brody
yeah I cleaned up the area last night while greasing the driveshaft I hope its just the output shaft and not anything crazy expensive.
Old 06-01-2020, 12:03 PM #4
joshik joshik is offline
joshik will become famous soon enough
Could possibly be a bad seal from the t-case actuator. Mine is doing that and it is a known issue and end up leaking because of a poorly design o-ring seal.
Hopefully it isn't that. It isn't the end of the world if it's a slow leak. I just check my tcase fluid levels often. I did find that I only have to fill not even a quart every few months. From my initial research it is an expensive fix from the dealer or a cheap one if you DIY.
IIRC, dealer will charge upwards of 2K because they want to replace the whole actuator + labor.
DIY is $8 for an oring plus the time and effort to drop the tranny and tcase. You can't get the actuator off without splitting the tcase.
2003 4Runner Limited 4wd V8. JBA UCA, Dobinsons MRA Front Coilovers, Dobinsons MRA Long Travel rear. Cooper AT3 XLT 285/70R17
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. [SOLD]
joshik is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 02:51 PM #5
Real Name: Brody
Real Name: Brody
yeah that's what I heard as well, I hope its not that but I plan on replacing the front/rear diff and transfer case fluids soon.
case , guys , leak , output , transfer
Oil Leak - transfer case?? tollboothwilley 4th Gen T4Rs 17 02-14-2022 01:39 PM
Transfer case leak batwood034runner 4th Gen T4Rs 3 02-15-2015 08:51 PM
Transfer Case Leak Jdrum1 Classic T4Rs 1 08-21-2013 11:13 PM
Transfer Case Leak jsmarine 3rd gen T4Rs 41 11-28-2011 10:25 PM
