Old 05-20-2020, 12:27 PM #1
Dergibog Dergibog is offline
Dergibog is on a distinguished road
2004 Sport Edition V8 - Subwoofer
Anyone ever pull this out and replace it with a factory unit? Any issues with that?
2004 Sport Edition V8 - Subwoofer-sub-jpg
Dergibog is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 01:13 PM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Replaced JBL Sub/Added Amp: Install Pics/Info
How to: access and remove the subwoofer
Options for replacing stock JBL subwoofer in 2004 Limited
JBL Synthesis Subwoofer Replace - Pioneer Shallow Mount
How to: Replace JBL Subwoofer
JBL Sub Replacement
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 01:19 PM #3
Thanks much.
This has to be the quickest and most efficient answer to any post I've made on any Toyota Forum, ever.
That's saying a lot because I always get good replies on the Toyota Forums for many years.
Old 05-20-2020, 06:06 PM #4
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Originally Posted by Dergibog View Post
Thanks much.
For sure @Bossman is "Da Boss" when it comes to supplying useful links to members inquiring on a certain subject!!
He's a great asset to these forums!!
2004 Limited V8
Old 05-20-2020, 08:14 PM #5
j4x4v8's Avatar
j4x4v8 j4x4v8 is offline
Real Name: Jordan
j4x4v8 is on a distinguished road
j4x4v8's Avatar
Real Name: Jordan
I opted to just disconnect it and have an 8in sub under the front seat. Fits and hits hard enough for me. I also put component speakers in the front, which did require a small bracket fabrication for the tweeters (factory bracket is part of the tweeter, so it’s unusable) It’s easy enough to do with a piece of wood.
04 4Runner SR5 4WD V8
j4x4v8 is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 07:36 AM #6
rokr1292 rokr1292 is offline
rokr1292 is on a distinguished road
As you have a JBL system I'm sure it wont be quite as simple, but I just installed an 8' kicker comp shallow mount and a 400w amp into/onto the factory box and it works great, hardest part was getting the subwoofer mounted securely, as the diameter of the factory JBL speaker was slightly larger, and had a different hole pattern.
rokr1292 is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 10:03 AM #7
Mike07SE's Avatar
Mike07SE Mike07SE is offline
Mike07SE will become famous soon enough
Mike07SE's Avatar
Mind me asking, but what brand/model did you go with?
How was the fitment, any issues?
And did you do one under each seat or just one under the driver or passenger?
I picked up a while ago a JBL sub enclosure from a junkyard. Plan is to add decent amount of bass to the system without encroaching on cargo area. Still have to find a sub specific side panel (donor was obviously wrecked and panel was unusable).
Thanks!
SOLD2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers | Ironman4x4 FCP's & UCA | Fuel Rebel 20x9+1 | GY Duratrac 275/60R20 | Victory 4x4 FLRR
Mike07SE is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 05:45 PM #8
j4x4v8's Avatar
Real Name: Jordan
j4x4v8's Avatar
Real Name: Jordan
Thanks!
I went the cheap-route with the sub because of budget, and yeah only 1 under the drivers seat. But I see no reason why you can’t put one under the passenger seat. (Actually, it’s kinda on my extended to-do list to have one under each seat.)
Model of 8” low profile sub I bought: Audiopipe APLP-800 (aplp800) 400W Active Low Profile Security Check
Fits great, sounds good. I’m 6’ 2” for the record, so it’s not like I’ve got the seat jacked way up. The sub height is 3” 3/16” and fits, which did surprise me, so rest assured anything less than that will fit too. Also I can’t speak to installation woes because I had an audio place do that part, but he told me there were no problems getting it to fit. He may have had to take the drivers seat off but don’t quote me on that (it was a while ago).
If price isn’t so much an issue for you, only space, I’d get the JBL BassPro SL2 It’s lower profile and I’ve heard good things about the JBL low profile subs. I bet one of those under each seat would sound niice
I can get you some pictures later of how it looks under seat.
Old 05-22-2020, 06:53 AM #9
Mike07SE's Avatar
Mike07SE's Avatar
Thanks very much for that detailed reply, especially on the measured height. That will give me something to work with and I'll scope out that JBL you mentioned. As long as it fits I'm good from there and will probably do both sides at once. My daily is a MINI and the BMW's/MINI's put the mid-bass/subs under the front seats,and to me sounds good for most of the time. Not chest thumping, but good enough for me. Trying for the near same results.
factory , issues , replace , sport , unit
2004 Sport subwoofer panel question Tylerdh 4th Gen T4Rs 9 12-12-2017 12:48 PM
2004 Sport Edition DezRunner 4th Gen T4Rs 0 05-15-2014 09:49 AM
FS: 2004 Sport Edition 4WD V8 AvAd14 Classifieds - buy & sell (no commercial ads please) 2 06-10-2010 04:57 AM
Best Powered subwoofer for an '07 Sport Edition 4R Demolition Engines / Suspension / Wheels / Tires / Audio / Accessories 2 08-15-2008 02:26 AM
2004 Sport Edition V8 qballjr13 Maintenance/Detailing 0 12-10-2006 09:08 PM
