Old 05-21-2020, 09:24 AM #1
MityMax96 MityMax96 is offline
MityMax96 is on a distinguished road
Lift kit options
Hello all,
What options or kits are out there for 4" front and 3" rear lift?
Currently I have about 3" up front and 2" in the rear, and I just replaced my UCAs with Dobinson's UCAs (should allow for 4" up front now?).
So looking to see what is out there, cause all I seem to be able to find is the 3"/2" lift/level stuff.
TIA
MityMax96 is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 09:52 AM #2
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Originally Posted by MityMax96 View Post
Hello all,
TIA
The best way to do it is to spend $5k on a long travel kit, which will give you the suspension geometry to lift 4".
What happens when you lift an independent front suspension vehicle is that the CV boots will start rubbing due to the higher angle, and they'll tear in short order slinging grease everywhere. That, and you want realistically at the very least 2" of downtravel from ride height which puts you in the max 3" lift range. Something like a 4" lift your ride quality will suffer. Basically your shocks are too short.
I would go up a size in tires before attempting a 4" lift. Or install a body lift.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 10:01 AM #3
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
Hello all,
TIA
The reason everything is 3/2 is because when you go over 3" you start to get in the territory where you can have major CV issues. There also is very little down travel left at that point. I've seen some people on here saying they can get 3.5" without too much trouble, but the general consensus is that 4" is not for those that want to wheel their rig.
Why are you wanting to go to 4/3? What size tire are you trying to run?
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 10:18 AM #4
Ah I see...didn't think about that aspect of it.
Do you have a long travel kit in mind?
Old 05-21-2020, 10:21 AM #5
Currently my tires are 33" I wanna say.
To do 4/3" I was wanting the extra height, as well as possibly doing 35" tires
Even now with what I have, I need to cut out some around the front wheels...I still get some rubbing when I am backing up w/ my wheels turned.
Oh and I totally forgot to put in the trim package for the driver side....so there is that slight lean.
Edit: 32"
KO2 265 75R16's
Old 05-21-2020, 10:45 AM #6
Inv4drZm's Avatar
Inv4drZm's Avatar
Total Chaos, Dirt King, Camburg all make good kits that are +3.5" wider than stock. The 'complete' kit involves $1500-$1800 shocks sold separately so factor that in too.
You don't need a suspension lift to fit larger tires. You need lots of caster in your alignment, a body lift helps, and trimming/removing mud flaps/body mount chop.
Old 05-21-2020, 12:02 PM #7
I am gonna have to get out there and do some cutting then.
Cause I thought once I put on the UCAs, that would help
But it didn't. Took it in and had them align it.....tires are still rubbing.
Rather frustrating to say the least, cause 32" tires aren't that big on a 4Runner
Old 05-21-2020, 12:06 PM #8
Inv4drZm's Avatar
Inv4drZm's Avatar
Next question, what wheel offset?
Old 05-21-2020, 02:16 PM #9
I don't remember the offset of the rims....but there isn't much
So not a negative offset, correct? More a positive offset.
Like the tires don't stick out from under the fenders
I have American Racing Baja rims, 16x8
I think offset is 0
Old 05-21-2020, 11:47 PM #10
BlairB's Avatar
BlairB BlairB is offline
Real Name: Blair
BlairB will become famous soon enough
BlairB's Avatar
Real Name: Blair
I love my long travel, but I absolutely wouldn't do it solely for the lift aspect.
Do you have a body lift? I am running a 1.5" and it helped me quite a bit when I wanted to run bigger tires (255/80/17, a skinny 33.5'").
2008 4Runner Sport Edition 4WD V6- Long Travel, Camping Rig Build Thread
2023 Lexus LX600 F Sport- Daily Driver
2023 Highlander Hybrid Limited- Wife Daily Driver
BlairB is offline   Reply With QuoteReply With Quote
Old 05-22-2020, 07:23 AM #11
No, no body lift.
I had an old toyota pickup truck that I did a body lift on
Don't want to do that again, I don't much like them.
Old 05-22-2020, 12:19 PM #12
BlairB's Avatar
Real Name: Blair
BlairB's Avatar
Real Name: Blair
No, no body lift.
I wouldn't totally rule them out. They are definitely the best way to add an extra 1" to fit tires. I am not aware of a single issue people have had with their body lift on a 4th gen 4Runner and tons of guys are running them.
I have personally been running mine over a decade and have never had a single problem. Over the years my 4Runner has definitely been beat on harder than 99% of them and although I have had motor mounts rip off the frame, control arms and shocks break, things bend and rattle off, etc... I have never once had a single issue with my minor body lift.
Old 05-28-2020, 05:40 PM #13
What about the Bilstein coils fro about a 2.5" rear lift?
I currently have Bilstein 5100's on the back
OME coil, w/ 2" spacer.
Would like to swap that out for a coil that gives about 2.5" lift
Looking at the
bilstein 36-281831
or
Icon 3" 52800_n1
On my 3rd Gen 4Runner, I had OME's, and they weren't bad coils...but I think only gave like a 2" lift.
Old 05-30-2020, 12:00 AM #14
BlairB's Avatar
Real Name: Blair
BlairB's Avatar
Real Name: Blair
Looking at the
bilstein 36-281831
or
Icon 3" 52800_n1
Do you know how much lift do the OME coils are supposed to give you on their own?
I don't know the Bilstein coils, so I will let others chime in there.
I am not sure if they still make them, but I previously ran All Pro 3.5" rear coils and they were great until I started adding a lot of weight (drawers, fridge, rear bumper, gas cans, etc...) at which point I had to go custom. I did find when I had a lot of lift with no weight though my ride really suffered.
Old 06-01-2020, 07:21 AM #15
Sorry I mis-typed in my post
I currently have OEM springs (not Old Man Emu)
So stock springs on the back w/ a 2" spacer sitting above them.
What do you mean the ride suffered w/ that lift and no weight?
In what way?
front , lift , options , rear , ucas
Need help on options if I don’t lift ..... Bruin1md 5th gen T4Rs 17 11-20-2019 06:07 PM
Hi-Lift Gear: Best options for no Hi-Lift-ready rails/bumpers? eric_rosenwald 3rd gen T4Rs 3 06-04-2017 10:47 PM
Rear lift options with toytec/eibach front lift cma1188 3rd gen T4Rs 3 10-06-2013 01:40 PM
Lift Options? snw4runner Classic T4Rs 7 07-01-2011 05:54 PM
Different lift options ?'s Falls Off-Roading 3 02-01-2007 03:25 AM
