Old 05-23-2020, 06:36 AM #16
j4x4v8's Avatar
j4x4v8 j4x4v8 is offline
Real Name: Jordan
j4x4v8 is on a distinguished road
j4x4v8's Avatar
Real Name: Jordan
Originally Posted by Ed_C View Post
Here's the breakdown using Walker exhaust parts...
The pipe labeled “front pipe” in that diagram is piping I would still need to buy, right? I tried searching it doesn’t seem like there’s a part number for it. Something like this, and cut/weld to fit? MagnaFlow 3 in 1 Multi Bend Stainless Steel Pipe
04 4Runner SR5 4WD V8
j4x4v8 is offline   Reply With QuoteReply With Quote
Old 05-23-2020, 09:15 AM #17
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Looks like you reuse the existing OEM pipe, in the other illustration I posted it's called the "Exhaust Front Pipe Assy". Walker doesn't offer a replacement part but Rock Auto lists two brands that do
Here's a thread about the 2003-2004 style Magnaflow Y-pipe by the way Worst Y-pipe Design ever - 2003 V8 4runner
I saved a photo from the thread before Photobucket decided to charge people - OEM setup vs. Magnaflow
Old 05-23-2020, 09:01 PM #18
j4x4v8's Avatar
Real Name: Jordan
j4x4v8's Avatar
Real Name: Jordan
Smile Updated Parts List
Big thanks to everyone who has chimed in helping me figure this thing out
@JONBOY345 I ended up going with the same cats you got.
I have updated my original post to reflect my updated parts list:
HEADERS - Doug Thorley THY-564-SS-C Short Tube Headers
UNIVERSAL CATS - QTY 2 - G-Sport #50025
Y-PIPE / REAR CAT - MagnaFlow #93655
CAT-BACK - MagnaFlow #15781
AIR/FUEL RATIO SENSOR - QTY 2 - UPSTREAM - Denso 234-4138
OXYGEN SENSOR - DOWNSTREAM LEFT - Denso 234-4261
OXYGEN SENSOR - DOWNSTREAM RIGHT - Denso 234-4260
MANIFOLD GASKET - QTY 2 - OEM 1717350021
HEADER BOLT KIT - Stage 8 (8919) 10mm Header Bolt Kit
I believe I have found an exhaust shop who is willing to do the work. I will keep everyone posted with updates!
After talking to the exhaust guy, I won't need to buy that "Front Pipe" / "Exhaust Front Pipe Assy" which I believe would be the only thing left OEM, but they said they are more than able to put a new stainless steel pipe in there, including the hole for the O2 sensor.
Old 05-23-2020, 09:35 PM #19
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Excellent! The shop-fabbed will probably have smoother bends, those two listed in Rock Auto are all crinkled.
Old 06-10-2020, 11:59 PM #20
j4x4v8's Avatar
Real Name: Jordan
j4x4v8's Avatar
Real Name: Jordan
New Exhaust Installed
Got my 4Runner back from the exhaust shop
It sounds so much better, especially paired with the K&N!
I do get the droning at ~2100 RPM which is unfourtnate for going around corners and stop/go traffic, and also when going 70-80MPH. But everywhere else it sounds perfect. I'm willing to bet other people wouldn't even consider what I am talking about as 'droning' at all.
Here's what my mechanic said about the headers:
  • 2 studs broke off in head and had to be extracted
  • Header holes not lining up with head
  • Had to remove headers 4 times on drivers side to get all studs to start
  • Passenger side header also had fit issues
He did the install solo to my knowledge. He opted to not put the locks on the stage 8 header bolts until after I drive it a few hundred miles and it needs to be re-torqued.
I am getting a dreaded CEL: P0154 - O2 Sensor Circuit No Activity Detected Bank 2 Sensor 1. That's the upstream A/F sensor for the passengers side header I believe. So I don't think I need the O2 spacers, which are for downstream (as @4RunnerAquasport pointed out). I'm hoping the sensor just needs to be wiggled or something.. maybe I got a bad Denso? Not sure.
Video 1 - Startup / idle sound - YouTube
Video 2 - Phone on dash; all windows down - YouTube
Hey @JONBOY345 do you have that Vibrant Resonator right before the Magnaflow muffler? How's the sound? Is it just as loud everywhere else for the most part, and the resonator gets rid of the droning? Would love your thoughts since I realized we have a pretty similar exhaust setup minus the Y-Pipe.
P.S. I sold my old cats to RRCats, $103/ea for the manifold cats and $73 for the Y-Pipe cat.
Pictures of the welds & underside coming very soon
Old 06-11-2020, 01:33 AM #21
meltdowner meltdowner is offline
Real Name: Tim
meltdowner is on a distinguished road
Real Name: Tim
Sounds good. I vae the 06 v8 and am thinking of doing similar. I have the doug thorleys ready but honestly just want stock exhaust setup beyond that. I dont want loud and cant stand droning at all.
What did this whole thing cost you? Especially curious on the labor.
meltdowner is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 02:10 AM #22
j4x4v8's Avatar
Real Name: Jordan
j4x4v8's Avatar
Real Name: Jordan
New exhaust system for 04 4Runner v8
I imagine that just doing the headers won’t add too too much noise. If you’re keeping everything else stock you should be good there.
My labor bill was $950 which includes headers, “front pipe” fabrication, welds, and install of the bolt-on cat-back. I’ve seen folks on the forums talking about labor quotes upwards of $2k just for the headers. I shopped around a few shops, a couple wouldn’t do headers and one I got a ~$1.2k estimate. It all depends where you’re located I think.
Old 06-11-2020, 04:29 AM #23
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is online now
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
@j4x4v8 sensors are new? where did you source the AF sensors? You might already know there has been complaints about Denso bootleg parts out there. Do you have your old ones you could swap out? And of course check the connector and wiring as well. Sounds amazing, way better than mine. My old muffler is getting a louder drone by the day.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is online now   Reply With QuoteReply With Quote
Old 06-11-2020, 04:49 AM #24
j4x4v8's Avatar
Real Name: Jordan
j4x4v8's Avatar
Real Name: Jordan
Thanks man! Yep they’re new, and unfortunately I found out about the bootleg parts after I ordered them from Amazon. I just checked and it was sold by Amazon services, not a 3rd party seller, but still a cause for concern if the market is being flooded with fakes. I may have accidentally left the old sensors on the manifold converters I sent to get scrapped (oops)
Old 06-11-2020, 06:07 AM #25
Real Name: Brett
Real Name: Brett
Sorry to hear that. From what I can tell, the dealer or Rock Auto might be your only option. Rock Auto being much cheaper if they are in fact genuine Denso. Quick search showed $175 for the right front on a dealer site, ridiculous. Try a quick search of the pick and pull yard in your area if you have the time. You might get lucky and find one that works for pennies on the dollar. Lexus 470s might work as well as Tundras. Just my opinion, but we need to weed out the crap that's getting sent to this country and bring some viable production back here as well. The management of these online stores don't care about QC, just bottom line. Sick of these people that compromise everything in the name of acquiring their next Mercedes. Good Luck!!
Old 06-11-2020, 08:32 AM #26
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
Looks great. I really like the look and sound of the Magnaflow kit. Added bonus is that it's a straight-through muffler unlike other options out there.
I do have the Vibrant Resonator before the muffler and it did noticeably help with the droning. It didn't eliminate it completely but certainly took it down a notch or two. As both the muffler and the resonator burn-in (due to the fiberglass packing material) it will get a bit louder. It happens so gradually you'll hardly even notice the change unless you compare some recordings of it.
Here's the link to the post I made about the Catback project: https://www.toyota-4runner.org/3253598-post32290.html
Note I had OEM Manifolds, and y-pipe at the time of the post.
That said, if I were to do it again, I'd get a 1/4 Wave Resonator instead. I took it to a shop recently to have them look at that, and they said there wasn't room to do one.
But, dirty deeds has a helmholtz resonator they make... Might be worth calling them to see if it works on our trucks: Helmholtz Resonator - DIRTY DEEDS INDUSTRIES
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 07-09-2020, 04:51 PM #27
V8Limited4wd's Avatar
V8Limited4wd V8Limited4wd is offline
V8Limited4wd is on a distinguished road
Wow $950 is cheap... I'm getting a quote for $1500 up in NoVA. Which shop did you have it done at in Richmond?
2004 V8 LIMITED 4WD
[INT/EXT] 06+ Projectors & HIDs/LEDs/CDN Hood deflector/SS Bull Bar & Hitch Step
[ENGINE] aFe Pro DRY S Air Filter/DT Headers/TRD Dual Exhaust
[WHEELS/SUSPENSION] OEM 20" Rims(265/50R20)/Dobinsons Suspension 2" lift
V8Limited4wd is offline   Reply With QuoteReply With Quote
Old 07-09-2020, 05:30 PM #28
j4x4v8's Avatar
Real Name: Jordan
j4x4v8's Avatar
Real Name: Jordan
I ended up driving to B & R Customs in Fredericksburg to get it done!
Old 07-09-2020, 08:07 PM #29
ryanarcane ryanarcane is offline
ryanarcane is on a distinguished road
Hi I need help with this as well in the same boat but V6 2004
My left rear catalytic converter has gone bad and I live in NY. I was thinking of using Bosal but they don't comply with NY/CA standards. I have to get something that does. I was thinking Magnaflow but I don't know if aftermarket CAT would remove the CEL. Can someone please advise on what my options are in NY. I don't want to use Universals because I don't want to depend on the quality of the weld job. Thanks in advance.
ryanarcane is offline   Reply With QuoteReply With Quote
Old 07-10-2020, 12:03 AM #30
I might have to take mine there to get it done. How long did it take and did you go back home then go back once they were done?
2004 V8 LIMITED 4WD
4runner , doug thorley , exhaust , magnaflow , system
Recommeded Exhaust System for 2000 4Runner V6 4RunnerPride00 3rd gen T4Rs 31 03-06-2015 05:02 PM
WTB, 00 4runner TRD cat back exhaust system mattstang66 Classifieds - buy & sell (no commercial ads please) 0 03-23-2011 08:52 PM
WTB black westin bull bar and exhaust system for 08 4Runner boostedprozac Classifieds - buy & sell (no commercial ads please) 0 02-09-2009 01:52 PM
TRD Exhaust System for 4runner 4Runner4UGA Engines / Suspension / Wheels / Tires / Audio / Accessories 0 12-23-2003 05:46 PM
