Old 07-10-2020, 07:23 AM #31
j4x4v8's Avatar
j4x4v8 j4x4v8 is offline
Real Name: Jordan
j4x4v8 is on a distinguished road
j4x4v8's Avatar
Real Name: Jordan
New exhaust system for 04 4Runner v8
Originally Posted by ryanarcane View Post
My left rear catalytic converter has gone bad and I live in NY. I was thinking of using Bosal but they don't comply with NY/CA standards. I have to get something that does. I was thinking Magnaflow but I don't know if aftermarket CAT would remove the CEL. Can someone please advise on what my options are in NY. I don't want to use Universals because I don't want to depend on the quality of the weld job. Thanks in advance.
I only have one rear cat, so I can’t speak to your vehicle specifically. However if you’re getting a direct fit MagnaFlow replacement cat, like I got for my Y-Pipe (see my parts list), then you shouldn’t have any issues with CEL. The direct-fits are made to be replacement OEM parts, and will have the O2 sensor bung included if necessary. MF should make a bolt-on replacement cat for your vehicle that’s NY compliant if you check their site.
If you did universal cats you would probably need the O2 sensor bungs welded on as well. I wouldn’t worry about the quality of the weld job as a factor. If an exhaust shop with good reviews couldn’t weld exhaust pipe, they probably wouldn’t be in business.
Originally Posted by V8Limited4wd View Post
I might have to take mine there to get it done. How long did it take and did you go back home then go back once they were done?
Yeah you would have to leave it there. Drop it off the day before, so vehicle is cold in the morning. I was fortunate enough to have a friend follow me both times, so I didn’t have to do a $70 Uber. Overall took 5 days if you include day I dropped off and day I picked up. Also like I had mentioned in an earlier post on this thread, the DT ST had quite the fitment issues. I believe the job ended up being more difficult and time consuming than expected.
04 4Runner SR5 4WD V8
j4x4v8 is offline   Reply With QuoteReply With Quote
Old 07-10-2020, 09:52 AM #32
V8Limited4wd's Avatar
V8Limited4wd V8Limited4wd is offline
V8Limited4wd is on a distinguished road
Thanks for the info! Hope to finally get it done this summer. Did you ever consider just getting a straight Y-pipe without the third cat? Wonder if that would trigger the check engine light.
2004 V8 LIMITED 4WD
[INT/EXT] 06+ Projectors & HIDs/LEDs/CDN Hood deflector/SS Bull Bar & Hitch Step
[ENGINE] aFe Pro DRY S Air Filter/DT Headers/TRD Dual Exhaust
[WHEELS/SUSPENSION] OEM 20" Rims(265/50R20)/Dobinsons Suspension 2" lift
V8Limited4wd is offline   Reply With QuoteReply With Quote
Old 07-10-2020, 12:07 PM #33
I'm not sure about pricing, but I found a set of two magnaflow OEM grade cats (#51005) and the standard Y-pipe (#93655) for $600... not sure if that's a decent price.
2004 V8 LIMITED 4WD
Old 07-10-2020, 03:54 PM #34
j4x4v8's Avatar
Real Name: Jordan
j4x4v8's Avatar
Real Name: Jordan
Yes it would trigger the CEL if you got the straight Y-pipe. But that’s exactly what the Blox O2 spacer is for, removing that CEL. I didn’t consider it myself because I wasn’t the one doing the install. Due to the legality aspect, exhaust shops / installers won’t do that kind of work (unless you have a real good relationship with them). I went into a few exhaust shops to talk over the job and get estimates and they would always slip in something about “gotta keep the cats — gotta have the cats” into the convo. I guess on the off chance I’m state police? Hah.
Yep #93655 is the Y-Pipe/Cat I got. Was $236 on Amazon, $280 after shipping/taxes. If you are going to stay legal that would be the one to get.
As for the (2) #51005’s .. I actually had those on my parts list originally. But I wasn’t sure if those cats are meant to go directly after the headers, or if they’re only for the rear. I ended up going with the G-Sport cats to play it safe, but I would give Magnaflow a call and ask.
Overall $600 does seem like a decent price for all (3)
Old 07-10-2020, 06:54 PM #35
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Thanks for the initial post on the parts you used. This is likely the route and parts I will go when I do my 2003. Should be virtually identical unless I decide to go with long tubes. But I'll still run the cats.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 07-21-2020, 12:01 PM #36
I got in touch with the shop, gave me a $1k estimate which is great compared to other places. Quick question, did you need to buy new gaskets (other than the one at the engine) and clamps? If you want to get it tuned, there is a shop in MD that was able to tune the ECU. By any chance do you have pics of the pipes underneath?
04 V8 Doug Thorley install with custom crossover pipe by GT Peace Automotive - Page 2 - Toyota 4Runner Forum - Largest 4Runner Forum
2004 V8 LIMITED 4WD
Old 08-13-2020, 01:37 PM #37
By any chance, do you have a pic of the piping? Finally got all the parts and will be doing it in september!
2004 V8 LIMITED 4WD
4runner , doug thorley , exhaust , magnaflow , system
Recommeded Exhaust System for 2000 4Runner V6 4RunnerPride00 3rd gen T4Rs 31 03-06-2015 05:02 PM
WTB, 00 4runner TRD cat back exhaust system mattstang66 Classifieds - buy & sell (no commercial ads please) 0 03-23-2011 08:52 PM
WTB black westin bull bar and exhaust system for 08 4Runner boostedprozac Classifieds - buy & sell (no commercial ads please) 0 02-09-2009 01:52 PM
TRD Exhaust System for 4runner 4Runner4UGA Engines / Suspension / Wheels / Tires / Audio / Accessories 0 12-23-2003 05:46 PM
